#1 Posted : 08 January 2011 07:08:06(UTC)
Over the years Märklin and other manufacturers have produced locos with limitations.
a,) Smoke generators (plastic housing)
b.) inadequate pulling power
c.) steam locos with divided frames
I've just inserted a smoke generator into my steam locos Art. No. 3086, 3112 both BR 86's, both have been converted to digital with a 5pole armature.
The apparent reason for not installing the smoke generator into a steam loco is a plastic housing.
Seuthe, the firm that produces smoke generators have a smoke unit suitable for plastic bodies.
To do job yourself, you have to be careful not to damage the chimney when drilling a hole through. the more time you take to do it the more chances you have not to damage it.
I've used a 3/16 drill bit but you start off with a much smaller size drill and step up a size as you go along.
The end result is, your heat protected smoke generator fits into the chimney.
connecting the 2 wires is simple, 1 to ground and the 2nd one to your Function 1 outlet.
At the same time I'm trying to add a sound decoder to this particular loco but whether I'll be successful or not will be revealed later on.
My 3rd attempt is the the Class 78 (3106), this loco has a metal boiler and again, I drilled a hole, this time a smaller drill size (3.5mm).
The problem is the chimney sits right above the light socket.
So I had to cut away the light socket (metal) and reduced the height of the light socket and after reducing the height, super glued it back on and this will give me the base for the connection.
because I've reduced the height, the light diffuser is no longer suitable either.
Reason:
the light bulb holder was upright, the light bulb holder is no longer available for a bulb and there isn't enough room underneath the re-glued bulbholder to fix a bulb holder and led.
Solution:
remove light diffuser and replace and fix tiny led's to the light lanterns.
this job hasn't been finalized yet but it is encouraging, a solution has been detected.
Smoke generators will be added to steam locos otherwise, either hasn't been installed or provided for by Märklin or it is impossible to do so, purely because of the size of the chimney in question (plastic housing)
Another loco in question is the Class 96 and because Märklin didn't provide any space for a smoke generator I've sold these locos.
Since than I've found out, someone else has actually fitted a smoke generator into this loco without any major problems.
Other steamlocos in questions are: BR 89, Br 80, Br 81, TT 800, Br 24 and I've converted my BR 23's already with steam generators.
My next topic is:
Steam locos with divided frames:
There are 2 loco types which come into my mind.
BR 53 and BR 96.
Looking at the construction of previous locos with divided frames or coupled frames are BR 44, BR 50 etc etc.
Looking at the construction and method used, I can't see any reasons why Märklin hasn't coupled the frames together so all axles are powered.
I'm sure, something like a linking rod could be fixed in the middle between the 2 frames.
ÖBB Rh 86
BR 78
added small wire distribution board for smoke generator, Roco 4 pin electrical coupling, wires for lights
Offline kariosls37
#2 Posted : 08 January 2011 08:14:01(UTC)
kariosls37
Nice upgrades JohnThumpUp
I have fitted a normal 3.5mm smoke unit to a BR 24 without problems. A bit of 3/16 tube provides the earthing. I also fitted lights on the tender.
#3 Posted : 08 January 2011 08:55:55(UTC)
thanks Rick,
Will update my progress.
When you say you've fitted a smoke generator into a BR 24 what type did you put in ?
Offline Ian555
#4 Posted : 08 January 2011 09:03:33(UTC)
Ian555
Hi John,
Great work on the Loco's. ThumpUp
Your detailed photo's and description make it very easy for a "first timer" to follow.
Thanks, I must try it sometime.
Ian.
Offline kariosls37
#5 Posted : 08 January 2011 09:22:03(UTC)
kariosls37
A Marklin 72270. It can sometimes be a bit touchy, either a very small whisp of smoke or a heavy plume, but I'm satisfied with the solution. I made the +ve contact from a bit of brass( .22 gun cartridgeBigGrin) and styrene, this way there is only one wire to the housing.
A thought for the "hinged chassis locos", it will be quite hard to fit a nice solution. Maybe the best way is to build a completely new chassis out of brass sheet.
A new motor with its axle lengthways and a few reduction gears below it, transmitting power to a long axle just above the axles. A wormwheel transmits the power to the drving wheels. With a bit of luck this can fit between the frame plates and out of view. A cardan at the hinge will power the front unit.
Let me know when youv'e finished itLOL I'll leave my BR 53 alone. I have enough locos to scratchbuild.
#6 Posted : 08 January 2011 15:30:42(UTC)
Thanks Ian,
Here is the almost finished product. Have to fiddle around a bit to avoid the light coming through the front.
It took me longer than anticipated.
the Led's gave me some trouble, because of my stupidity.
I connected the bottom two and added the 3rd separately but to the same circuit.
one cuts out the other one.
Than I thought, I've connected the wires wrongly on the 3rd led (top)and it still didn't work.
Finally I've got it right.
the smoke unit was easier to install than expected.
Got rid of the bulb holder and replaced it with another bulb holder (sparepart) super glued it onto the frame after cutting off more of the original bulb holder, down to the base.
Offline Darren W
#7 Posted : 08 January 2011 16:55:58(UTC)
Darren W
Great workThumpUp . Thanks for posting pictures of what you are doing. It will help many others get up the nerve to upgrade loco's.
Cheers...
Darren
#8 Posted : 09 January 2011 02:06:25(UTC)
Thanks Darren,
I'll paint the underside black so you can't notice the alterations that much.
May have to take out the little PCB and make the height thinner, so the housing doesn't get pushed upwards (1mm) at the front where the lights are.
Offline Chris6382chris
#9 Posted : 09 January 2011 06:51:27(UTC)
Chris6382chris
John nicely done. I have the metal BR 81 and Plastic BR 86 both from recent starter sets and I have wanted to add steam to both. I haven't really looked at the feasabilty yet but after your posts I am going to seriously look at it.
Chris
#10 Posted : 09 January 2011 07:13:58(UTC)
Chris
The BR 86 is not easy to convert, the wiring is simple and you don't need any contact lip for the smoke generator.
the tricky bit is drilling the hole without damaging the chimney.
I've managed to separate one chimney from the housing, though I've been able to put it back onto the smoke generator.
So drilling the hole, don't use an electric drill, you can use one without turning the power on and hand drill it, even than the drill could bite into the plastic and gashes a hole into the chimney. so patience is the key word. every time you feel it grips release the pressure so the drill turns freely.
If you manage to do this your home and free of any further complications.
This page was generated in 0.898 seconds.
