Offline Neil
#1 Posted : 08 January 2011 20:06:27(UTC)
Neil
I am seeking a tender for an SK800. I would post a photo but I have not figured out how to do that. Thanks for any help.
#2 Posted : 08 January 2011 23:32:19(UTC)
To post a photo, when you edit the post on the Bottom Left tick the box attach Files.
That also includes photos.
When you have finished and posted and you forgot there is a n attach button next to the edit button.
NN
Offline CCS800KrokHunter3
#3 Posted : 09 January 2011 00:07:16(UTC)
CCS800KrokHunter3
What version of the SK 800 tender are you looking for? I have several SK 800 tenders in varying conditions and versions.
Paul
#4 Posted : 09 January 2011 09:52:31(UTC)
Paul
...and if needed I have a few bits around, including original spares bogies I have kept for the last 30 years!
Offline goneclandestine
#5 Posted : 21 January 2011 03:09:05(UTC)
goneclandestine
Paul
Jvuye,
I have just seen the picture which you posted. I am also restoring an old SK800 and the last bit I need is a bogie for the one which is snapped on my tender. My model is from 1949.
Andrew
#6 Posted : 22 January 2011 10:59:21(UTC)
Originally Posted by: goneclandestine Go to Quoted Post
Jvuye,
Andrew
Hello Andrew
I still have these.Smile
If your SK 800 is from 1949, in theory, you need the tin plate style bogies, not the die cast version I have.
Are you sure this is the model you need?Confused
Jacques
#7 Posted : 23 January 2011 10:32:58(UTC)
Pictures of SK800 on http://www.modellbahnboerse.org/3000-2.htm
Can you tell me which one is it?
Also Welcome to the forum.
#8 Posted : 23 January 2011 10:39:53(UTC)
goneclandestine
Jvuye,
Andrew
Hello Andrew
Jacques
Hi Jacques,
That is interesting about the tin plate style bogie. Looking at mine, it would appear to be die cast and look exactly like yours in the photo. So maybe it is not from 1949 afterall.. But I am pretty sure that one will suit the tinder fine BigGrin
Cheers!
Andrew
#9 Posted : 23 January 2011 10:43:22(UTC)
Hi Andrew,
Welcome to the forum.Smile
#10 Posted : 23 January 2011 10:48:40(UTC)
goneclandestine
Thanks StevenBigGrin
#11 Posted : 07 February 2011 22:10:52(UTC)
Jvuye,
Andrew
Hi Andrew
I have replied via PM, please check your forum PM inbox!
This page was generated in 0.391 seconds.
