I was able to recently win a Marklin set at auction for decent price, but with one draw back. The transformer is for a 220 outlet. I have not received it yet, but if this transformer is similar to some of the ones I already have, it is very hard and/or impossible to open in order to rewire with a new step down transformer. I was wondering if I could just use an adapter plug/voltage converter like the ones that are available at Radio Shack or any electrical shop in order to use this transformer? Any suggestions will be greatly appreciated. Karl
Joined: 08/12/2004(UTC) Posts: 4,430 Location: Attiki Athens Greece
I think that is a little risk use an adapter.A new transformer have low price and you are sure for transformer and your locs.
Joined: 12/01/2003(UTC) Posts: 2,528 Location: Groton, Connecticut
I second foumaro advice. Get a 110 transformer for the set.
Ira |
Building German Era I-II layout(Mk IIIc).  |
Joined: 31/01/2003(UTC) Posts: 140 Location: Madrid, Madrid
Hi Karl, As Ira and Foumaro has told you, I wouldn't try to modify the transformer due to the risk of short-circuit, burning or, what is worse, damage seriously any of the connected items (Central Station, 6021, even locomotive & switch decoders [:(] ). It's safer trying to acquire a 110V transformer directly. But don't think about getting rid of your 220V transformer. As far as I can remember from my old electronics at school, any transformer can be fed up with less voltage but it will have less voltage in its output. So assuming your 220V transformer has an output of 24V, if you plug it to 110V you will have 12V, which is perfect for a dim lighting all around your layout  NOTE: Do not try to do the opposite, feeding a transformer with more voltage than it was designed for can burn it out. Best regards. |
Julio Castillo Madrid, Spain
Joined: 21/10/2004(UTC) Posts: 31,704 Location: United Kingdom
THE 110 VOLT TRANSFORMER IS A MUST FOR AMERICA MARKET.220 VOLT FOR EUROPE.OTHERWISE SAFETY FEARS[xx(] |
Joined: 19/12/2003(UTC) Posts: 1,205 Location: Swindon, Wiltshire
I've bought a cheap ($10) step-up transformer (110 to 220) where my existing 220 M* transformer plugs in to. Everything works just fine. |
Richard |
Joined: 22/04/2004(UTC) Posts: 12,139 Location: New York, NY
Or you could get some 220V outlets - so you can buy the original Starter Sets from Germany, which are cheaper plus easily available  John |
I hope no one visits a poor Southener's layout in Brooklyn. Intruders beware of Gators. AT&SF, D&RGW, T&P, SP, WP, UP, BN, NYC, ARR, epI-III - analog & digital Marklin Classics only. CU#6021 FX-MOTOROLA DIGITAL SYSTEM. Fast as lightning and no trouble. What else ... Outlaw Member of BIG JUHAN's OUTSIDER CLUB. With the most members, worldwide
