Offline Chris Honer
#1 Posted : 08 November 2010 18:06:31(UTC)
Chris Honer
You have been a member since:: 08/11/2010(UTC)
I am new to the forum. This weekend my shipment from Lokshop arrived. Part of my order was the 29814 Swiss Mega Starter set. Everything else in my collection has been purchased in the US (older digital stuff... 80f unit controlled). I did not consider the fact that something ordered from Germany would have a transformer made for European electrical service. My question is, will I do any damage to the 60214 central station by simply using a US plug adapter? Would it be better to buy a 60055 transformer? Does it matter?
Any advice would be greatly appreciated.
Kind regards,
Chris - Chatham, NJ
#2 Posted : 08 November 2010 18:13:50(UTC)
Kind regards,
Chris - Chatham, NJ
Hi Chris, it matters very much!
The European power pack is designed to accept a nominal 230V. If you feed it with US house current it will not be able to function, and might cause damage to itself. I think it unlikely that it will damage the Central station, though, but it definitely will not work.
Get the 60055 transformer, if that is the correct US voltage rating.
Offline GSRR
#3 Posted : 08 November 2010 18:33:59(UTC)
GSRR
Chris,
Welcome to the forum.
Any thoughts on a step up transformer?
https://www.amazon.com/S...172282&s=electronics
http://www.220-electroni...sformers/trans/prod.html
Thomas
#4 Posted : 08 November 2010 18:37:24(UTC)
Hi Chris,
Offline Chris Honer
#5 Posted : 08 November 2010 18:59:49(UTC)
Chris Honer
Thanks to all for the quick responses. I definitely wanted to avoid making any kind of tragic mistake. I've been lurking around for a few months now (reading and digesting) and all of the great discussions have really been a big help towards my decision making and money saving. I appreciate the fact that there is a support group with knowledgable folks willing to share.
Kind regards,
Chris - Chatham, NJ
Offline Piggy
#6 Posted : 08 November 2010 19:51:47(UTC)
Piggy
First of all welcome to Chris.
From what I can see your set is supplied with DC switchmode supply, most switchmode power supplies are unversal now a days. The power supply from ESU is unversal, and should do the job. It's possible that the one you got in the set is universal too, but Märklin just haven't stated it. Personally I would try it, while disconnected it from the CS2, and check the output voltage with a multimeter, it should read approx. 19 V dc.
If the transformer is safe for 230 Vac then I can't see why it shouldn't be for 115 Vac.
Kenneth
#7 Posted : 08 November 2010 20:04:54(UTC)
Kenneth, it might or might not be safe to try it. Supplying half of the correct voltage might correspond to a "brownout" situation, where the power supply might be working hard to try to supply 19V from an input which is too low. This could cause component failure, depending on the design of the circuits.
If the supply were universal it would show the input range 100-250V on the label. If it specifies 230V I would assume it means just that.
Offline gachar001
#8 Posted : 08 November 2010 20:29:43(UTC)
gachar001
India
A good quality step up transformer (120 to 230 V with the appropriate wattage) should work. When I bought my mega starter set, that's what I used until I got a 60055 transformer. I am not sure if there will be any negative effects if used as a long term solution. The experts here will clarify that.
Gautham
Atlanta, GA USA
Offline Piggy
#9 Posted : 08 November 2010 20:31:47(UTC)
Piggy
Point taken, Ray. Personaly I would try, but I would admit I'm don't have much fear of electricity.Scared
Anyway it must easy optain PSU in the US with those specs, maybe made a DCC system at fair price.
Kenneth
#10 Posted : 08 November 2010 20:50:32(UTC)
Chris,
have you contacted Lokshop and let them know about this issue. many times, they will replace the Euro transformer or power supply with the corresponding one made in the USA. Contact them and let us know what happens before you go out and buy a step up transformer. If they do not offer to help, contact Maerklin directly at service@maerklin.de and see if they step up to the plate.
I would not expect a US Dealer or Walthers to offer much help. They might offer to sell you the 120VAC US part.
#11 Posted : 08 November 2010 22:02:38(UTC)
The problem you will have there, is that the CS2 has a special 4 pin socket for the power supply to plug into. So you can't just go and buy any switchmode power supply and expect it will plug straight in. I believe it is possible to use any of the current Marklin AC transformers with the CS2, you just need to source a cable with the correct plug on it from somewhere.
Maybe the suggestion of a step-up transformer is the best one for now, until Marklin release the 120v version of the 60061 switchmode power supply.
BTW, welcome to the forum, Chris.
#12 Posted : 08 November 2010 22:04:30(UTC)
It does specify that, and you are right Ray, it means 230v only. Although, having said that, mine is working OK on 240vac.
Offline GSRR
#13 Posted : 09 November 2010 00:38:22(UTC)
GSRR
Chris,
as Mike C mentioned with a notice to the dealer ahead of shipping most will exchange the transformer for a 120V version useful in North America. You can contact the dealer and see if they will do an exchange, however that will involve shipping charges. You could also try selling it on eBay with a disclaimer that it is 230V.
If you are looking for possible alternatives that you feel confident in undertaking then have a look at these two threads. The usual caveat of doing some research and being informed applies.
https://www.marklin-user...&m=259570#post259570
https://www.marklin-user...&m=259509#post259509
Thomas
#14 Posted : 09 November 2010 01:35:21(UTC)
230 V means 230 V +/- 10 % (207 to 253 V).
As long as your 240 V stay within +6 %/-10 % then you're using it within its specification (AFAIK it's 240 V +/- 10 %).
Back to topic: I think that this power supply along with a step-up transformer will perform better than a transformer for US voltage.
Märklin doesn't offer power supplies for the US yet.
Offline Chris Honer
#15 Posted : 02 December 2010 18:12:41(UTC)
Chris Honer
Dear Gautham,
First, I got a step up transformer. Works fine. Good stop-gap measure. Yesterday, my 60055 transformer arrived. I was a little surprised to find that the 60055 transformer does not appear to be directly compatible with the 60214 central station. Central station has a round four-pinned receptor socket, while 60055 has a narrower, round plug with no pins.
Can you tell me what intermediate item I am missing?
Chris
Offline GSRR
#16 Posted : 02 December 2010 18:33:50(UTC)
GSRR
Chris
Chris,
You may need the following spare part number from Marklin 120722. Others can confirm. Marklin changed the pin design for the CS2.
You can read more here:
https://www.marklin-user...aspx?g=posts&t=17214
r/Thomas
Offline gachar001
#17 Posted : 02 December 2010 19:45:01(UTC)
gachar001
India
Chris Honer wrote:
Dear Gautham,
Chris
Chris,
Congratulations on your transformer.
I am not sure why it is not compatible. I am not in front of mine now so I am unable to see what type of plug it has.
I'm sure someone else here can help you out.
Gautham
Atlanta, GA USA
Guest (6)
This page was generated in 3.677 seconds.
