Offline mal239
#1 Posted : 16 October 2010 15:06:40(UTC)
mal239
I have recently purchased the starter set 29532. Unfortunately, it is not working. I am trying to start the locomotive, but it is not running? Could you please help me?! By the way, there were no instruction book in the set!
Looking forward...
Thank you ahead!
Offline Brakepad
#2 Posted : 16 October 2010 15:15:59(UTC)
Brakepad
France, Metropolitan
Looking forward...
Thank you ahead!
If this set was purchased second-hand (is what it seems if there was no booklet in the set), are you using the attached MS to make it work?
If the set is not new, chances are either that the MS is not properly setup (swapped MS, digital codes changed) or the locomotive's digital code has been changed so the digital code in the MS and in the locomotive do not match.
If you have one, try to make it work with an analog trafo. If it does, the locomotive has not a mechanical problem.
You can also open the loco and check which digital code has been set on the decoder, and adjust the MS to have the same so you can make it work with the MS.
#3 Posted : 16 October 2010 15:25:05(UTC)
29532 loco manual. (Factory setting address code 78).
http://medienpdb.maerklin.de/product_files/1/pdf/29532_betrieb.pdf
Mobile station manual.
http://medienpdb.maerklin.de/product_files/1/pdf/60652_betrieb.pdf
If the links above not work, Try copy and paste the link.
#4 Posted : 16 October 2010 21:37:50(UTC)
The loco has a programmable decoder, no need to open it.
Mal239,
Setup the loco from Database. If it doesn't run then change the address.
Offline mal239
#5 Posted : 17 October 2010 00:45:26(UTC)
mal239
Thank you a lot! I just had to enter Factory setting address code 78!
It is working now!
Thank you again!
#6 Posted : 17 October 2010 12:44:09(UTC)
Nice to hear your set problem solved.
Also welcome to the forum.Smile
This page was generated in 0.342 seconds.
