Offline ulf999
#1 Posted : 15 July 2005 16:46:53(UTC)
ulf999
Has anyone built the New River Mining Company (http://www.walthers.com/exec/productinfo/933-3017)and used it on a layout?
If so, did you use C or K track?
/Ulf
#2 Posted : 16 July 2005 11:41:31(UTC)
I havent any walthers.What is the clearance lengths (high + wide) to spare for wagons?
#3 Posted : 18 July 2005 16:30:27(UTC)
Ulf: Sorry no - but it looks impressive ! Nice kit ... Smile
Offline PierreGILLARD
#4 Posted : 23 October 2005 16:45:05(UTC)
PierreGILLARD
Hello Ulf,
I don't have that specific kit but several other from Walthers. Usual quality is equivalent to products from well known European makes ... because they are mostly manufactured in Europe (some kits are manufactured for Walthers by Kibri, for instance). Even instruction sheets are printed on A4 size papers instead of Letter format !
Of course, if you would like to add a realistic look, you will have to paint, weatherise and add some details but that is just like for any other kit.
Have fun with that kit ... and please post pictures and report when completed.
Pierre.
#5 Posted : 29 October 2005 13:58:17(UTC)
I guess you need K track to make better room for wagons.
#6 Posted : 29 October 2005 16:55:19(UTC)
PierreGILLARD
... or rise the buildings !
Pierre.
Offline ulf999
#7 Posted : 12 January 2006 22:54:25(UTC)
ulf999
Work has begun!
With the slim turnouts the track spacing is ok.
#8 Posted : 12 January 2006 23:12:07(UTC)
PierreGILLARD
Thanks for the information, Ulf.
You will now have plenty of fun assembling this kit. Please keep us informed about work progress.
Pierre.
#9 Posted : 13 January 2006 00:26:20(UTC)
Ulf, this looks very promising. Keep on it !
Offline ulf999
#10 Posted : 20 March 2006 22:15:09(UTC)
ulf999
Following Pierre's example, I moved the pictures to this topic...
Many, many window bars/mullions to paint [xx(]
Plenty of pieces. These (walls) have been painted, dirtied and rusted with Polly Scale paints (reefer gray, rust, black)
First part with windows glued. umpteen more to go...
[img]https://www.marklin-users.net/upload/Community/Notpublic/ulf999/NRM6.jpg/img]
More work done on the N.R.M. It's a big sucker!
Edited by moderator 11 January 2011 21:30:08(UTC)  | Reason: Not specified
Offline ulf999
#11 Posted : 20 March 2006 22:19:56(UTC)
ulf999
Woodland scenics "Coal Mine Run" added just for the look Smile
Roof (most of it...) in place
Do I need more weathering? Probably...
Experimenting with some broken windows, a bit hard to spot in the picture...
Coal tumbling didn't work as I wanted (dust wouldn't stay on [:(]) so I added a wash of Polly Scale Dirt to the windows.
An more rust on the steel plates
Next step is a wash of black and then I'll airbrush some more 'Dirt' or 'Earth' all over it. When I'm done the coal cars will look too clean next to this Coal Mine...
Offline ulf999
#12 Posted : 20 March 2006 22:29:13(UTC)
ulf999
Roof before using Humbrol Model Filler
Filler applied
Sanded and painted. Well worth the effort I think.
Edited by moderator 11 January 2011 21:29:35(UTC)  | Reason: Not specified
#13 Posted : 21 March 2006 02:45:04(UTC)
PierreGILLARD
You will certainly have no longer water leak in roof !
Once again, I really like the rust on the corrugated steel !
Pierre.
Offline ulf999
#14 Posted : 21 March 2006 23:30:31(UTC)
ulf999
Thanks Pierre! Smile
Offline jerdenberg
#15 Posted : 02 April 2006 00:12:24(UTC)
jerdenberg
Hi Ulf,
A colleague mine owner of yours appears in the May issue of Model Railroader. I prefer your version of the weathering.
Do you have access to MR or are you interested in a scan?
Jeroen
Offline ulf999
#16 Posted : 02 April 2006 19:55:52(UTC)
ulf999
I subscribe Smile. Thanks Jeroen!
Offline steamfriend
#17 Posted : 03 April 2006 00:44:43(UTC)
steamfriend
Nice work Ulf ! Loved your interest in the details like the filling of the roof gap - I do not know the Humbrol filler. Is it like the Tamiya body putty ? Good result anyway.
I'm also interested in your rust weathering ! What paint do you use, and what procedure ? Looks very realistic ! Congratulations!
Bob
#18 Posted : 03 April 2006 03:55:25(UTC)
PierreGILLARD
[size=1" face="Verdana" id="quote]quote:Originally posted by steamfriend
<br />Nice work Ulf ! Loved your interest in the details like the filling of the roof gap - I do not know the Humbrol filler. Is it like the Tamiya body putty ? Good result anyway.
(...) Bob
I use the Tamiya putty. Two applications are usually needed to have a flat surface. Is it the same with the Humbrol putty, Ulf ?
Pierre.
Offline ulf999
#19 Posted : 03 April 2006 12:09:47(UTC)
ulf999
For these gaps it was enough with one 'coat'. I use a painters spatula to apply just in the gap (too much filler and it starts to eat away the plastic...). When it's dry I use a fine sand paper. A second application would have made it very smooth, but I want it to look rust attacked Smile
I use Polly Scale 'rust'. The rust is applied normally and randomly. After the rust is applied I add water to thin it out.
I tried dry brushing at first, but it didn't get into the 'crevaces' the way I wanted...
After the rust is in place, I add a wash of flat black (90% water).
Offline steamfriend
#20 Posted : 04 April 2006 01:43:15(UTC)
steamfriend
Sorry for my ignorance, Ulf, but Polly scale rust, is that a powder? From your description it seems to be..[:I]
Thanks again !
Bob
#21 Posted : 04 April 2006 04:53:18(UTC)
PierreGILLARD
<br />Sorry for my ignorance, Ulf, but Polly scale rust, is that a powder? From your description it seems to be..[:I]
Thanks again !
Bob
It is an acrylic paint produced by Floquil under the Poly Scale brand (# 414323).
If you don't like acrylics, Humbrol # 113 also gives excellent results.
Pierre.
Offline ulf999
#22 Posted : 05 April 2006 22:21:43(UTC)
ulf999
Slack bin built.
How will it look?
Big foot print!
Now all I have to do is build the landscape for it...
#23 Posted : 06 April 2006 02:42:01(UTC)
PierreGILLARD
It is really a huge facility !
Excellent job, Ulf.
Pierre.
Offline HueyCE
#24 Posted : 06 April 2006 05:28:28(UTC)
HueyCE
That looks really nice.
Ira
#25 Posted : 11 April 2006 04:31:34(UTC)
PierreGILLARD
An actual structure that could maybe fit your layout, Ulf : http://www.railpictures..../viewphoto.php?id=140106
Pierre.
Offline pat
#26 Posted : 11 April 2006 04:39:07(UTC)
pat
Ulf,great work love the weathering[:p][:p][:p]
worse things happen at sea
Offline ulf999
#27 Posted : 11 April 2006 12:28:04(UTC)
ulf999
<br />An actual structure that could maybe fit your layout, Ulf : http://www.railpictures..../viewphoto.php?id=140106
Pierre.
Yes Pierre!
I believe that Walther's has something similar? would be great to have that one too Smile
Offline ulf999
#28 Posted : 11 April 2006 12:30:10(UTC)
ulf999
[size=1" face="Verdana" id="quote]quote:Originally posted by pat
<br />Ulf,great work love the weathering[:p][:p][:p]
Thanks Pat Smile
#29 Posted : 19 April 2006 03:24:01(UTC)
PierreGILLARD
[size=1" face="Verdana" id="quote]quote:Originally posted by ulf999
Pierre.
Yes Pierre!
... And another one here : http://www.railpictures..../viewphoto.php?id=141204
Pierre.
#30 Posted : 19 April 2006 22:51:33(UTC)
Ulf: Again, excellent job - congratulations [:p] !!! If I only had space ...
Offline Steven86
#31 Posted : 04 May 2006 01:53:12(UTC)
Steven86
Smile Excellent work, Ulf. Very nice weathering of the roofs. Subtle rusting. You made it look ten times better than Walther's picture wink
Way to go. I cannot wait to seen the scenery which will accompany this jewel.
Offline ulf999
#32 Posted : 26 May 2006 09:38:12(UTC)
ulf999
A thread with more on this structure!
http://www.trains.com/co...topic.asp?TOPIC_ID=65439
#33 Posted : 07 July 2006 02:40:51(UTC)
PierreGILLARD
For you, Ulf ! A picture of a mining structure in Quebec : http://www.railpictures..../viewphoto.php?id=150313
Pierre.
Offline viragoLDR
#34 Posted : 07 July 2006 12:15:30(UTC)
viragoLDR
Ulf, where do you get all those cool paints from? I've been looking around in Norway, but the only reasonable supply of acrylics I can come across (for plastic building kits that is), is the Tamiya series, and they lack quite a few colors I want/need.
Also, where'd you get that Humbrol model filler? Just straight from the US, or is there some cool store in Sweden that has all that? ;)
- Martijn
Offline ulf999
#35 Posted : 07 July 2006 14:52:22(UTC)
ulf999
<br />For you, Ulf ! A picture of a mining structure in Quebec : http://www.railpictures..../viewphoto.php?id=150313
Pierre.
Thanks biggrin
Offline ulf999
#36 Posted : 07 July 2006 14:55:00(UTC)
ulf999
Martijn,
I got the paint and filler from a local store in Stockholm,
http://www.mjhobby.se/
/Ulf
Offline viragoLDR
#37 Posted : 07 July 2006 15:16:39(UTC)
viragoLDR
Okay, thanks, will need to have a look at that, looking for some very specific colors though, will be hard to find ;)
- Martijn
Offline dk4000
#38 Posted : 14 July 2007 03:23:27(UTC)
dk4000
Views messages in topic : 21
Thats one empressive structure. Seems like the height of C-rails does not pose a problem. Great weathering.
Unfortunatly my layout does not hold space for such a large building, Howerver plans for a scratch built, size adjusted "look alike" is in the planning. Looking forward to see yours in situ at your layout.
DK4000
Offline mj
#39 Posted : 17 July 2007 02:48:53(UTC)
mj
Ulf, as usual you've done an excellent work! Smile
Magnus
Offline dk4000
#40 Posted : 20 July 2007 05:31:43(UTC)
dk4000
Just ordered the new river mining company structure knowing theres no room for it on the layout. However, theres a cure for that.
After a bit of surgery, the kit will hopefully fit like a glove in a corner of my layout. I just love the things that you can find on the internet! Smile
http://trains.com/mrr/default.aspx?c=a&id=1206
Progress on the kitbashing can be found on my webpage when the kit arrives next month.
DK4000
#41 Posted : 20 July 2007 06:42:55(UTC)
great! its a monster building !
Offline ulf999
#42 Posted : 20 July 2007 10:57:09(UTC)
ulf999
yup. quite big Smile. Go for it dk4000!
This page was generated in 0.838 seconds.
