Offline sebastian
#1 Posted : 29 July 2010 19:45:18(UTC)
sebastian
Hi guys,
I cannot hold the desire at the gates any longer. Its charming looks have worked their magic spell on my weak mind. Wub I am looking to add a Swiss crocodile in Era III to my collection. And so the quest begins.
I have been looking at one with mfx and full sound options. The only two that have both, mfx and full sound, are 39562 (brown) and 39563 (green). Personally, I would go for 39563 but this is just what I can tell from the pictures seen on the Internet. I haven’t actually seen a crocodile in real life. I am sure they are imposing on the layout.
Now, from your experience are these ones worth it? Are there issues with them? They seem to be pretty big locomotives, heavy.
Another thing is, I have tried to find Swiss freight cars in Era III from M, but nothing is available. Would Brawa or Roco be OK to use with a Marklin Loco? I’m sure the couplers need to be changed and if Roco or Brawa are using NEM pockets, than this is solved. How about wheels? Do I need to change the wheels as well – they are just freight cars with no electrical function. Which of the two is better, Brawa or Roco?
Thank you for your support and help.
DRG, DB and SBB
Era II, III and IV
Sincerely,
Sebastian
#2 Posted : 29 July 2010 20:00:34(UTC)
Hi Sebastian,
I have the 39563 and I love it. It's very impressive when moving on the layout, especially through reverse curves.
The sound on this loco is only a whistle. It does not have full operating sounds.
I bought a couple of Swiss freight cars from Lilliput. They work fine on my C-track. I also have some Roco wagons and they work fine too. I have no experience of Hag wagons.
Offline dragos
#3 Posted: : 29 July 2010 20:07:06(UTC)
dragos
Sebastian:
You can use both Brawa and Roco wagons on your layout. But, you might have to change the wheels. Both Brawa and Roco have suitable wheels to go with Märklin. And, as you said, you probably have to change the couplers. Make sure you buy newer wagons with NEM 362-pocket, and you can use Märklins coulplers 7203.
rgards
Björn H
#4 Posted : 29 July 2010 20:17:29(UTC)
I like Crocodilles, too.
Here is one of mine, the 39561:
Good luck with your selection, Sebastian.
#5 Posted : 29 July 2010 20:26:34(UTC)
Sebastian:
I have the 26730 Digital Set with the Crocodile. As the Kroks were used until the late 1960s, you can use any freight car from that period. One of the trains that I remember seeing photos of was the Crocodile pulling hopper cars of the Weiacher company between Eglisau and Zuerich. Coincidentally, those cars were released in a 3-car Set this year (46331). Even though the cars are in their most recent livery and have UIC numbers, they still look pretty much the same as during the 1960s.
Most of the photos that I have of Crocodiles have the lok pulling mixed freight trains. Around that time, containers were just starting to be used and pretty much the only other unit trains would have been car carriers carrying German cars to Italy or Italian cars north to Germany and maybe the Benelux countries. Roco has a model of Swiss car carrier that you could use. Many of the trains hauled by the Crocodile were German or Italian trains running across the Gotthard, so don't limit yourself to only Swiss cars.
You could also look for the following models:
Maerklin
48807 SBB Set 1970s
46132/46134 car carriers
47878 FS Cars
Roco
44119
45942
46832
46842
46899
47500
47501
and so on...
Well inro the 1970s, a few Crocs were used for shunting at the Muttenz marshalling yard. Although the model of this version was only made by Roco, you could use the Maerklin model with a little imagination. This would open up more possibilities for use. You could also recreate one of the trains pulled by the Crocs during the 100th anniversary celebrations of the Gotthard in 1982.
Happy Consist building!
Offline Unholz
#6 Posted : 29 July 2010 21:59:28(UTC)
Unholz
The Marklin model 39563 is a Ce 6/8 III with the road number 14307. This definitely limits a prototypical usage to the era before the year 1956 when these locomotives were re-classified to Be 6/8 III and the whole series received the new road numbers 13301 to 13318.
Thus any kind of freight train behind such a loco must be made up of wagons with two axles (four-axle freight vans were almost inexistant in Switzerland between the 1930's and mid-1950's). And gravel hoppers or wagons with UIC numbering would certainly not look right behind a Ce 6/8 III 14307. ThumbDown
I suggest using wagons from Liliput or Brawa if Marklin does not offer enough typical era III models. You might also want to look out for specialties such as AKU who offers a broad variety of vans suitable for a 1950's freight train ( http://www.aku-modelle.ch ).
Offline gachar001
#7 Posted : 29 July 2010 22:38:14(UTC)
gachar001
India
As ray mentioned, the crocs you mantioned has only a whistle. I was in the process fo converting mine to full sound with a Loksound MFX decoder but found a short in one of the circuit boards. Poor loco has been sitting dismantled for many months now. I know where the short is but don't know how to fix it Crying
Gautham
Atlanta, GA USA
#8 Posted : 29 July 2010 23:41:21(UTC)
Stefan:
Thanks for the precise information. I was not aware that the model was a Ce 6/6II and not the renumbered Be 6/8III. As I already have a Crocodile in my collection, I have not paid much attention to more recent releases. My forte is post-1968.
Dealers like Roundhouse.ch have a pretty complete list of loks, cars, coaches from many manufacturers under HO Scale. You will be able to find the major brands as well as Friho, Aku and other small producers. ACME has released a number of FS cars that could be found in Switzerland as well. Once you have found a model that interests you, you may have to do an internet search to find that model at a dealer or on eBay or similar.
You could also look into the cars from the Maerklin Swiss Era III Start Sets that have been released over the past few years.
If you were interested in the more recent Be 6/8III to run with 1960s cars, you may wish to consider the 39560 if you can find it or the Roco model.
#9 Posted : 30 July 2010 01:05:04(UTC)
I presume it's just a typo.
The Ce 6/8 III later became Be 6/8 III when the permitted maximum speed was increased (Märklin H0 model available).
The Ce 6/8 II later became Be 6/8 II for the same reason (Roco H0 and Märklin I models available).
De 6/6 is the Seetal crocodile.
#10 Posted : 30 July 2010 03:22:15(UTC)
I
(Here's the missing I from the Ce 6/8, making it a Ce 6/8III.) Thank to Tom for pointing out the omission.
Offline sebastian
#11 Posted : 30 July 2010 05:46:09(UTC)
sebastian
Thanks so much guys. A lot of information. I asked my dealer about the 39563 and he said the loco in question has been on backorder with Marklin for months. Confused
I will check eurorailhobbies to see what kind of freight cars do they have from the ones mentioned in your replies.
Certainly, this loco will make a nice addition.
Again, thank you so much for all your help. ThumpUp ThumpUp ThumpUp
DRG, DB and SBB
Era II, III and IV
Sincerely,
Sebastian
Offline TimR
#12 Posted : 30 July 2010 06:10:19(UTC)
TimR
Indonesia
39563 was released late November-09, I think.. but then sold out at around Christmas...
Have been out of stock ever since.
(thanks to excellent demand forecasting from Marklin - with second batch of production obviously planned to be restarted only months after the first batch was completed)
Didn't got the chance to order it then...
Now I'm still waiting for the light turn green again before placing my order.... my guess is November-2010.
Now collecting C-Sine models.
Offline Unholz
#13 Posted : 30 July 2010 09:01:16(UTC)
Unholz
It doesn't seem to be sold out in Switzerland, see for instance here:
http://www.suter-meggen....klin/sortiment/39563.htm
#14 Posted : 03 August 2010 01:44:48(UTC)
Sebastian,
maybe these cars would go with the croc?
http://cgi.ebay.com/Mark...3cafa165af#ht_500wt_1154
Offline Jeremy Palmer
#15 Posted : 24 August 2010 17:39:52(UTC)
Jeremy Palmer
Barbados
Hello Sebastian,
Be warned that when these Krocs get a hold of you they do not let go.
Will at Modellbahn has a few on his site. It is well documented in the forum that he is a quality gent to deal with.
He also has some wagons that may be suitable. He also may be able to find you a set (26730) like Mike's, add the wagons
it comes with, well it is a very decent value. I found the Delta 28730 and had it converted to digital.
Alternatively you might not want to visit his site, it can be quite expensiveThumpUp ThumpUp .
Stefan thanks for the note ref the wagons, that was very interesting.
Jeremy.
Jeremy.
Offline eduard71
#16 Posted : 24 August 2010 19:27:57(UTC)
eduard71
Chile
Sebastian,
As soon as you get one you will want more.... here an example of my collection:
Regards BigGrin
Eduardo Palacios
#17 Posted : 24 August 2010 23:58:08(UTC)
Nice, Eduardo.
#18 Posted : 25 August 2010 04:35:24(UTC)
Here are my 2 Crocodiles
This is the 3300, from the 3300 125 year anniversary set (I don't have the Gator from this set).......
....and its big sister, the 39560.
According to Stephan's info, 3300 is the later era IV loco - Be 6/8 III, and 39560 is the earlier era III loco, Ce 6/8 III.
I too would like to get a 39563, to match 39560 in a double headed train.
As per my picture of 39560, it seems that loco may be of the earlier Be 6/8 III series - 39560 has road number 14310, 39563 has road number 14307.
Edited by moderator 11 January 2011 12:07:37(UTC)  | Reason: Not specified
This page was generated in 0.596 seconds.
