Offline applor
#1 Posted : 02 August 2010 08:54:46(UTC)
applor
Hello everyone!
So I've got a 3-stall engine shed which has the walls erected but no roof. I want to expand it with some more engine sheds so I need to remove one of the walls.
What is the best way to do it?
Thanks!
#2 Posted : 02 August 2010 10:26:41(UTC)
Hi Eric,
Having bashed many plastic kits and plastic buildings, the best way is to simply prise them apart. Very often, if the glue was used sparingly, it will make a surpprisingly clean break along the original divides.
You can always soften the joint first with some of the wife's or daughter's nail polish remover, or some liquid plastic glue, or solvent like acetone.
#3 Posted : 02 August 2010 13:15:14(UTC)
As Kimball says you can usually just prise it apart. I have also used a Dremel with the cutting disc attached.
dave
Offline obxbill
#4 Posted : 03 August 2010 02:50:42(UTC)
obxbill
I have found that if you stick them in the freezer for a bit, the glue joint will break easier. I've used this for dismantling old car models.
Bill
Offline muzza
#5 Posted : 03 August 2010 06:22:05(UTC)
muzza
Bill
Good simple tip Bill . ThanksThumpUp
Murray
Offline applor
#6 Posted : 03 August 2010 09:42:45(UTC)
applor
Thanks for the advice!
This page was generated in 0.452 seconds.
