#1 Posted : 14 May 2010 07:45:52(UTC)
A long time ago, I promised that I would post these comparative photos of the Maerklin and Hag Re 6/6 Loks.
Unfortunately, my Maerklin Re 6/6 was slightly damaged and must be returned. I did manage to take a few photos while I was inspecting it.
Here is the Maerklin 37320 alongside the Roco 69730 and the Hag 205:
If you compare the three models, you can see how each one has it's better and poorer features.
The Roco model clearly has the most detailed pantographs as well as being the only model with raised lettering and city crest. I am also going to give the Roco model points for the Swiss Crest on the front.
The Hag and Roco models have separately applied windshield wipers.
The Hag model's Swiss Crest looks like Chrome, but I don't like the little indent in the housing where the crest is inserted. Both Roco and Maerklin look more like the prototype in this regard.
The Roco model is the only one to have the white stripe extending fully around the locomotive body. This does not extend past the start of the footboard on the Maerklin and Hag models. Unfortunately, the footboard is a little too wide on the Roco model, so this kind of cancels out the advantage.
The Maerklin model seemed to be the heaviest of the three models. I did not have a chance to weigh them.
The Roco model has the slider mounted on the intermediate bogie, which allows for the outer bogies to be powered by cardan shaft. Both the Maerklin and Hag models have traditional motors, where the front bogie has the slider and the rear bogie has the motor block.
I did notice that the Maerklin lok is reversed when compared to the Hag Lok, in terms that the slider is on the bogie which is in front when the SBB FFS side of the lok is visible (Lok heading to the right). The Hag model has the slider on the opposite end of the lok, so that the SBB CFF side is showing. Normally, this is considered Cab Nr 1. You can also notice this difference by looking at the position of the air blast circuit breaker and the layout on the roof.
The Hag model has the best lighting. The light channels are milled so that there is a real headlights effect. Unfortunately, the Hag lok does have a problem with light leaking through the frame around the motor bogie. This problem can be solved with a little electrical tape or other masking agent.
The Roco lok has good lighting, but not as focused as the Hag model. On the red model, the lighting glowed through the locomotive shell, which was not satisfactory at all. This is a simple problem that could have been solved by moulding the housing in red instead of neutral plastic.ThumbDown
The Roco and Hag models have a driver in Cab Nr 1. All three models have detailed cabs.
None of the models have true close coupling. The Hag model (original) has a metal hook, which IMHO works well combined with my trains. The Roco model came with a standard Roco hook and loop. I have installed a Hag NEM hook, which works pretty well. The Maerklin lok comes standard with a Maerklin 7203 close coupler head.
I installed an ESU sound decoder in the Roco lok. The speaker is sitting on top of one of the bogies. The Hag has no sound. The Maerklin lok has blower and horn sounds. I noticed that the horn was set for continuous blast and not for single toot when F3 is pressed. I wonder if this can be corrected with a Lokprogrammer as I do not have a MS or CS. The Roco has the best selection of sounds, as the decoder can be bridged over two Motorola addresses, enabling additional sound options.
It has already been discussed in other posts that the positioning of the lok number and the crest is slightly off prototype on the Maerklin lok. The Hag lok has them in the correct position.
I am waiting for my 37321 Re 620. I have not yet decided whether I will run the 37320 as an Re 10/10 or operate the loks separately. I may choose to run the 37321 with the Re 4/4II from the 29859 (11376) and use the Re 6/6 with a 1980s/1990s Intercity or Eurocity as my Hag lok is analog and not digital.
In any case, my 37321 should arrive any day now and the 37320 has to go back to the dealer to be repaired/replaced.
In the meantime, enjoy these pics and this short review of some of the aspects of each model.
Oh, and for those who are curious, the photo in the background is a photo of the TEE Roland pulled by a Re 4/4II in the TEE livery and is in a SLM (Schweizer Lokomotiven und Maschinenfabrik) Flyer that I picked up in Switzerland as a child. I presume this is a bridge over either the Aare or the Reuss on the route between Basel and Luzern.
Offline TimR
#2 Posted : 14 May 2010 08:42:32(UTC)
TimR
Indonesia
Comparison is very well written, Mike..
How do you write the drive qualities of each lok?
Which one do you think drives better?
(Of course, the HAG one as you say is analog, but still..)
I don't think you can reprogram the sound on the Marklin lok. The Re6/6 got a sound module v2, if I'm not mistaken, so I don't think a Lokprogrammer can rewrite the sound file.
In any case, if the Re6/6 got a full sound decoder, the Marklin version is not programmable either as it is write protected.
To upgrade the sounds, might as well get an ESU Loksound decoder to match your Roco.
Now collecting C-Sine models.
Offline Armando
#3 Posted : 14 May 2010 17:11:52(UTC)
Armando
Mike,
What an excellent writer you are!
I've been holding off purchasing this Märklin model until I could read more comments. However, I would like to see it in red livery instead.
According to what you may have researched, was it ever prototypically possible to use two Re 6/6 or one Re 6/6 and one Ae 6/6 for tandem operation? Were the Re 6/6 exclusively used in combination with Re 4/4, sunch as in the Märklin model?
Armando García
Offline Unholz
#4 Posted : 14 May 2010 20:19:08(UTC)
Unholz
Armando, Ae 6/6 are not equipped for "real" tandem operation (= multi unit operation by one single driver). Two Re 6/6 in tandem mode are technically possible, but one does not see this too often in reality. Re 6/6 heading a train alone are very frequent.
Offline Rinus
#5 Posted : 16 May 2010 14:15:51(UTC)
Rinus
Quite curious about a comparison between the driving capabilities as well!
#6 Posted : 16 May 2010 15:34:08(UTC)
Yep. Which drives the best. I tend to go for good driving then look at the detail. I probably would not buy the Roco as it is plastic and light coming through the shell is poor.
dave
#7 Posted : 16 May 2010 21:14:30(UTC)
David,
I did report that the Roco lok did have a problem with light shining through the shell. This referred only to the red models (63/699731 and 63/69736) and not to the green models (63/69730/33/35). The difference between these models is that Roco moulded the green loks out of green dyed plastic while the red ones were moulded from neutral (opaque plastic) which was then painted red. The result is that the paint was not sufficient to block out the light source underneath.
This is another one of those flaws that could easily have been avoided if they had taken more care in the planning, development and quality control in production. I don't think that adding red dye to a mould would substantially increase the cost.
It is interesting to note that after having a similar problem with the 63/69841 Re 4/4II that the problem was corrected on the 63/69845 model with rectangular headlights, but the problem reappeared with the next year's 63/69736 Re 6/6. I am waiting to see if the problem exists on the Re 10/10 Set from Roco, as I am very interested in the Re 4/4III from that Set.
As far as driving quality, the Hag probably has the best motor. The Maerklin model has the same motor as the Re 4/4IIs, which was Maerklin's standard motor type for years. The Roco model has a centre mounted motor with cardan shafts driving the outer bogies, which helps to give this model traction as well.
If I was to run them head to head, I would think that the Hag and Maerklin loks would probably either end up pushing the Roco model backwards. The Hag lok would triumph over the Maerklin lok.
As I stated in my review that started this topic, each of these loks has some aspects that are far better than the others and each of them has it's weak points as well.
I have several of the Hag loks, at least three of the Roco ones, and am waiting for my second one from Maerklin.
I am hoping that Maerklin releases the model in red next year, because I do not have a digital version of this lok in red (having returned the Roco version to the dealer).
#8 Posted : 17 May 2010 01:04:35(UTC)
Thanks Mike. Some black paint on the inside of the red Roco would I expect solve the problem but then again why should this be necessary. With my locos I find that there is little to choose between Marklin and HAG as to which runs best with the Roco coming third. For detail I have always liked Roco (not necessarily Swiss) but I dont like my steamers being pushed by a tender. The HAG motor for me is reliable and smooth although the way it sits on the chassis does not quite feel right but in practice works OK.
I would like to see Marklin increase their Swiss Locos and rolling stock as the better price (against the HAG)would be my choice for value.
dave
#9 Posted : 17 May 2010 01:49:40(UTC)
Thanks for the report Mike. Methinks I should get myself a Re 10/10 set.
#10 Posted : 29 May 2010 01:39:49(UTC)
Thought I would add a Set of photos of the 37321 Re 620 in comparison to the Hag 203 Hochdorf Lok:
Maerklin 37321
Hag 203 Cargo
Hag vs Maerklin
The Hag lok has standard light bulbs with milled light channels, which provides a nice illumination of the track in the dark.
The Maerklin lok has brighter "Bright White" LEDs and high beams, but the lamps are more diffuse.
I like the sound of the Hag lok's motor better than the Maerklin one.
It also seems smoother running than the Maerklin lok. I have not as yet inspected the settings on the decoder of the 37321
Maerklin lok has the separately applied footsteps for the door entries, which is missing on the Hag model.
The Maerklin model has the UIC handrail that attaches to the footboard. The Hag model has this detail incorrectly mounted to the lok body, although it is hard to notice the difference at eye level.
The Cargo inscriptions and the crests, etc seem to be prototypically correct on both models.
The Maerklin model does not have a problem with light seeping out next to the motor block, which has been a problem with Hag models.
What I did notice is that the Maerklin model is inverted vis-a-vis the Hag and Roco models. On the Roco and Hag models, the driver is in Cab #1, which is located to the right of the lok side lettered SBB CFF or in the case of the Cargo loks, on the side with the round tanks between the bogies. The Maerklin model has the slider under the opposite cab. This can also be seen by looking at the roof arrangement when comparing the models.
I noticed that the details adjacent to the driver's door are correct on the Maerklin and Roco models while the Hag model has the footplate extending all the way back to the driver's door and thus cutting through the socket. I had not noticed this discrepancy on the Hag model until today. I guess I'm not as good a nitpicker as some might think.
Altogether, Maerklin has produced a model that is as good as their Re 4/4II. It will look very nice on any layout with a Swiss or generic European theme.
The blower and the horn are the only sounds available as delivered. Both sounds are on loop and the button must be pressed a second time to stop the sound. Apparently this can be switched to momentary when using the CS2.
I most likely will use the 37321 Re 620 Cargo as part of a Re 10/10 combination and use the Re 6/6 from the 37320 to pull a 1980s/early 1990s IC/EC with either DB or Italian coaches or maybe even some EWIV coaches in the original green/stone gray livery.
I may have to swap the shells so that the 37321 Re 620 inherits the chassis (motor and decoder) from the 37320 Re 10/10 Set.
FYI For those interested, the train in the background is my prized Lemaco RBe 540 and matching RailTop BDt.
Edited by user 29 May 2010 05:23:35(UTC)  | Reason: Not specified
Offline bmcrae
#11 Posted : 29 May 2010 21:45:43(UTC)
bmcrae
Thanks for the comparison Mike. Great pics!! ThumpUp Drool
Offline Hemmerich
#12 Posted : 31 May 2010 02:18:27(UTC)
Hemmerich
Whether the slider is located under bogie 1 or 2 is meaningless; there is no rule anyways. The only thing important is that the Märklin models correctly match the prototype equipment arrangement on driver cabin sides 1 vs. 2.
Nothing is mentioned in this report about the incorrect handrails also on the HAG Re6/6 models; although this "important detail" was a matter of discussion already in the past regarding the Ae6/6 and Re4/4-II.
Wrong. The horn is already factory configured as momentary switched, it is just not a single shot signal. It's the 6021 (and alike old controllers) which is unable to handle momentary switching like a MS or CS do.
Attempting to do that shows that one hasn't understood the difference between the two models and implications of such a change.
PS: I've as well Re6/6 models from those suppliers and my evaluations are quite different; in particular since I evaluate my models primarily by their technical features and performance rather than such minor optic stuff like UIC connectors or Swiss crest shape, etc.
#13 Posted : 31 May 2010 04:16:08(UTC)
Lutz,
The positioning of the slider can be a big issue with some modellers. I have read postings in the past where modellers prefer to have Cab 1 facing front and some of those and other postings/articles mention that the position of the slider under the front bogie is preferable due to signals and the positioning of stop/power cutoff zones. The fact that the model was conceived in the opposite direction than most existing models is a valid comment that may be of interest to some modellers.
You then go on to quote "I had not noticed this discrepancy on the Hag model until today." without any reference to what I had been referring to, which was the area between the buffers and the driver's door on the right side of the lok and how far the footboard extends along the chassis.
As far as the handrails, If you actually read the entire thread, you would have noticed that the issue of the placement of the UIC handrail was addressed in my review/comments on the 37321. You did misquote from that post, so you should have read the sentence about the UIC handrail.
I have not had the chance to closely examine the motor and frames of both of the Maerklin Re 6/6 as my 37320 had to be returned to Germany because it was damaged during shipping. Most of the detail changes were made to the outer shells (housing), including the additional antennae, headlight configuration, UIC steps and handrails, etc. The chassis should be the same for both variants.
In order to operate the Cargo lok as part of a Re 10/10, I assumed that the chassis (motor/decoder) of the 37320 was better designed for tandem operation, while the 37321 with the budget mfx decoder was better for solo operation. The lok from the 37320 seemed to operate much smoother than the 37321. I have not had the chance to compare the accel/decel and other decoder settings because, as I stated, the 37320 had to be returned for repairs/replacement.
If there were any other changes to the chassis that would make a swap non prototypical, please let me know.
Regarding the horn, you state it is already factory switched to momentary sounding and it is the older controllers that are not equipped to handle that function. This may be true, but as the horn is not constantly in use, it should have been designed to be a short sound for all customers and not just for those with a CS/MS. The older models (Re 4/4I) etc with similar sound module did not have this problem.
Your criteria for evaluating a model are your own. You are free to compare, contrast and evaluate models as you feel. I did not have the equipment to measure traction (pulling power) and other mechanical criteria. I gave a very basic review of those aspects of the model and chose to focus on the visual aspects aka "the look" of the model. The fact that I used different criteria does not take anything away from the review or any of the comments therein. You criticize the criteria that I use to review the loks, state that you use other features to guide your evaluations, but do not contribute any information of significance.
Respectfully,
#14 Posted : 31 May 2010 04:31:34(UTC)
Hemmerich wrote:
.... since I evaluate my models primarily by their technical features and performance rather than such minor optic stuff like UIC connectors or Swiss crest shape, etc.
There's an oxymoron if I ever saw one!
Offline TimR
#15 Posted : 31 May 2010 05:28:24(UTC)
TimR
Indonesia
Lutz,
Here is an idea,
rather than attacking Mike for the criterias he used to review a model (his review, his opinion),
why don't you write your own version of Re6/6 review?
What's the point of telling everyone that your criterias are "technical features" and "performance" when there is no Lutz review to speak of?
Nuff said.
#16 Posted : 31 May 2010 11:14:30(UTC)
Tim, that is a great idea. Lutz can publish his report and then Mike can get even by pulling Lutz's report to pieces.
Sweet revenge.
Now that could be an oxymoron. a bit like fighting for Peace.
NN
#17 Posted : 31 May 2010 14:02:58(UTC)
It would be my view that a model should be as close to the original as possible as this is what we are paying for.
Regarding any technical or running qualities then all models should run and operate well straight from the box as described in the catalogue. The only reason I can see to test anything would be to compare the running of different manufacturers and even then all should run perfectly with perhaps different noise levels. Only in the long term will we know who is best for reliabilty.
With regard to small details I do not have the knowledge of the original to notice differences but Mike has and is able to thne point out errors which are important to collectors but not always to those who just enjoy running the trains.
dave
#18 Posted : 31 May 2010 14:36:22(UTC)
I assure you that it is important and of interest to me, as an analog driver and using powerless stop-sections in front of signals.
Mike c´s report was interesting to read. But your comments seems more like going after the original writer, rather than providing additional information...
I tend to agree with Henrik's assessment. Lutz, once again you are starting to sail too close to the edge with your comments. Once again, you are asked to desist from trouble making within the forum./DB 2300 31052010
Offline jeehring
#19 Posted : 31 May 2010 20:54:26(UTC)
jeehring
Always same contributions circulating the same message...
...same biased & patchy comparisons under cover of "just an enthusiast's review"...LOL
Marketing departments today takes a great interest in the value of "internet-image " of a brand ......Laugh
ON the first post of this topic , the author said :
"I installed an ESU decoder on Roco model..(...)....
...Roco model has the best selection of sounds....(...)...
So why did he installed an ESU locksound decoder ?
...or is he talking about the sound of ESU decoders at 120 Euro each ?
no report about which one has plastic body, which one has metal body ...
....etc...
#20 Posted : 31 May 2010 21:20:48(UTC)
David Dewar wrote:
With regard to small details I do not have the knowledge of the original to notice differences but Mike has and is able to then point out errors which are important to collectors but not always to those who just enjoy running the trains.
dave
I would hope that what I am doing is not only pointing out "errors" but more illustrating the strong and weak points of those models, both aesthetical and functonal and providing as much information as possible about that model.
I did not elaborate on the mechanical comparison of the models, other than to describe the motor type and general characteristics. I did not have the time to provide specific testing of pulling power, either in force (kn) or by testing to see how many cars/coaches could be pulled on a flat surface or on any incline. I provided general information about motor type.
The issue with the Re 620 (6/6) regarding the positioning of the slider is an interesting one. Although there is, as Lutz stated, no specific rule, most SBB models over the years have had the model designed so that when the slider bogie is at the front, the SBB CFF has been on the right side of the lok. This goes as far back as the Maerklin 3050 Ae 6/6. The earlier 3014/RET had a mid mounted slider, so it would not technically count. Since then, the Hag Re 4/4 (160), Re 6/6 (200) and also the various Re 4/4I, Re 4/4II and Re 6/6 have all followed this unwritten standard. The Ae 6/6 actually is a special case, because many of the loks were actually labelled SBB FFS on both sides or SBB CFF on both sides, depending on the canton the lok was named for. With the so-called "City" loks, the inscription depended on where the lok was based.
The fact that Maerklin's model was designed with the SBB FFS on the right does not in any way take away from it's operability. It will function on any layout and will not have any problems with "stop" zones and other signalling related issues. It does remain that the lok will be operating with what normally is interpreted as Cab 2 forward. This, however, should not stop anybody from buying this model, as these (and most other) loks in Europe are designed with two cabs and can be operated in either direction. Thus, the visual appearance in prototype can be seen daily in operation, and is not wrong for a model, but simply different from other manufacturers' models.
In some aspects, the Maerklin model is better than the Roco and Hag models. In other criteria, one of the other models is better. I have all three models in my collection, in many cases more than just one variant, and I like each one for what they have to offer.
I hope that my comments are read for the positive and negative aspects and not just to find the "errors" in the models. Hopefully, this information is equally of use to those who are collectors and those who like to play with their trains.
#21 Posted : 31 May 2010 21:38:50(UTC)
....etc...
Jeehring,
In response to your comments. I did not think it was necessary to repeat, once again, that Roco models have plastic body, while the Maerklin and Hag models have Die Cast shells. I did mention related details like the raised lettering on the Roco model and so on that might be unknown to modellers.
I did install a ESU Loksound (V3.0) decoder in one of my Roco Re 6/6 as I wanted to replace the OEM (non ESU) decoder that came with that particular model (69730). The other Roco models in my collection have OEM ESU decoders (no sound). When I stated that the Roco model has the best selection of sound, I meant that the ESU decoder. I should have added that the Roco model comes standard without a sound decoder. The Hag model is available with factory installed sound (for a surcharge) and the Maerklin model comes standard with a basic sound module.
In my posting, I was trying to keep it concise by not repeating details that may have been addressed in other threads about the 37321 or 37320:
https://www.marklin-user...aspx?g=posts&t=15658
https://www.marklin-user...aspx?g=posts&t=15494
Specifically, here is the original post where I gave a quick comparison of the models (based on photos). You will find that details like the plastic body (Roco), etc were addressed here:
mike c wrote:
I have not yet received my 37320, but am basing my initial evaluation on the photos supplied by Alberto (above):
Hag:
+ Great motor and pulling power
+ Metal body
+ Spring loaded buffers
+ Separately applied wipers
+ Best reproduction of the front windows (main)
+ So far only producer with accurate depiction of model with A/C panel
+ Closed snowplough available as accessory
- Swiss Crest is a little oversized
- Light shines through bogie opening
- Body moulding line visible on some models*
Roco:
+ Very detailed plastic body with raised lettering
+ Swiss Crest is correct
+ Very accurate Swiss Pantographs
+ Best overall reproduction of the front windows
+ Best reproduction of the hoses/connections on the lok front/Closed plough
+ Very smooth operation
- Light can shine through body shell of red locomotives
- Middle bogie lacks weight and can derail on switches
- End footboards extend too far out on the sides
Maerklin:
+ Metal body
+ First model with bright white LEDs/Cab lighting
+/- Swiss Crest on front is moulded into the lok shell, but the dimensions are correct.
+/- Closed front piece with hoses included but may interfere with the bogies
- City Crest and lok number on side too high
- Roof adjacent to vents looks different than prototype.
Common:
As far as I can tell, none of these model come equipped with true close couplings. All three come with coupler shafts or couplings mounted directly on the bogie.
The Hag Re 6/6 probably looks best when combined with a Hag Re 4/4II/Re 4/4III. The same can respectively be said for the Roco model and likely for the Maerklin model as well.
As far as traction, the model Hag probably has the best motor. Maerklin's traditional motor has proved itself to be reliable and the Roco model is the quietest.
CORRECTION: The Roco and Maerklin models come with 3 white/1 white Swiss lighting. The Hag model at present has 3 white headlights at the front of the lok (running). New editions of the Hag model should have LED lighting and possibly the Swiss taillight as well.
None of the models come with working red lights. Roco has so far had the best imitation of the current rectangular halogen lights.
The Hag and Maerklin models are metal. The Roco model has a metal frame with a plastic body.
All models come with the correct rectangular buffers. Hag's model has spring loaded buffers while the Maerklin and Roco models have fixed plastic buffers.
The main windows look the best on the Hag model. The Roco model has the best overall reproduction of the windows, probably due to the fact that the lok is moulded in plastic. Maerklin still has the brown tinted side windows.
The Roco model has the most accurate pantographs, while the Hag and Maerklin models rely on Sommerfeldt designs that go back to the 1970s. The Sommerfeldt pantos are still way better than the original Maerklin 7219s that came with earlier models with single arm pantos. The Roco pantos cannot be installed on the Hag or Maerklin models without some modifications as the screw mount locations are different.
I guess that in conclusion, the choice of whether you prefer one specific model is up to you. I like certain aspects of each model and because of that, I cannot decide which model I prefer. I do not have any of the red Re 6/6s by Roco due to the glow-through issue and am looking forward to a red model from Maerklin. I have not ordered the 37321 as I already have two Re 620s (Cargo) from Hag. I would hope that Maerklin would go through the Hag catalog or Stefan's website before selecting future coats of arms. There are still some models that have not been made that would probably be big sellers.
As soon as I receive my 37320, I will take some photos of the three models, individually, all together and head to head with each other.
I have not included any of the older Lima models in this comparison, as I do not have any of those models in my collection.
I hope that this clears the issue up.
Offline bmcrae
#22 Posted : 31 May 2010 22:02:25(UTC)
bmcrae
heavy sigh.... Sad
#23 Posted : 01 June 2010 00:03:19(UTC)
I tend to agree with Brian here, we all have different aspects and expectations of this hobby and we are all free to express what we think about it... Unfortunately it sometimes tends to lead into "storm in the waterglass" discussions...
Remember, we all have our different preferences of what makes model railroads fun and worthwhile, and we also have to expect that other members may have other preferences...
I myself think it is great to learn things from the forum. Smile
#24 Posted : 01 June 2010 00:24:21(UTC)
Hi Juhan. Your point that model rail is fun is the part that appears to be missing from many posts and this thread is just going the same as the others with a similar topic. Enjoyment of model rail is to me important and scoring points in threads has no benefit to anybody. I like HAG and Marklin Swiss locos but rarely buy Roco because of the plastic body but I enjoy running all of the models I have.
dave
#25 Posted : 01 June 2010 00:50:42(UTC)
Well, I come from the Flash Dave School of MRR - it's a hobby and is meant to have an element of fun to it. As has been said before, there is room for all types in this hobby, the rivet counters, the non rivet counters, those who are modellers, those who like woodworking, those who write software, those who are into electronics, those who like painting their buildings, and those who don't. That includes Lutz and MikeC and all the rest of us.
Don't forget, the rest of the normal world consider us all to be complete nutters anyway, so it is best that we don't start infighting amongst ourselves.
I've just ordered myself the Marklin Re 10/10 set, these will be my first Ae 6/6 and Re 4/4 II locos, so I'm very much looking forward to getting and enjoying them.
As for Roco, well I only have 1 Roco, my Br 182 Tauras (see piccies in Stephen's 'What locos have you got' thread). It doesn't have any issues with light showing through the plastic shell, it runs very well, and doesn't lose much at all when compared to the Marklin version of the same loco (again piccies of the 2 in Stephen's thread).
#26 Posted : 01 June 2010 01:43:30(UTC)
It saddens me when I try to post what I consider to be material of potential interest to other members only to find myself attacked often without basis.
The end result is that people end up getting turned off by the argument and do not pay attention to the information itself. I sometimes wonder if this is not actual the intention of those who make these attacks.
I have three different Roco Re 6/6, four Hag Re 6/6 (2 Re 620) and now have 2 of the Maerklin models as well.
I enjoy each one as much as the others, and although, like I have said, there are little differences between each model, they all are excellent models in their own right.
Which one you prefer is up to you. It is said that beauty is in the eye of the beholder. This is also true when it comes to model railroading. If you did not buy a Roco or Hag model since those models came out, the Maerklin model is now available and will make a very nice addition to any collection.
Concluding this topic in this manner seems a perfect way to keep the topic from getting too convoluted. Hope you enjoy the photos and the information.
Webmaster, please shut off this topic or limit it to other peoples' evaluation of the models only and delete any non-related postings.
Thank you
#27 Posted : 01 June 2010 03:30:33(UTC)
Topic Locked.
Guest (8)
This page was generated in 0.936 seconds.
