3 Pages123>
#1 Posted : 03 January 2010 15:52:13(UTC)
#2 Posted : 03 January 2010 16:55:22(UTC)
I have heard from Au Pullman and price will be around 450 euro for 4-car set.
Offline mmervine
#3 Posted : 03 January 2010 17:44:26(UTC)
mmervine
Wonder which body style? Atlantique/Reseau/Thalys-1 or POS/Thays-2?
Offline RMW
#4 Posted : 03 January 2010 17:45:37(UTC)
RMW
[size=1" face="Verdana" id="quote]quote:Originally posted by mmervine
<br />Wonder which body style? Atlantique/Reseau/Thalys-1 or POS/Thays-2?
Thalys would be very nice.
RMW
Rensen Modelbaan Wereld - Since 1963
RMW - Website
RMW - YouTube
Offline RMW
#5 Posted : 03 January 2010 18:16:41(UTC)
RMW
See NOW: MÄRKLIN 2010 NEW ITEMS (new link).
RMW
Edited by user 09 January 2010 00:21:51(UTC)  | Reason: Not specified
RMW - Website
RMW - YouTube
Offline mmervine
#6 Posted : 03 January 2010 18:34:30(UTC)
mmervine
TGV POS is good. That means that they can do a Thalys-2 (PBKA) with only a change of paint!
Offline fvri
#7 Posted : 03 January 2010 19:26:31(UTC)
fvri
Yes I would finally be interesting to have a TGV produced by Marklin.
It will certainly be on my list of the ones I would like to have!wink
Kr,
Frank
Offline TimR
#8 Posted : 04 January 2010 03:39:08(UTC)
TimR
Indonesia
<br />TGV POS is good. That means that they can do a Thalys-2 (PBKA) with only a change of paint!
OR
they can as easily do the sole example of the unit owned by SBB/CFF/FFS.
Smile
Now collecting C-Sine models.
Offline mascagni
#9 Posted : 04 January 2010 17:17:11(UTC)
mascagni
I agree that a Märklin TGV would be good. I do want to mention that the 3-rail Mehano TGVs are all very nice as well, and I have the Thalys and the Duplex versions of these. I would welcome comparisons when the new Märklin versions come out!!--MM
Michael Mascagni, Tallahassee
Offline tekin65
#10 Posted : 04 January 2010 17:19:59(UTC)
tekin65
Turkey
[size=1" face="Verdana" id="quote]quote:Originally posted by TimR
<br />they can as easily do the sole example of the unit owned by SBB/CFF/FFS.
Smile
That'd be superb Smile
Do we know if it's going to be metal or plastic?
Cem.
Now all eras but no ICE
#11 Posted : 04 January 2010 21:28:05(UTC)
Here is the first official information from one of the Maerklin distributors (Holland) about the new TGV POS model.
http://www.marklin.nl/nieuws/tres-grande-vitesse
I will wait to see more detailed photos of the actual model, but am pretty sure that it will be nicer than the old Lima, Jouef and Mehano models. Hopefully the model will represent a model that can be found on French, German and Swiss rails, complete with all pantographs and features for those routes.
Offline VT 08.8
#12 Posted : 04 January 2010 22:00:40(UTC)
VT 08.8
Delirium on French Märklin forum :
http://www.3rails-forum.org/portal.htm
Märc
Offline Armando
#13 Posted : 05 January 2010 22:33:57(UTC)
Armando
Well, I only hope that this TGV will INDEED be made to the correct H0 scale (1:87) and won't come with any movable "skirts".
Armando García
#14 Posted : 06 January 2010 00:21:00(UTC)
With the Jacobs Bogies, I doubt that there will be any problem with the connections between coaches. The only possible problem will be between the motor units and the first and last coach, as these are equipped with normal bogies and normal connections on the prototype. How Maerklin will render this is not yet clear. The photo on the Maerklin.nl site does not show much detail in this regard and is only a sample photo.
Offline Davy
#15 Posted : 09 January 2010 02:23:12(UTC)
Davy
My gues they use the same connectors as for the Koploper.
M-track with a CS2.
#16 Posted : 09 January 2010 14:48:29(UTC)
This is clear now. Today I received DER MODELLEISENBAHNER with a Märklin ad for the TGV.
Motor unit and first coach have a fixed connection.
One motor unit has four powered axles (so I presume there are plastic "toothpicks" inside (as John calls them)).
Units come with interior lights.
They don't mention metal (except for the handrails), so I presume TGV has a plastic case.
No word about the motor (but the number 37790 indicates it's not a SDS).
They mention that it's prototypical length.
Offline VT 08.8
#17 Posted : 09 January 2010 18:50:48(UTC)
VT 08.8
Hi Tom,
From an important french dealer 37790 has metal motor and dummy units, a 5 poles motor, and a 12 functions MFX decoder :
http://www.3rails-forum....in-37790-t2980.htm#43596
Märc
Offline Pavle
#18 Posted : 09 January 2010 20:00:51(UTC)
Pavle
I believe the prototype is some 200 meter long, so the full 10-part model in true 1:87 would be about 230 cm! Very nice long train. I want it!
And if they bring the Thalys-version in 2011, I want that too (oh boy, need more budget).
But I guess the model has one motorised unit, correct? Would that mean running in one direction only?
#19 Posted : 09 January 2010 21:01:14(UTC)
No. When running digital you will be able to change the direction.
Just kidding: will also work in analog mode.
Pickup show in the leading motor unit is used - even if it's the dummy unit.
Offline tekin65
#20 Posted : 09 January 2010 21:34:18(UTC)
tekin65
Turkey
Complete train 2.3 meters long and one DCM motor; so plastic body ... not exactly my dream train ... will pass on this one. May buy the SBB version if it ever comes out with a sensible price tag.
Cem.
#21 Posted : 09 January 2010 22:46:23(UTC)
Somebody in France heard from his French dealer that motor units are metal.
I guess DCM is pure speculation now (a DCM loco with 4 powered axles? we ne'er had that from M*).
I presume there'll be a non-DCM non SDS motor in it.
Make your decision when it shows up in M*'s product database or new items brochure. Then there'll be more dealers with pre-order prices, too.
I wait for the Thalys livery (and avoid the toothing problems). Flapper
Offline tekin65
#22 Posted : 09 January 2010 22:50:09(UTC)
tekin65
Turkey
Yes Tom you're right, my fault. Must be Maxxon or something similar.
Cem.
Offline TimR
#23 Posted : 09 January 2010 23:00:20(UTC)
TimR
Indonesia
Considering the price, I think this model will come with the same setup as the cancelled Trix ICE-1.
By "5-pole motor"; it means the new can motor used on recent Trix models or a variant of it; application can also be found on M* 37308/37309.
If this model comes with full sound and interior lighting; wow, what a bargain!
Compare it to the price of the current Marklin ICE-3..
Offline cyberbeast41
#24 Posted : 10 January 2010 12:05:08(UTC)
cyberbeast41
The locomoties are full metal.
Both locomotives will have a motor in them.
And you can already buy them for 360 euro from a famous german seller.
That's a much better price tag than 470 euro.
The sets with two will cost you 104 euro, instead of the hefty 140 euro.
Offline TimR
#25 Posted : 10 January 2010 12:38:02(UTC)
TimR
Indonesia
Rumours have been around for a while now that at least the motor unit will be made of metal; but I'm still a bit skeptical.
Obviously with a high speed train model, design consideration would be prioritized to achieve what the prototype does best; to achieve high speed. So overall, the train needs to be quite lightweight; excepting the end units.
Secondly; as with the ICE models; the TGV will not be expected to haul any significant loads beyond its consist. So a very heavy motor unit (for tractive effort) is not really necessary for decent running..
And of course, there are cost implication to consider. High speed trainset forced buyers to get at least a minimum consist of say, 3 to 5 units in one set. It means price would naturally be quite premium compared to the rest of the range, and metal body would add a lot to that basic price. Look at the current pricing for both ICE3s in Marklin and Trix range.. and they only come with sound modules!
The prices for the TGV we're seeing now simply says something gotta give; between the metal body of the motor unit, MFX Loksound, and interior lighting..
In saying that...
I'd be very happy if the motor unit would indeed come with a metal body..
Hats off for Marklin if they managed to squeeze all the above in this package for the given price..
#26 Posted : 10 January 2010 13:35:57(UTC)
That contradicts the Märklin ad in DER MODELLEISENBAHNER.
They explicitly say that one motor unit is not motorized.
#27 Posted : 11 January 2010 20:55:32(UTC)
cyberbeast41
Yes, you're right. I read it now too. Apperently, the message saying the TGV would have two engines is faulty.
I do wonder if you can ride it both ways then? Isn't it going to derail when the locomotive is pushing and the non-motor locomotive is in front?
Offline TimR
#28 Posted : 11 January 2010 21:35:43(UTC)
TimR
Indonesia
No.
With the ICE models, Marklin usually put a metal ballast on the non-powered motor unit to keep it stable in push-mode. I reckoned this will the same in the new TGV.
I think only M* RAM TEE have a problem with that..
From the latest description, I think it can be concluded that the motor unit is going to be plastic body and metal frame.
Reason is simple; cost..
Having the powered unit in metal and the non-powered one in plastic is no go either -as this would mean that Marklin had to develop two seperate casting for the same motor unit (even more expensive!).
Offline Pavle
#29 Posted : 12 January 2010 02:14:47(UTC)
Pavle
TimR wrote:
No.
Sure about that? ICE has the motorised unit in the middle of the train, so it pushes only 3 or 4 coaches. This TGV will have to push the full 2.30 meter. Does not sound comfortable...
Offline TimR
#30 Posted : 12 January 2010 02:42:29(UTC)
TimR
Indonesia
Hi Peter,
As we know, Marklin had made plenty of screw ups before...
guess we can't really be 100% sure until we see the first test reviews.
If they do manage to make a TGV that derails on push mode, just as well they didn't seem to learn from their previous mistakes.
Right now I'm not overly concern though, but who knows?
Offline RMW
#31 Posted : 14 January 2010 11:36:56(UTC)
RMW
Information of "Oude Station" (Dutch):
37990 TGV POS SNCF 4-delig. Prijs: 469,95
Complete nieuwe constructie in schaal 1:87, 4 delige basisset die uitbreidbaar is met de sets 43420 en 43430 en 43440, 5 polige motor met vliegwiel (= with flywheel), Mfx decoder met volledige sound (= Full Sound), v.v. binnenverlichting (= interior lighting), correcte lichtwisseling met warmwitte LEDs (= warm white LED's), gedeeltelijk in metaal uitgevoerd. Minimale boogstraal 360 mm
RMW
RMW - Website
RMW - YouTube
Offline Steamer01
#32 Posted : 25 January 2010 23:37:21(UTC)
Steamer01
Now it is clear. The body will be made of plastic, but the motor unit will have a heavy weight through metal lay-in units. Märklin has answered the question today. It will be a wonderful model. BigGrin
Steamer 01
CS3 60216 + 8 x 60174 + 1 x 60175
www.rensenmodelbaanwereld.com
Offline old toot
#33 Posted : 26 January 2010 06:43:01(UTC)
old toot
well considering the recently produced swiss mouse has metal body which they were happy to make lets see what they put on show at the show next weekend so presume someone from the net is going to be there and report back.
and all the speculation can be put to rest.
Offline jeehring
#34 Posted : 10 April 2010 16:46:04(UTC)
jeehring
some pictures here ,
scroll down a little, this is a retailer website, update April 10:
http://railway.fr/
#35 Posted : 10 April 2010 17:49:57(UTC)
http://railway.fr/
Roland,
Part of the TGV, this is an interesting website with numberous locos (SNCF Panorama Railcar) and carriages.
Offline jeehring
#36 Posted : 11 April 2010 18:14:27(UTC)
jeehring
http://railway.fr/
Roland,
This retailer is at Lisieux, Normandie about 40 Km east of Caen, he is well known in France. He runs a toy & models shop.
It's OK for people interested in French Railways. If you are not in a hurry he probably can provide many things else .... Each year he is editing his own train shop catalogue ( he sells it)
He is known as an incredible grouch !( which is the reason why he is well known...)
He has a tremendous knowledge of French Railroad and French train model ingeneral. Found of railways, he likes to drive himself some old steamer...
Rarely he also produce limited run of handy craft kits...
Prices are not so competitivebut people appreciate his knowledge about model making ( as usual customer one can get some discount...If he is in a good mood, we can discuss...)
Offline jeehring
#37 Posted : 19 April 2010 02:13:27(UTC)
jeehring
http://railway.fr/
Roland,
I agree about the Panorama Railcar . It will be produced by "Mistral Train" who is a serious manufacturer. (Much more serious than LS Model/LSM).
It's plastic but engraving & moulding are fine. Like Marklin : motorized items are delivered with full digital and interior lighting (factory installed electronics) for 3 rails and 2 rails. They also have good quality motorization (in contrast to LSM).
Have a look on a pre-serial model:
Offline jeehring
#38 Posted : 04 May 2010 17:52:57(UTC)
jeehring
here some pictures of "handmuster"/ prototype only for behaviour & endurance tests (without painting, without all details,) brought to the shop by Marklin sales representative for demo....
http://www.rmfmagazine.c...um/viewtopic.php?id=5645
(scroll down, you'll see it on track. It is said very smooth and the 2 machines at each end quite heavy despite their plastic body...)
#39 Posted : 04 May 2010 19:05:49(UTC)
Thanks for the link.
#40 Posted : 08 May 2010 11:36:36(UTC)
cyberbeast41
Is there a fixed release date for the TGV?
How much do you guys thinks it will be postponed? Until after summer? Just before Christmas?
#41 Posted : 08 May 2010 12:40:54(UTC)
The current release date list (from the Ides of April) lists TGV in June, extension sets in Q3 and Q4.
New list coming around the Ides of May.
April list:
http://mediencms.maerkli...in-Neuheiten_2010-04.pdf
As always: this is the earliest availability - not all orders will be fulfilled with the first batch.
A six-piece train should be there long before Xmas - maybe even the full 10-piece train.
Märklin never makes fixed dates, postponements are quite common.
Offline TimR
#42 Posted : 08 May 2010 17:43:02(UTC)
TimR
Indonesia
It looks very good! ThumpUp
It seems very well detailed at this stage,
the permanent coupling between the motor end and the transition coach seems to be quite nicely done too..
#43 Posted : 10 May 2010 17:52:27(UTC)
Have you check here?
https://www.marklin-user...aspx?g=posts&t=11739
#44 Posted : 12 May 2010 15:11:23(UTC)
cyberbeast41
I have, but there are 30 days in June ;)
I'm on a vacation in June, maybe I can pick it up when I'm back.
#45 Posted : 12 May 2010 21:33:03(UTC)
Update - Marklin TGV delivery is now date back to Q3.
Offline RMW
#46 Posted : 12 May 2010 21:50:36(UTC)
RMW
New pictures ("Es wird bunt") of the TGV, see: Märklin.de.
RMW
RMW - Website
RMW - YouTube
Offline Hemmerich
#47 Posted : 19 May 2010 00:25:54(UTC)
Hemmerich
Edited by user 21 November 2010 01:59:27(UTC)  | Reason: Not specified
#48 Posted : 19 May 2010 02:25:36(UTC)
Hemmerich wrote:
Changed from 30.06. to 01.07. BigGrin
Very Clear Information Lutz, Congratulations. Smile Can you verify the Source. Unsure
#49 Posted : 16 June 2010 22:45:08(UTC)
cyberbeast41
Is there any news on the TGV? I hope the release date hasn't changed?
Hope to get it when I'm back from my trip.
Offline VT 08.8
#50 Posted : 16 June 2010 23:10:34(UTC)
VT 08.8
It will be shown at Paris "Mondial du Modélisme" on june 17-20 :
http://www.mondial-modelisme.com/news.html
Scroll down to Märklin ad Razz
Märk
Märc
3 Pages123>
This page was generated in 1.853 seconds.
