#1 Posted : 14 April 2010 12:11:49(UTC)
Just to record
.. what actually happens when you do what you are not meant to (According to Marketing).
Even if the plugs and Sockets allow it.
Plugging 60651/2 into 60113 (with or without 60653 also plugged)
- Powers Up - Displays "No Master"
Plugging 60653 into 60212
- Powers up - Shows stop and unable to Go
Plugging 60653 into 24088 as Master
- No Power - Screen Blank
Plugging 60653 into 24088 as Slave (With 60651 as Master)
- same as connecting to 60212
In Summary .. No Smoke either.
#2 Posted : 14 April 2010 13:03:58(UTC)
Well done Peter. Make sure your insurance policies are up to date. !!!
David
Offline Hemmerich
#3 Posted : 14 April 2010 21:13:11(UTC)
Hemmerich
Edited by user 21 November 2010 02:10:50(UTC)  | Reason: Not specified
#4 Posted : 14 April 2010 23:55:45(UTC)
Hemmerich wrote:
Try combination #5 (beware of smoke). Wink
Please elaborate...
My prime reason for posting was to test if there were any specific damaging scenarios. If you have one please let everyone know.
I could envision plugging the 60212 into the 60113 - both with power.
What else are you thinking
#5 Posted : 15 April 2010 03:18:18(UTC)
Cryptic Lutz at it again. It is guess the Question & answer time again.
It was peaceful for a few weeks.
NN
#6 Posted : 15 April 2010 03:34:05(UTC)
Probably plugging it in where the Sun don't shine! Scared Scared
Lutz, it would be really nice for the well being of the forum if you would play nicely with the other kids in the sandpit and share your toys like a good boy! If you know something, that in this case, Peter has not covered, then say what it is. We don't need cryptic answers all the time. Otherwise, the other kids get grumpy, and that's when the sand fights start. We moderators should not have to keep nagging on about this, but it seems you keep repeating the same behaviour over and over again.
Offline a245283
#7 Posted : 10 May 2010 23:59:55(UTC)
a245283
can you help me ?
I bought a 60653. can i use 60113, 60653 and 60052 (60VA) together?
Confused
Offline a245283
#8 Posted : 11 May 2010 00:08:37(UTC)
a245283
clapcott wrote:
Just to record
In a RAILWAY TRACK can i use together 24088 (with connected 60052 trasf. and 60652 MS) and 60113 (with connected 60653 NEW MS and 66361 trasf.).
Many thanks
Confused
Offline Darren W
#9 Posted : 11 May 2010 02:44:32(UTC)
Darren W
a245283 wrote:
can you help me ?
Confused
As far as I know the answer is Yes. This should be the correct set up for a 60653 MS2. You could also connect a second 60653 to the 60113.
Cheers...
Darren
Offline Darren W
#10 Posted : 11 May 2010 02:49:28(UTC)
Darren W
a245283 wrote:
clapcott wrote:
Just to record
Many thanks
Confused
I would say NO. The 60652 MS and the 60653 MS2 will both be supplying the track with power and signal and conflict each other. It may also damage something.
You should be able to connect a 60652 MS and a 60653 MS2 to a Central Station 2. This way the CS2 controls the track signal and power and the MS's just act as slave controllers. You want to have only one contoller and properly connected boosters to supply track power. Any other controllers must slave the the main unit.
Darren
#11 Posted : 11 May 2010 11:58:40(UTC)
a245283 wrote:
can you help me ?
Confused
Yes, That's correct.Smile You don't need the 24088 feeder track.
If you have CS2, You don't need the 60113.
Also Welcome to the forum.Smile
This page was generated in 0.749 seconds.
