Offline AlexandrS
#1 Posted : 08 May 2010 00:08:35(UTC)
AlexandrS
Russian Federation
Good Day !
I here have faced a problem.In the description of some Maerklin steam locs I cannot find mentions about minimum radius for operation. The list is from catalogue 2007/2008 :art. 37039 (BR38) , art.37849 (BR50), art.37115 (BR18.1), art.37953 (BR03) ,art.37921 (BR41) , art.37883 (BR44) , art.37151 (BR52), art.37452 (BR45) and so on... So, can I use curved tracks like art.24130 or art.24115 ?
Alexandr
AC/DC Maerklin Central Station® I Reloaded
#2 Posted : 08 May 2010 00:36:59(UTC)
All Märklin locos can run on 360" radius curves (SCNR).
And AFAIK all H0 locos can run on 360 mm radius curves.
There are even smaller radii for M and K track - some big steamers cannot negogiate this small curves. The indication "360 mm" actually means "cannot run on smaller curves".
Offline Ian555
#3 Posted : 08 May 2010 00:46:03(UTC)
Ian555
Hi AlexandrS,
Welcome to the forum. ThumpUp
Ian.
#4 Posted : 08 May 2010 01:35:35(UTC)
Welcome. As Tom says they will all run on radius 1. Where possible I use the widest radius that will fit the layout size as it helps with the running of longer coaches and looks better.
dave
#5 Posted : 08 May 2010 10:40:53(UTC)
Hi Alexandrs
Welcome to the forum.Smile
Offline AlexandrS
#6 Posted : 08 May 2010 16:56:35(UTC)
AlexandrS
Russian Federation
Greetings to all !
With Maerklin steam locos I have understood. But There are other manufacturers like Roco , Brawa , Fleischmann which make AC-models. Brawa says that all their locos can move on 360" curves.From Roco and Fleischmann I haven't informations.
Alexandr
Offline pa-pauls
#7 Posted : 08 May 2010 17:01:24(UTC)
pa-pauls
Hello AlexandrS and welcome to the forum BigGrin
I have never discovered any problems with any locomotive's on a 360" curves ThumpUp
I have the loooong SBB Ae 8/14 elektro locomotive and even that model runs nice on 360" curves...
Pål Paulsen
Offline pab
#8 Posted : 08 May 2010 17:03:12(UTC)
pab
Hi Alexandr
As said most Märklin locomotives, coaches and wagons will run on 36 mm radius curves (or larger).
Some extra parts, like rod protectors on steamlocomotives, can only be used on 50mm radius curves.
Some locs will not negotiate a left 36 mm curve, immidiately follewed by a right 36 mm curve
Of course you have to realise that long locomotives, coaches or wagons will hang over in the curves, which isn't not so nice to look at.
Depending on your available space, I would say, the wider the curves the better.
Offline rugauger
#9 Posted : 08 May 2010 19:02:47(UTC)
rugauger
pab wrote:
Hi Alexandr
Some locs will not negotiate a left 36 mm curve, immidiately follewed by a right 36 mm curve ...
Let's put it like this: all Märklin rolling stock is designed to be able to run on 360mm radius curves. The important word here is "designed to" - as Piet very rightly points out, intention and reality can be two different things. Every layout has its own particular challenges in this area, and only because something is supposed to work on paper doesn't necessarily mean that it will in practice. The example of the opposing turns is a case in point (although I would expect the steamers mentioned in Alexandr's post to be OK).
Richard
#10 Posted : 08 May 2010 22:05:28(UTC)
All Roco locos can take 360" curves. (SCNR)
But some require 420 mm or larger radii (FYI: 1" = 25.4 mm; 360" is about C track R9).
This information is in the leaflet that comes with the loco, but not in the catalogue. But AFAIK all Roco locos can run on Märklin R2 - and most of them (except some large steamers) can run on 360 mm.
I have some Fleischmann steamers and they all run fine on R2 (never tested on R1, R2 is the smallest radius I use (except on some sidings)).
I don't recall seeing radius information in their leaflets.
#11 Posted : 08 May 2010 22:36:28(UTC)
Any min radius 360" locomotives will not run on M-tracks 5120 and K-tracks 2110/2210 curved.
Some small Tank/diesel locos model date up to 1990s can run less that 360" radius.
Offline AlexandrS
#12 Posted : 08 May 2010 23:10:57(UTC)
AlexandrS
Russian Federation
Thanks to Tom ,
certainly, more correctly 360" = 360mm or Maerklin R1 curved track.I have forgotten about a sign inch or " .
Alexandr
#13 Posted : 09 May 2010 00:52:01(UTC)
Brawa longer coaches fitted with sliders for lighting are not great on R1. As mentioned if you have space use the largest radius that will fit your layout. If you can only manage R1 and stick with Marklin then there should not be any major problems (avoiding S curves)
dave
Offline rbw993
#14 Posted : 09 May 2010 17:11:13(UTC)
rbw993
One point of confusion regarding R1 and R2 when talking about Roco versus Marklin track radii is that Roco R2 (358mm) is basically the same as Marklin R1 (360mm)Confused . So when a Roco spec states that rolling stock will operate on R2 it should work on Marklin R1. If you check a Roco catalog their "R" numbers are always +1 to the Marklin equivalent.
For all you mathematicians out there:
' = Marklin
" = Roco
R'(n) = R"(n+1)
Roger
Offline atilla
#15 Posted : 09 May 2010 18:00:25(UTC)
atilla
Welcome to the forum! I remember drooling over the "Big Boy" locomotive and reading warnings that while it will run on 360mm radii, it might have trouble with existing signals that were set too close to the track. I assume this is a consequence of the overhangs.
#16 Posted : 10 May 2010 01:44:04(UTC)
While not having a Big Boy Damon was over one day and had his Big Boy for a runn on the new layout when it was the bottom layer only and we laid a Temp R1 Loop. the big Boy had a Lot of Overhang. The Loco handbook actually gives the overhang for various Radius.
NN
This page was generated in 0.870 seconds.
