#1 Posted : 30 April 2010 22:22:55(UTC)
Hello!
Here's my review of Re 421 (Re 4/4 II) from the M* starter set 29481:
In the box the loco lies on a long strip of felt - I should have dusted her before taking the pictures.
The locos has yellow LEDs (three front lights, one tail light), no red tail light. Tail light cannot be switched off separately.
Loco looks very detailed.
The dark frame at the big "g" from cargo is not prototypical. The mould is prepared for the number plate that the loco had in earlier eras.
The loco has spoked wheels and two different pantographs - just like the prototype.
It includes closed front skirts (that can be mounted after removing the NEM pocket).
However, the closed skirt collided with the truck - a piece of sandpaper solved this.
Before (left) and after (right) the sandpaper treatment:
The loco can be operated from catenary - but the manual is outdated (it describes a switch that was replaced by a jumper; this has been discussed here before, but though this is a new model they still have the wrong description in the manual.
The Mobile Station that comes with the set already includes 29481 in its database; the MS offers to set ACC and DEC separately (which is not supported by the decoder).
The decoder is mounted on a 21 pole plug underneath the PCB (there are free solder pads on the PCB and the light module):
Is there a way to activate red rear lights? I don't know, but maybe somebody else can tell...
The loco has a decoder of the 60760 type and the normal 5-pole high efficiency propulsion.
14 speed steps only, but with a long acceleration and braking delay it works OK.
The motor is rather quiet compared to other 5-pole locos (not as quiet as a c-sine).
Since the decoder is only plugged on, it should be simple to convert this loco to mfx (or DCC wink).
The print looks very good and very detailed:
Manufacturer signs printed silver, other information printed white.
The text SBB CFF FFS Cargo should be on the height of the door handle, so it's too deep on the model.
You can see through the engineer's cab which has a reproduction of the interior.
Two more pictures:
I was too late to get a 37345 so I'm happy to have this loco now.
Note: Original review thread:
https://www.marklin-user...ts&m=10673#post10673
Edited by moderator 05 June 2010 01:39:31(UTC)  | Reason: Not specified
Offline TimR
#2 Posted : 01 May 2010 02:13:35(UTC)
TimR
Indonesia
Did Webmaster just moved H0's two topics to this section? ThumpUp
Re: Close skirting on ALL Marklin Re4/4 IIs
I have a couple of Delta models and a new Trix 22148 - all have the same problem - they rub off against the truck. I would think that Marklin hasn't fixed this with 37320 and 37321.
Now collecting C-Sine models.
#3 Posted : 01 May 2010 14:26:49(UTC)
Thanks Tom for a very good report. This looks a nice loco. Pity though they did not sort the errors you have mentioned.
dave
Offline mmervine
#4 Posted : 01 May 2010 15:25:51(UTC)
mmervine
I did get my hands on one of these (thanks to Guy (Charlie) at AJCKIDS). I am going to install a LP3.0 and get some warm white Leds for it. It will be a real nice lok with these upgrades!
Offline bam1748
#5 Posted : 03 May 2010 15:20:34(UTC)
bam1748
Thanks for the review, the problems would seem fairly easily corrected if they wanted to. You'd think they try hard to get the starter set loco working right with the correct instructions. (cost cutting to help deal with the financial woes perhaps?)
Matt
#6 Posted : 04 May 2010 07:48:27(UTC)
I ordered the white LED panels from Maerklin but have not yet installed them on any of my Re 4/4IIs. They come with white LEDs for the long distance headlights but do not have the red LEDs as does the 37343 TEE Lok.
I use the frame and motor from my 37343 with my 37344, which enables me to shut off the white lights and use only the single red when pushing my "NPZ" Regio Pendelzug with Lima coaches and RailTop pilot coach.
I don't know whether the 29841 has an ESU Decoder, but on some of the ESU decoders, the front and/or rear lights can be disactivated using the lokprogrammer. It may be possible to adjust using a Central Station as well.
This page was generated in 0.312 seconds.
