Offline I_love_Marklin_37538
#1 Posted : 10 April 2010 09:30:56(UTC)
Ok
Yesterday I tried a Wurttermberg 34112 + Pr G. 8 from a starter set which had a class 85 and 4 thunderbox coach and 4 freight wagons,when I tried double heading when the G. 8 pushes,the tender on the Wurttemberg C leaves the tracks and CS1 comes to a stop light
#2 Posted : 10 April 2010 12:38:39(UTC)
I_love_Marklin_37538 wrote:
Ok
I'm not surprised. The two locos you mention have very different driving characteristics. Probably at low speeds the G8 will be trying to move faster than the "C", so it will derail its tender, which is quite light.
You should only try double heading with two locos which have regulated decoders, and who's speed matches at different throttle settings.
#3 Posted : 10 April 2010 13:48:14(UTC)
I use double heading with two 60901 decoder locos or two MFX locos.
Offline TimR
#4 Posted : 10 April 2010 14:18:32(UTC)
TimR
Indonesia
Another safer way to do double heading: take out the motor in one of the loks... preferably in the lok that has inferior decoder (Delta, C80, etc)..
A good Marklin model will easily pull the dummy lok;
No need to worry about fiddling with parameters, and no risk for the two loks to run at different speed.
Now collecting C-Sine models.
#5 Posted : 10 April 2010 15:31:09(UTC)
Ok
Would changing over the Delta chip or faulhaber motor to MFX mode work better when double heading?
#6 Posted : 10 April 2010 15:45:12(UTC)
Ok
Possibly, but you would still have to fiddle with the CVs to get the speed to match at different throttle settings, which might be quite hard to do, as one loco is an Express passenger type, and the other is a goods loco.
You have to ask yourself, "Is this something I'd see in real life?" You might be complicating things unnecessarily.
#7 Posted : 10 April 2010 17:23:34(UTC)
I feel enough has been said without me adding anything to it.
Putting your inquiry aside, there are certain rules and options one has to consider and include, before taking a plunge of trying to use a double header.
Even with 2 identical locos you still can experience a different speed at low, medium or high level.
I have Roco & Märklin locos and I don't even think or trying to match their speed ranges because they have different gearing.
It is very rare to find a combination of the type of locos you're trying to doubel head.
You sometimes could see freight locos have been used for passenger trains.
Your combination would be a 1 off and only you would be able to match, if ever, the same speed, regardless of motor or decoder.
Offline klarinettmeister
#8 Posted : 11 April 2010 22:53:12(UTC)
klarinettmeister
I also agree with everyone here. It´s easier removing all the drivings in one loco.
I have the 37415. 2 locomotives that are made exactly the same and are made to be coupled together but they also differ. And on top of that one of them has to drive backwards and the other forwards. Otherwise it says "Green Green" on one side and "Cargo Cargo" on the other instead of "Green Cargo". It should be better to buy one of the locos seperate and rip out the motor parts from it.
#9 Posted : 12 April 2010 00:31:43(UTC)
When two modern locomotives are coupled together, it is less of an issue, than when coupling two steam engines or two locomotives with cars/coaches inbetween. Even if the trailing lok (like in klarinettmeister's example) is a little slower, this will put a little strain on the other engines motor and coupler, but should not be too much stress for it to bear. When creating, say a DB Regio consist with a bunch of coaches sandwiched between two 143/112/146 loks, if one lok is slower than the other, this can exert tremendous force on the intermediate coaches, which will cause them to tilt and potentially derail.
I once experimented with using a Ae 6/6 as a pusher on a freight train, like they do on the Gotthard. It was extremely problematic for the following reasons:
1) When train entered signal (stop) zone, pusher kept pushing = FAIL
2) When train entered incline, pusher did not decelerate like main lok = FAIL
3) When train reached peak of hill, main lok would accelerate, pusher would cause drag = FAIL
Interesting to note that when I used a Maerklin lok with the motor (rotor) removed, it still caused a drag on the consist, causing a few lightweight 2 axle freight cars to tilt/tip in curves.
I did notice that it worked better using a Roco Lok with the motor removed.
@Klarinettmeister:
In prototype, are the RC4s always arranged in tandem so that is says "Green Cargo" over the two loks or is it common to see either "Green Green" or "Cargo Cargo" as well
#10 Posted : 12 April 2010 03:49:12(UTC)
Changing the topic slightly from originally 2 different loco types inb tandem drive to use locos in tandem drive or push pull locos.
With Märklin couplings you can notice (push-pull operation) which loco is pyliing or pushing the consists by watching the coupling being together or slightly apart.
My example below was'nt a deliberate attempt to have the train consist running in 2 parts but the result was this was the point of the first loco pulling and second loco pushing.
So the ratio was quite high for the first loco (carriages).
It had the same effect as Mike described it by lighter carriages de-railing because the pushing loco was going slightly faster.
You also have to include the load the first loco is encountering and would the loco be able to haul the train on its own. ?
My curve tracks at this point are k-track 2251.
Offline TimR
#11 Posted : 12 April 2010 04:38:13(UTC)
TimR
Indonesia
I have to mention that it's probably good that the new Marklin TGV (or even the old ICE-1) only have one motor unit powered - not only that it makes the set cheaper, it also avoided all the problems mentioned here - especially with their rather delicate couplings.
Even with the two BR189s with the more precise SDS motor - being set up at exactly the same parameter - they both are running at slightly different speeds in the same speed settings.
With DCMs, it's even worse, as even when you got the speed to synchronize in the first instance, over time, one or both of the loks would begin to drift from the original settings and running uneven again.
Not saying that double consists can't be done - they can. But for many, it would either be too much hassle or you would risk damaging your loks and/or wagons.
#12 Posted : 12 April 2010 10:02:43(UTC)
I would do it on occasions but not as a permanent feature.
As everyone has pointed out the flaws and irregularities which can occur over time, it is'nt worth it.
the origianl post mfx decoders could also bring hassles unless you can operate both locos (mfx different decoder number) e.g. Central Station.
My video of 2 crocodiles (1 x Märklin, 1 Roco) can only run almost at the same speed at one particular speed level.
The problem with pull push locos is having a signal with braking delay (2 pickup shoes).
Having 2 locos together, you have to remove one pickupshoe and join them with electrical couplers (freight train).
Passenger train = all carriages have to have electrical couplings (Pull-push train. (push loco = no pickupshoe)
And another problem which could arise is: acceleration delay off or on ? I run mine with acceleration delay off.
If anything happens while running (power failure) both locos will resume their previous speed.
You have to ask yourself the question: Who in the world is going through all the problems associated with it.
Can it be done: yes, How ? is everybody's guess, does it look good: yes, does it have any benefits: no,
Is it easy to set up: no.
#13 Posted : 12 April 2010 15:51:32(UTC)
klarinettmeister
mike c wrote:
@Klarinettmeister:
Mike. The answer is no. 37415 consists of 2 totally different RC4 locos and has only been seen together once, at the 150th year celebration. I think they were painted only for that particular occassion, because none of the other RC4 are painted that way. 37412 and 37414 represents how they normally look like. I´ve seen one of the prototype locos from 37415. It looked strange, therefore I use both loks together.
BTW, I have the same experiences as you do, now that you mention it. I was converting one RC-loco and removed the motor and used another RC-loco that pulled. It was very heavy and I couldn´t have many cars because they are not very heavy. I tried the typical Swedish SMS-train. Loco-cars-loco which are sometimes used because it takes time to change the locomotive from one end to the other end. One typical is: loco-3 cars-loco.
/David
Offline hemau
#14 Posted : 13 April 2010 00:13:51(UTC)
hemau
Of course I want to be able to use each separate loco too so taking the motor out of one is no option. I have two double headers, a M* Delta NS 6513 and a M* mfx MaK of about same type, and a converted Pico class 189 (with 60960 decoder) and a M* Br 189. The trick is to tune the mfx loco's so that they run almost the same as the other. Tuning is done by making them run alone at a little distance of eachother. Make sure the front runner is the fastest. They've run for hours now and all is OK.
Best regards, Henk
C and M track; CS1R and 2 MS
This page was generated in 0.526 seconds.
