Offline steamfriend
#1 Posted : 30 March 2006 20:56:32(UTC)
steamfriend
Now that we've been admiring Pierre's conversion of the Walters turntable, I got inspired to convert the Marklin/Fleischmann turntable 7286.
In fact, the 7286 turntable is not the correct style for roundhouses, as it is of the so called Schrotterbett-Drehscheibe (ballastbed turntable) type version. These were used usually not in conjunction with the roundhouses, and ought not to be driven too frequently. The concrete version was used mostly with roundhouses, so that is what I aim for. This means in fact that the middle rail should disappear. There was only the outer rail (close to the wall) and the king pin. (central stud and rotation point)
See picture :
Am I the only one with this idea - I was wondering
I intend to convert the turntable in the real thing, that means I'll have to grind away the inner rail. Anyone there to give me advise?Cool I know, if I do so , it will fall apart totally, so I first will have to fix the 'pit'....
I will add pics as soon as I have something of value biggrin
Bye for now
Yours,
Bob
thanks 1 user liked this useful post by steamfriend
Offline stephenbb
#2 Posted : 31 March 2006 01:20:41(UTC)
stephenbb
Good luck! I didn't know that Marklins wasn't prototypical. However, I look forward to seeing your progress photos if possible.
Stephen(USA)
Stephen(USA)
ETE,NMRA,MEA
Offline PierreGILLARD
#3 Posted : 31 March 2006 03:36:16(UTC)
PierreGILLARD
Hello Bob.
I wish you all the fun that I had to convert the Walthers turntable !
I don't know how the Märklin turntable pit is made, but my suggestion would be to remove the unwanted rail and glue concrete plates made of thin styrene sheets as can be seen on your picture.
Keep us informed about the progress of your conversion.
Pierre.
Offline steamfriend
#4 Posted : 02 April 2006 02:32:36(UTC)
steamfriend
well , here is my first update. The first thing I wanted is the inspection tunnel that these turntables are equipped with. It is accessible from the side and allow crew to do maintenance jobs <u>under</u> the bridge.
The result is seen here :
What do you think ? Indeed, the contour of the future wall looks kind of bizarre to me: too many ups and downs biggrin
My hesitation took the final turn : the middle rail had to go. More work ! If you mill it out, the centre part will come apart, so I made a supporting 'ring' structure from some recuperation plastic (looks like wood, but it is plastic !). I used the hot glue gun, as well as screw to fit it firmly. See picture :
Then, and only then, the middle rail could be milled out. Result :
Now, this leaves a hill-like landscape in the pit.... Putting styrene plates (thanks Pierre for the tip !wink) was not possible now, since the damn driving motor hangs too deep in the pit. I wanted to keep it - saw some other guys switching to a Roco motor drive that drives the bridge from underneath. To me, this looks too much out of the way, and I invested in the digital control system. So I had to stay with the original drive.
Only solution : further milling the landscape out, as flat as possible. I took of 2,5 mm. More is too dangerous for my system of fixture - if someone is interested, I can provide a tip for doing better.
See pic.
Now, I think we can add the plates to mimic the concrete. But that is a story for later...
Hope you enjoyed the pics...
Bob
Offline HueyCE
#5 Posted : 02 April 2006 06:47:40(UTC)
HueyCE
Lot's of work involved. Keep us updated.
Ira
Offline franciscohg
#6 Posted : 02 April 2006 08:57:31(UTC)
franciscohg
Chile
Brave man!!!!!!!
wish you success
#7 Posted : 02 April 2006 10:43:01(UTC)
Keep posted soon on your process.
#8 Posted : 03 April 2006 11:03:28(UTC)
Very risky decision.I hope the result will be nice.confused
Offline steamfriend
#9 Posted : 04 April 2006 01:57:02(UTC)
steamfriend
Hi friends,
Mm, did some more work the past hours, and - mind you - I got even bolder: the bridge itself got also under the milling machine : I took the bulky u shaped profiles away, and used plastic card to build the actual double shape of the bridge (did you know it exists in two parts ? I did not before I started to do some research). I add a pic. I feel very satisfied with this premature result, since it now correspods to what I really want to see on my layout ! Hope you like it too.
First pic shows the 'new' frame of the bridge.
and the second picture shows a trial assembly of the bridge with pit. The pit uses a very temporary cover, I am not satisfied with this. But it gives an impression of what is to come biggrin :
Now, I am trying to improve the bridge railings, not so easy. I'll report on that hopefully in a couple of days. Stay tuned wink
Bob
#10 Posted : 04 April 2006 04:47:24(UTC)
PierreGILLARD
Great work, Bob ! Congratulations !
Which tools do you use ? You look to be perfectly equipped !
Pierre.
Offline franciscohg
#11 Posted : 04 April 2006 06:08:27(UTC)
franciscohg
Chile
[:0][:0]
Congratulations!!!!
#12 Posted : 04 April 2006 10:48:40(UTC)
Dremel maybe?
<br />Great work, Bob ! Congratulations !
Pierre.
Offline steamfriend
#13 Posted : 04 April 2006 11:10:49(UTC)
steamfriend
Indeed, Pierre, I like to invest from time to time in tools, rather than the umpteenth locomotive... There are marvelous tools available, and I am using Proxxon tools. I'm not an addict, but they have quite an extensive range, and the quality is exactly what we need. Not the super industrialised and heavy thing, but also not too lightweigthed. Have a look at http://www.proxxon.com/
Moreover, the prices are quite modest. I use quite some material from the Micromot range...
Until soon,
best wishes,
Bob
#14 Posted : 05 April 2006 00:52:35(UTC)
PierreGILLARD
[size=1" face="Verdana" id="quote]quote:Originally posted by steamfriend
<br />Hi all,
Until soon,
best wishes,
Bob
Thanks for the link, Bob. I didn't know this tool manufacturer previously. If I had room enough, I would buy the Mill/Drill System BFW 40/E as well as a small lathe.
BTW, where do you live in Belgium ?
Pierre.
Offline franciscohg
#15 Posted : 05 April 2006 02:10:58(UTC)
franciscohg
Chile
Great tools indeed!!
#16 Posted : 05 April 2006 22:49:06(UTC)
Hi friends. I have found this, sorry only in Danish; but on page 17-18 you can se a detailed drawing
on how a prototypical turntable i Denmark looked in year 1900:
http://www.modelbanetekn...k/bog/sporlaere-1900.pdf
Offline franciscohg
#17 Posted : 06 April 2006 00:39:41(UTC)
franciscohg
Chile
great!!!!
cannot read anything, but the drawings are superb!!!
Offline steamfriend
#18 Posted : 06 April 2006 02:36:29(UTC)
steamfriend
Hi all !
Thanks for the comments guys !
Pierre, it is indeed the BFW40 that I am using. Guess what : it costed me 300 Euros (excl VAT). Real value for money !!
Per : loved the drawing you provided. It is not exactly the same style as the german type, but it comes close. Note indeed the split nature of the bridge !
Coming back to my project, here are a few pics of my recent work :
general overview picture of the first paint work. The pit is naked, but smoothed with filler. Not bad maybe, but still slightly 'hilly'
Today, I have been working on the groove, and the cover sheet for the pit. I tried further painting work, but am not very satisfied with it. Two tones to choose from gentlemen : top or bottom(gray) I probably will go for an even deeper gray tone.... stil not sure
Note I had to trim the edge border profile (see gray Tamiya filler zone) since that damn motor hangs so deep in the pit, it hit the corner of the groove, despite all my efforts to avoid that.... Anyway, I will use it as a realistic effect - I'll see..
Finally a pic on first assembly trial. I cut down the railings too. Did anyone notice ? It took me a full evening to do both, but I am not fully satisfied : difficult to cut them down in a straight way (use a sharp knife, since I fear a mechanic tool will sollicit too much vibrations for the structure to survive). I have to further think on that. I ordered brass profiles to prepare myself...
All the best,
yours,
Bob
Offline HueyCE
#19 Posted : 06 April 2006 05:26:11(UTC)
HueyCE
Looks good so far.
Ira
Offline ulf999
#20 Posted : 06 April 2006 10:11:11(UTC)
ulf999
Looks very good!
#21 Posted : 06 April 2006 23:39:35(UTC)
Look 100% great!Smile
Offline franciscohg
#22 Posted : 07 April 2006 00:21:42(UTC)
franciscohg
Chile
Really great!!!!
Can't wait to see it done.
#23 Posted : 07 April 2006 00:58:30(UTC)
PierreGILLARD
It is a true adventure !
To paint realistic concrete, I use Floquil "Concrete" # 110082. Then I drybrush strokes of Humbrol "Rust" # 113 and I finish later with dry-brush of Humbrol Black # 33, Grey # 27 or Poly Scale "Grimy Black" # 414137. Further weathering can be completed with Poly Scale "Mud" # 414314 or "Dirt" # 414308 for instance. Proceed first with some tests on a scrap styrene if you are not familar with these techniques.
I am sure that you will get a superb turntable !
Pierre.
#24 Posted : 07 April 2006 02:39:35(UTC)
Bob: Excellent job - congratulations [:p] !!!
Offline steamfriend
#25 Posted : 19 April 2006 00:39:49(UTC)
steamfriend
Hi all, and thanks for the encouraging words Smile ... I needed them.biggrin
I have not finished the project, but I wanted just to keep you updated with my progress.
I am almost finished with the pit. I gave it several coatings, and loved the deep gray look it has now. Comes close to the original Märklin - maybe that is why I like it wink. Did not like the concrete light gray - too clean for my taste...
I have also given it a place in my layout - something quite definite and not an easy decision. I give two pics :
The two incoming rails are in fact the two rails to leave the depot. Hope you like the color... I added some traces of rust [:p] too..
I broke away all the slits that 'click' the individual rail-endings in the pitwall. The fit without is strong enough, and by gentle pulling one can remove a connection if necessary. The pit wall still is not finished, you have to wait to see the end of it in some days - weeks from now. Note also the wooden ring (4mm) to 'bridge' the difference in height between K and C track.
Finally, what better way to test the bridge than with the BR44 ?
I am now waiting the delivery of some fine scale profiles to make up the railings. I jeopardized the original ones (see earlier picture) too much to my taste. Then the cabin has to follow.
Good news : the electrics work ! With the original motor still in place !
Until later !
Bob
#26 Posted : 19 April 2006 03:08:25(UTC)
PierreGILLARD
Really nice job, Bob !
The most difficult is now behind you.
Congratulations.
Pierre.
Offline HueyCE
#27 Posted : 19 April 2006 05:56:09(UTC)
HueyCE
It is turning out rather well.
Ira
Offline Tony
#28 Posted : 19 April 2006 09:57:42(UTC)
Tony
Hi Bob
Nice job - looks really great.wink
Just on the Proxxon stuff - I get all my stuff from:
http://www.sell-it-easy....103f1d4d&cp_tpl=5501
Really great service and good prices. They also have some other interesting tools and things.
Regards Tony
#29 Posted : 19 April 2006 19:39:00(UTC)
Great job.
Offline steamfriend
#30 Posted : 19 April 2006 21:36:46(UTC)
steamfriend
more rapid than I thought, but here are two more pics of the pit wall: nothing more than a plastic-card ribbon (0.3 mm thick) painted in gray and rust now hides the ugly slots. Only the gearteeth have to remain[:(]. Well, anyway, I am happy with the overall effect.
Here, the entrance of the maintanance groove can be fully seen (Blitz light excagerates the illumination effect of course)
Thanks folks for the praise biggrin I'm not finished yet..
Bye for now,
Bob
Offline franciscohg
#31 Posted : 19 April 2006 21:51:49(UTC)
franciscohg
Chile
Great work Bob.
Offline MHauge
#32 Posted : 28 May 2006 21:46:15(UTC)
MHauge
Photos of the turntable in Randers, Denmark can be found here:
http://server6.theimageh...N2106.JPG&album=9944
http://server6.theimageh...N2107.JPG&album=9944
Looks much like what you made.
But i hope yours isn't as noisy, almost wished i brought earplugs.
Mixed photos from my day in Randers http://server6.theimageh...com/album.php?album=9944
Märklin C-tracks, Mobile Station, Danish Ep 4
Offline Sander van Wijk
#33 Posted : 28 May 2006 22:27:29(UTC)
Sander van Wijk
Looks very neat! Your BW with this turntable and your ashpits will definately be a real eyecatcher. Wonderful!
Sander
Offline steamfriend
#34 Posted : 29 May 2006 00:32:12(UTC)
steamfriend
Hi friends,
Thanks for all the support. I spent the four last days on finishing my turntable, so for me this is the final report on this particular job.
As mentioned earlier, I was not entirely happy with the original Marklin/Fleischman handrails. I tried to cut them down, but I succeeded only with doubtful results. So I to make a hairraising decision: to make my own handrails. I ordered L brass profiles (1x1 mm), and received them a few days ago. My plan could take shape now [:p].
Here is a pic of the frame building :
One day later, the railings got finished too. Note here that at this point I still wanted to use the original pieces with the stairs, in view of the difficulty to produce them.
But the combination of the rough rails with the fine scaled home made ones was too much for my heart. I decided to go for the full job:
The full bridge with the brass rails. Nice, isn't it ? A pitty we cannot leave it like that... [}:)]
One major point of attention was the driver's house. I put two guys in there, that keeps company alife biggrin, put a heater, and some extra levers. I - of course, cut away the extra window in the roof (it was only used when working with overwire electric locos, to see if the pantograph was down when starting the turntable - so of no use in a steam only operation mode). A risky thing was to cut the door out of its support, and I added two suspension wheels and a rail to make it a sliding door (as with the prototype). I am happy with the result - though not perfect - It looks great to me.
I like small details, like the chap that left his bag outside the cabin. Hope he will no forget it when he is finished with his gossip conversation wink.
A final view of the built-in bridge ! And, it still works (use a digital drive, works marvelous). Case closed. biggrinbiggrin
Now, the coaling bunker is waiting ....
Bob
#35 Posted : 29 May 2006 01:36:16(UTC)
PierreGILLARD
Bob, you are an extraordinary scratchbuilder ! Congratulations.
Your job will inspire me for my next turntable !
Pierre.
Offline usbeauty
#36 Posted : 29 May 2006 02:34:35(UTC)
usbeauty
Really magnificent, Bob. Thank you for sharing it here.
Bruce
Modeling the Bruxelles - Nord to Knokke - Heist line on my layout, complete with pommes frites stand (frituur). (Epoch IV, digital and analog)
Offline HueyCE
#37 Posted : 29 May 2006 05:14:21(UTC)
HueyCE
That looks outstanding.
Ira
#38 Posted: : 29 May 2006 07:26:13(UTC)
Simply amazing - thanks for sharing the pictures Bob..
Offline Tony
#39 Posted : 29 May 2006 10:11:23(UTC)
Tony
Good job Bob
Love the brass workwink
Regards Tony
Offline franciscohg
#40 Posted : 30 May 2006 06:41:56(UTC)
franciscohg
Chile
Wow!!!!!!
Great!!!!!
Offline ulf999
#41 Posted : 30 May 2006 11:27:34(UTC)
ulf999
a beauty!!!
Offline laalves
#42 Posted : 30 May 2006 15:13:06(UTC)
laalves
Yes, truly great job Bob! I'm looking at my own TT (still boxed) with a different look now..... Considering some copy now, as I did before with the ashpit....
Luis
Offline SRB
#43 Posted : 30 May 2006 19:48:21(UTC)
SRB
It's a remarkable work you have done here. Congratulations. Looks much better than M*. I really like youe details.
Stig
IB; C-track; DSB and SBB ep. III-V
Offline kiwi
#44 Posted : 31 May 2006 02:38:41(UTC)
kiwi
Bob
great work it really looks good.
cant wait to see that coal bunker
kiwi
Mike. Rebuilding at the moment(c-track,digital) DRG,DB,SBB era 1-4 steamers and the odd electric
https://www.marklin-user...ault.aspx?g=posts&t=4561
Offline steamfriend
#45 Posted : 31 May 2006 03:02:08(UTC)
steamfriend
Kiwi,
Thanks, but you will have to have some patience... I will use the Faller coal bunker, but I do not like the welded unity construction. I am desparately seeking for some good alternatives, with bolted profile constructions (but with the same configuration as the Faller one). I have found some vague examples, but need more details. It seems I will have to let go my imagination again... (like with the ashpits) [^]
Hope it will not take too much of your patience Smile I promise to be back with this...
Yours,
Bob
Guest (5)
This page was generated in 1.223 seconds.
