Offline Caplin
#1 Posted : 11 January 2010 19:58:41(UTC)
Caplin
Hi all members.
Does any of you have experience with using lacker-isolated solid copper wire from transformers instead of the colour-scheme multicore wires supplied by Märklin and Viessmann and others?
I think I would like to try it out on my next conversion.
I am aware of the hazards of possible shortings if the wire is rubbing against a sharp metal corner or otherwise damaging the coat of lacker, also due to not being flexible it is not suited where the decoder is situated in the slepptender and between cars/coatches.
The advantage as I see it is that a solid wire is easily shaped and soldered and the supply of it is plenty from the secondary coil of just one standard pluggable 240V to low volt transformer. Also the diameter is smaller than the overall diameter of the multicore wire. See the picture below. As for the conduction capabiliy, I think that the solid wire being thicker than the multicore wire compensates fully for the smaller surface compared to the although thinner multicore having a larger surface to carry the current.
Benny - Outsider and MFDWPL
#2 Posted : 11 January 2010 20:29:28(UTC)
As electrician, the general rule is to use multicore wire on everythings that can be moved/moves/vibrates osv.
A solid wire can break over time.
In Denmark, "Maskindiriktivet EN60204-1" says you have to use multicore wire on machines.
Don't break the law, Benny BigGrin BigGrin BigGrin BigGrin
P.S: Use orange wire, not "cobber-coloured" Drool Drool Drool Flapper Flapper Flapper
#3 Posted : 11 January 2010 21:23:05(UTC)
Yes!
#4 Posted : 11 January 2010 23:11:40(UTC)
And that's what Märklin do in their analogue locos: if the loco has no trucks, the copper wires of the field coil are directly connected to motor shield and mechanical reverse unit. They use multicore wire for locos where the motor moves with the truck.
#5 Posted : 11 January 2010 23:52:16(UTC)
Svein has plenty of orange wire he can give you, Benny!
#6 Posted : 12 January 2010 00:14:31(UTC)
We are all not that colour on the correct side of the world. SOme have more sense than lay around all day out in the sun. Flapper Flapper Love Love LOL LOL
Offline rugauger
#7 Posted : 18 January 2010 01:36:33(UTC)
rugauger
I'd stay away from it. If you want to move/replace the decoder, flexible wires will give you more room to play with (and less chance of breaking). Also, you'd lose the colour coding of the wires which would make fault diagnosis or decoder replacement more tricky. I've had plenty of occasions where I had to re-solder the wire that goes from the field coil to the brush plate, especially when I "just quickly" wanted to give the motor a clean...
Where I do see a use for this wires is where where space is very limited, or where you actually want the wire to stay in place, e.g. along the inside of a loco roof or body.
Richard
Guest (4)
This page was generated in 0.349 seconds.
