2 Pages<12
#51 Posted : 13 March 2009 01:36:57(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Rud
<br />Hej Henrik. No I mean 100 Euros. Nettog.dk charge only Kr. 299,00 for a MS from a starterset, and the savings are even bigger when bought with one of the transformers.
Well, I suspect that you are comparing the price of two different products;
The little MS that normally comes in H0 starter-sets can only support 1,2Amps.
The product that is sold alone can support 1.9Amps.
The normal price for the small MS, a 18VA trafo and the uglybox is around 30-35€ on Ebay. So the offer from the shop you mention is "average" unless you mean to say that it includes the big MS?!
#52 Posted : 13 March 2009 01:48:23(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by MarioFabro
<br />)....(...)... can they really take one year off of doing something new?
I remember to have read that around 40% of each years revenue is on new items alone... :-/
Offline Rud
#53 Posted : 13 March 2009 20:19:12(UTC)
Rud
You have been a member since:: 08/02/2009(UTC)
Hello Henrik. I have just checked my 2 mobilestations. The one from 29575 and the one I bought from a anonymous starterset, and they are both the "normal" 60652 with 1.9 amps.according to the manual. Actually I didn´t knew Marklin had 2 versions, and somehow it doesn´t make sense to me, not that I don´t believe you, really I do, but in a world where it obviously is difficult making money by making modeltrains, having 2 allmost identical products, seems like a mistake.
Rud
#54 Posted : 13 March 2009 21:39:28(UTC)
<br />The little MS that normally comes in H0 starter-sets can only support 1,2Amps.
Starting 2008 (or was it 2007) they only had the 1.9 A Mobile Station in all starter sets.
I think it was when they started sticking serial numbers under the starter set MSs.
It didn't pay to have different versions (they said).
Offline mvd71
#55 Posted : 13 March 2009 23:12:37(UTC)
[size=1" face="Verdana" id="quote]quote:Rud, welcome to the forum. Your english is just fine! I too have bought locos from starter sets - BR86, BR41, BR50. I've bought Mobile Stations as well. It's a good way to get good models relatively cheap. I hope retailers keep on dong this.
Prehaps I didn't explain myself well. What I was refering to was private individuals who buy starter sets, break them up and on sell them in the hope of making the hobby pay for itself.
I certainly would not begrudge someone who takes advantage of the chance to get a bargain from these people. But every person that sales these items in the local market undermines the sales from a dealer, and it is often the same dealer we turn to when we want service.
Cheers....
Mike.
BTW I have been one of the ones who buys these cheap items, and when it was mentioned to me I thought it was good food for thought, hence why I put my original comment here.
#56 Posted : 13 March 2009 23:41:25(UTC)
The other distinction to make is that a lot of the German Marklin dealers break up starter sets and on sell them. The guys doing it here and on selling on our Trademe site are not Marklin dealers, so you cannot expect any service support from them, and would have to pay to get our local dealer to provide any service.
In my case, the BR41 and BR50 were both delta locos which I have converted. In those cases I can replace decoders or motor parts myself. The BR86 is digital, but should it fail would be reasonably easy to fix should the decoder require replacing. In the case of more advanced model, such as SDS ones, user servicing would be much harder.
#57 Posted : 14 March 2009 00:25:52(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by H0
In that case I am happy to stand corrected! ;-)
As Rud mentions, -and according to you M. also admits; it's just too stupid to have that kind of tactical segmentation of the market. I am happy that M. realized that. Now I will definatly have to help myself to one of those "MS-kits" on Ebay! ;-) (Especially seeing that the MS2 will be delayed anyway)
#58 Posted : 14 March 2009 01:14:42(UTC)
I recently brought a MS , traffo and Ugly Box on Ebay . they came from a Broken up start set. MS was still 1.2 Amp. must have been an old set.
the seller was a Marklin dealer in Germany.
N
#59 Posted : 14 March 2009 04:20:17(UTC)
As mentned before on an other topic regarding shipments from Märklin, the 2 MS that I've received from them as exchange units, are now 1.9 amp.
This suits me right down to the ground.
My Roco 69771 (Ae8/14 2motors) would'nt work with the 1.2 amp version.
It still does'nt reverse for some reason. (Lenz decoder ?)
As for the Roco Re 8/8 = 2 motors, the 1,2 amp unit, it had no trouble.
If you use your 1.2 amp as a slave MS it may woud'nt matter.
#60 Posted : 14 March 2009 04:23:12(UTC)
<br />I recently brought a MS , traffo and Ugly Box on Ebay . they came from a Broken up start set. MS was still 1.2 Amp. must have been an old set.
N
The 1st MS I got off ebay was a 1.2a version (it is now incapable of controlling trains on its own, but works OK as a slave to the CS1 - blown output stage??), and the 2nd one is a 1.9a version.
Offline Writhdar
#61 Posted : 14 March 2009 04:41:13(UTC)
Writhdar
Determining whether a 1.2 amp or a 1.9amp Mobile Station?
The manual I received with my starter (29532) set indicates the 1.2 version is what comes with starter sets. However, when I go to SETUP - INFO on the MS, the values for IT are 0.0-0.1/1.9A. I assume the IT gives the amp limit and 1.9 indicates I have a 1.9amp version. Also, the AN value is 60651 - which from the manual indicates the 1.9a version. Are my assumptions correct?
I'm also curious as what the various categories in INFO refer to - is there a reference to them? The categories are: HW, BL, AP, AN, UT, UD, and IT
(BTW, I had three locos idling when I went to SETUP - INFO)
Dan
#62 Posted : 14 March 2009 05:07:40(UTC)
Marklin originally issued the 1.2a version with starter sets. Later, they upgraded the starter set versions to 1.9a.
Yes Dan, you are reading the info correctly.
#63 Posted : 14 March 2009 09:31:44(UTC)
Just hear that Hornby is cancelled some 2009 new items.[:0]
http://www.rmweb.co.uk/f...pic.php?f=11&t=40000
#64 Posted : 14 March 2009 09:34:04(UTC)
Now what is the next model to been cancalled back...? biggrin
Goofy [}:)]
#65 Posted : 14 March 2009 12:50:25(UTC)
Cancelling? -Is that a new tendency of the producers?
I think M. has been the first to annouce systematic cancelling in great numbers, and if other brands now follow suit quickly, it might show that this whole "new-items-race" during the last decade was in fact draining and de-stabilicing the market? (Sorry; pure speculation by someone who hardly buys ANY "New!" item.)
#66 Posted : 14 March 2009 13:13:49(UTC)
Henrik,
I think thatat last there is some sane reasoning and planning
Offline Rud
#67 Posted : 14 March 2009 17:20:47(UTC)
Rud
I totally agree with you Henrik. I don´t have an unlimited budget, I spend about 1000-1500 Euros a year, most of it on secondhand items. With so many new items being announced every year, it has becomed allmost impossible to choose between them. There may be 15-20 items I would like. At best I can afford maybe 4-6, and then comes the whole process of selecting. I read the cataloque to shreds and end up buying nothing, instead buying old models at swapmeetings or "last years model" on special offer.
Rud
Offline perz
#68 Posted : 14 March 2009 17:47:24(UTC)
perz
I think the "new items race" in MRR in the later years is a natural consequence of the fact that the MRR hobby attracts too few newcomers. Selling MMR things is not like selling food. If you sell red tomatoes today, you can sell red tomatoes to the same customer the next week too. But if you sell a certain model of a certain lok to one customer today, he probably won't buy exactly the same lok next week. In MRR, you can sell old models to new customers and you can sell new models to old customers. But you can't sell that many old models to old customers. If new customers are scarce, new items need to be plenty.
Said that, my impression when I saw Märklin's new items announcements for 2009 was that they had gone desperate. They had definitely over-done it. Many new items are needed for above given reasons, but probably not that many. Now they are cutting down somewhat, but there is still quite an amount of goodies left. I can only afford half of my wish list ...
#69 Posted : 14 March 2009 20:58:18(UTC)
If you look at old catalogues, it was normal to see 2-3 new locos per year. Recently they've gone over the top!
#70 Posted : 14 March 2009 22:52:27(UTC)
Just take a look at the catalogues. As some of you may know, I have been busy scanning Marklin catalogues, from 1950 through 2008, and one thing that strikes me is the increase in catalogue sizes. During the 1980's they were around 180 pages each, by the mid 1990's they were around 500 pages each. That's an awful lot of product to make and sell.
#71 Posted : 15 March 2009 00:17:09(UTC)
In the '70s there were 120 pages (including metall and sprint) - but they had 3 or 4 locos on one page, 6 coaches on one page, up to 11 freight cars on one page.
Later there was a time when they showed the items on nice layouts.
What matters is the number of items, new items, and new moulds. Comparing the number of pages doesn't say much (but I haven't done that yet).
#72 Posted : 15 March 2009 00:36:56(UTC)
I take your point Tom, but given close to a threefold increase in the number of catalogue pages in the space of 10 years, surely that is going to result in a large increase in the number of new items introduced in that time. Surely it wasn't just 300 extra pages of nice layouts and pretty pictures!
#73 Posted : 15 March 2009 02:24:58(UTC)
David, I don't want to estimate how many items there were in the '70s, '80s, '90s, and in the last few years.
In the current decade they sometimes give two pages to one new model. They weren't that verbose in the '70s - even new models had to share a page with other models.
Many additional pages came because of the more generous layout.
Well, catalogue price rose from 0,00 DM in the '70s to 7,50 Euro after the millenium.
In the '70s all locos were "conventional" (i. e. analog).
In the '90s you could see up to four variations of a model: e.g. 3304, 3504, 3604, 3704.
This was reduced to Delta and 37xxx after the millenium - and Delta finally disappeared, too.
So what will we count? Models? Articles? How to deal with these variations?
The new items brochure has 173 new items (I only counted the index) on 186 pages.
The 1978 pricelist had 682 items while the catalogue had only 120 pages (the pages with tracks, signals, and spare parts contain many items!).
I think there are more new items nowadays - but counting pages is not meaningful if you wish to compare the counts of new items now and then.
#74 Posted : 15 March 2009 02:38:04(UTC)
I agree I'm making a generalisation, but my point is, that given the size increase in the catalogue, there has got to have been an increase in the number of items on sale, notwithstanding the 2 page layouts, articles, pictures etc. Of course, the item increase could be due to more coaches and freight cars being available, rather than locos. I suppose if I find time I could go count them!
All I know is that it's real hard work scanning the more recent catalogues than it is the earlier ones!
#75 Posted : 15 March 2009 02:42:56(UTC)
<br />......though I didn´t know there was a movie too.
http://en.wikipedia.org/...index.html?curid=5434141
#76 Posted : 15 March 2009 10:42:10(UTC)
<br />If you look at old catalogues, it was normal to see 2-3 new locos per year. Recently they've gone over the top!
Yes,but those models has been exsist for years...!
#77 Posted : 15 March 2009 11:47:38(UTC)
Yes Goofy, that's my point. You would see 2 or 3 new items in a year, and then they would stay in the catalogue for many years.
Today, you get many more new items, but many of them are "one time series", and you don't see them again in that form the following year. This is great for rich collectors, but not so good for the average enthusiast. I find that I'm still trying to catch up with models that I wanted from the '80s and '90s, and I have no hope of getting all the new items that I like.
Offline Rud
#78 Posted : 15 March 2009 14:09:34(UTC)
Rud
Thats exactly what I mean Ray.
There was a time when a "one time serie" or a "MHI model" meant something special.
Today it seems that there are so many of them, and you have to order long time in advance. Sometimes so long that the next cataloque with new models has arrived. Personally I hate to have money tied up in advance, who knows what can happend in 6, 9 or 12 months, and it´s still just a hobby. Somehow I found my niche in the world of modelrailroading, finding as much joy in collecting models from the 50´ and 60´, as well as newer and new models. And afterall I do order new items, I just have to own the Kittel Dampftriebwagen 37256, which seems not to be a "one time series", and the Flugzeugtransport 45097. There are other models I would like, but then again, maybe I´ll just stumble over something I didn´t knew I was missing badly, and I would hate not being able to buy it.
By the way, thanks for the link David. I´m looking for the movie now, I just have to see it. There are a few goodies on Youtube from the movie.
Rud
#79 Posted : 15 March 2009 14:59:36(UTC)
One thing is for sure.
Businesses today are keeping us on our toes.
We are not allowed to rest our minds from and for new items.
Märklin, unfortunately has paid the price.
From what I can gather, most members had their wish lists on new items already.
There is a fine line between being conservative and pushing for new items.
But in the end or going towards a climat of millions of spare parts, faulty equipment, delayed deliveries can make your dream become a nightmare.
Liquidators are not known for creative ideas.
Will Märklin fans be left hanging in the air and are again waiting for better days ahead ?
The maker of the CS 2 cannot claim any money from Märklin regarding production costs and materials used for producing the CS 2.
With furter statements being announced in April we may hear a conclusion of what will happen with Märklin.
In the case of new owners, I suspect they will try to get their hands on the new CS 2 as soon as possible and produce the startersets.
There does'nt seem to be any stalemate, regarding orders are concerned.
And the other question will arise regarding the US dealership and its future.
regards.,
2 Pages<12
This page was generated in 1.317 seconds.
