Offline metpo
#1 Posted : 23 October 2008 18:10:51(UTC)
metpo
I recently was laying ballast on krails for a diorama, and when I tried to run a loco on it I discovered that on some places the loco stops or runs really hard.. so it seems some contact points frome those places are a bit rusty because of laying the ballast (mixture of glue and water)... Anyone could give me an advice?
I tested the whole (second hand)tracks before laying ballast on it... and all was going ok.
Offline metpo
#2 Posted : 23 October 2008 18:15:24(UTC)
metpo
I want to add that some little parts of the tracks are the old ones..but most of them are the new ones.. but on the old onse the loco can run without problems (even if there is also a bit of rust on the rails (not the middle point contact)
Offline banco
#3 Posted : 23 October 2008 18:21:14(UTC)
banco
I have come across a similar problem and was able to cure it as follows:
1) use of a light grade of sand paper to the middle studs . ( Light use only!)
2) Use of a cleaning truck with pads soaked in lighter fuel.
3) running one of the cleaning pads from the cleaning truck soaked in lighter fuel over the centre studs
hope this helps.
C track,6021,large digital loft layout modelled in the legendary European land of "Moresnet"
#4 Posted : 23 October 2008 18:21:50(UTC)
Try running a track cleaning rubber along the rails where you get the problem. This usually solves this sort of problem for me.
Offline rschaffr
#5 Posted : 23 October 2008 18:45:24(UTC)
rschaffr
metpo:
I have the same effect after ballasting. After my glue dries on the ballast, I take a stepped approach. First I try to clean the rails AND pukos with cleaning solutions. I first apply "GooGone" which is a citrus based cleaner. This leaves a residue, and I take that off with either alcohol or lighter fluid. I then test run it. If it still hesitates, I try the cleaning rubber. If I still have problems, I use a "ScotchBrite" pad lightly. If I STILL have problems, then I use a very high grit (180 or higher) sand paper VERY lightly on the pukos.
-Ron
Offline Trainingtime
#6 Posted : 23 October 2008 18:45:30(UTC)
Trainingtime
If cleaning the track does not work maybe add a few additional wires to the track at the problem areas.
Offline metpo
#7 Posted : 23 October 2008 19:24:36(UTC)
metpo
great ! quick reactions!
GooGone: never heard about it..
cleaning truck with pads soaked in lighter fuel: I will have to check out what is meant with that..
anyways big thanks for reactions!
Offline rschaffr
#8 Posted : 23 October 2008 19:47:58(UTC)
rschaffr
Metpo:
I don't know if Goo Gone is marketed yet outside the US but I'm sure any citrus based household cleaner will suffice. Here is a description of the product:
http://www.magicamerican.com/
Lighter fluid is the fuel you put in cigarette lighters.
-Ron
Offline WelshMatt
#9 Posted : 23 October 2008 20:42:58(UTC)
WelshMatt
I just use a plain track cleaning block - a quick wipe will remove dried glue from the railheads. On my last layout I found that the glue left on the sides of the rails discoloured to a realistic gungy appearance, so I didn't have to paint them.
Matt from Wales.
Offline monster134
#10 Posted : 23 October 2008 23:56:39(UTC)
monster134
I do the same to clean the rails as above.By hard running...do you mean the loco runs noisily over the ballast?
I have found that i sometimes get ballast onto the rail itself.Not the top of the rail but just enough at the bottom so the wheel flange catches it.I use a stick with sandpaper glued to it to clean it off.Then they are nice and quiet.
#11 Posted : 24 October 2008 00:48:09(UTC)
I would never use anything abrassive on the rail!!! -Not even the finest grade sand paper.
I use a wooden block. That is abrasive enough. (No, I didnt steal the idea from Dale, I invented it myself too ;-)
Offline rschaffr
#12 Posted : 24 October 2008 04:03:50(UTC)
rschaffr
Henrik: All metals are polished by an abrasive. The rails that you are running on were polished at the factory that way. Your jewelry was polished with an abrasive compound in a jeweler's cloth. That is how metal gets it's shine...by using finer and finer grit abrasives.
-Ron
Offline metpo
#13 Posted : 24 October 2008 10:13:14(UTC)
metpo
thanks thanks and i tried to resolve withj a cleaning truck and it helps..
anyways still the locomotive is running a bit strange..perhaps it is because of the fact that some little ballast is sticked on the sdie of the rails..but I took it off.. I will check later on how it is going on and tell about it..
cheers
Offline WelshMatt
#14 Posted : 24 October 2008 12:55:08(UTC)
WelshMatt
The best method I've found for ballasting:
Lay the loose ballast - use your fingertips to shuffle it into place, making sure it doesn't jam points or come above the sleepers
Mix PVA glue, washing up liquid and a little water in an old jar
Use a syringe to pick up the glue mix, and very gently flood the ballast with it. You need to use a gentle trickle as any pressure will blast the ballast everywhere and make a mess. Leave to harden for a few hours (checking that points, etc still work) then give the rail tops and pickup studs a light rub with a cleaning block.
Matt from Wales.
This page was generated in 0.378 seconds.
