Offline Caplin
#1 Posted : 29 July 2008 19:25:23(UTC)
Caplin
This loco is too old for being included in the Product database. Can I ask you for what year(s) it was produced and any other relevant information.
Thank you.
Benny - Outsider and MFDWPL
#2 Posted : 29 July 2008 20:58:18(UTC)
The 3301 53 002 DRG was Delta version, Production 1995-1999.
See the link.
http://www.bahn.hfkern.d...aerklin/Dt_Loks_D53.html
Full Marklin loco database on
http://www.bahn.hfkern.de/Maerklin/Menue.html
Offline Guus
#3 Posted : 29 July 2008 22:47:56(UTC)
Guus
Hi Benny,
According to Koll's catalogue this information is confirmed. Both the DELTA and the digital version were produced for four years from 1995 till 1998.
Exact description according to Kolls:
Lok mit Tender,Bauart Mallet,Achsfolge (1'C) D,Baureihe 53 der DRG,grau/schwarz
Guß/Kunststoff,beids. 2Stirnlampen,weiße aufschriften,Betriebsnummer 53 00002,
Räder geschwärzt,vorn Scheibenräder,vorn HK 9.1(coupler type)
Wannentender fünfachsig,grau,Kunststoff,KKKopf,>31,4cm<
4 Jahr 1995-1998
Kind regards
Guus
Kind regards,
Guus
Offline Caplin
#4 Posted : 29 July 2008 23:04:40(UTC)
Caplin
Thanks Stephen and Guus for very good information.
May I ask also what exactly Delta is? This was before my M* start. I just assumed it was a kind of simple digital.
I have acquired one 3301 and was told by the seller that it will run on both digital and analog systems.
I read in another topic that it is worthwhile to update to 5* with various decoders at choice.
#5 Posted : 29 July 2008 23:35:26(UTC)
Delta normally means: 15 addresses available without soldering (80 with soldering), intensity of light changes with speed (digital loco, but lights simulate analog operation wink).
No load regulation.
Most delta locos have the old AC/DC motor ("Allstrommotor"); nothing can be adjusted, speed characteristics are not good.
#6 Posted : 30 July 2008 12:32:14(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by h-zero
<br />... speed characteristics are not good.
Now that's an understatement.. biggrin
Offline Caplin
#7 Posted : 30 July 2008 13:55:06(UTC)
Caplin
<br />....No load regulation.
Is the old AC/DC motor you mention equal to the DCM type?
My 3301 loco arrived to-day.
Its brand new in box just kept by a collector. After oiling the bearings the loco is running - with flickering front light intensity by speed. I agree to the above statements. Being a new loco I think it will be worthwhile updating.
I found a very good topic here for updating a 3302 which should be very helpfull. https://www.marklin-users.net/fo...8&SearchTerms=mallet
#8 Posted : 30 July 2008 14:46:41(UTC)
Very nice, Benny.[:p]
Offline Guus
#9 Posted : 30 July 2008 14:49:43(UTC)
Guus
Congratulations Benny,
I'm not Tom,but I think both of you won't mind that I answer your question. The motor is a DCM of an older generation.
Part number of the rotor # 231440
Kind regards
Guus
Kind regards,
Guus
#10 Posted : 30 July 2008 14:53:26(UTC)
Nice loco Benny!
Enjoy!
Offline Caplin
#11 Posted : 30 July 2008 14:57:32(UTC)
Caplin
<br />The motor is a DCM of an older generation.
Thanks Guus. I hope that it can still be upgraded with the 60760 kit - otherwise I have bought "the cat in the sack" [B)]
Can it?
Offline Guus
#12 Posted : 30 July 2008 15:43:38(UTC)
Guus
Can it?
Hi Benny,
This loc isn't mentioned in the Märklin lists on digital conversions I have.
Maybe someone else will know whether it's a model that can be converted easily.
Another idea might be to try and obtain the motor parts of the digital version 3701 and install the decoder of the 60760 kit. This may not be the most economical solution,but still.......
Kind regards
Guus
Kind regards,
Guus
#13 Posted : 30 July 2008 16:15:18(UTC)
If it is a DCM it should be possible to use the 60760. Sometimes it is necessary to mount the motor shield upside down, but other than that it should be OK.
Offline Guus
#14 Posted : 30 July 2008 16:36:40(UTC)
Guus
Hi Benny,hi Ray,
The following site has a nicely documented overhaul of a Borsig Mallet locomotive just like yours and with the motor shield mounted upside down like Ray mentioned.
http://www.eisenbahnclinic.com/
It's to be found at the "Projects" button.
I'm not quite sure but I believe this most interesting site was suggested by Jvuye not so long ago.
Kind regards
Guus
Kind regards,
Guus
Online DasBert33
#15 Posted : 30 July 2008 18:10:07(UTC)
DasBert33
How much did you pay for it? I was bidding for one on ebay the last days but everyone seemed to bid higher than me. Maybe you snatched away this one before I did.
Bert
#16 Posted : 30 July 2008 18:47:45(UTC)
<br />Is the old AC/DC motor you mention equal to the DCM type?
DCM, LFCM, and SFCM are all AC/DC motors.
Some folks remove the MRU, install two diodes instead, and run the loco with DC.
Delta locos with DC motors (e. g. E 69, ET 194, Schweineschnäuzchen) behave a little bit better - like Piko Hobby locos with AnDi, I think. Still not really good.
Those don't need a motor update.
With respect to 3301 this is OT, but you also asked what Delta is.
Offline Caplin
#17 Posted : 30 July 2008 20:29:26(UTC)
Caplin
[size=1" face="Verdana" id="quote]quote:Originally posted by DasBert33
<br />I was bidding for one on ebay the last days but everyone seemed to bid higher than me. Maybe you snatched away this one before I did.
biggrin Well, could have been me, because I did outbid somebody, but I was not bidding on ebay.
Offline Caplin
#18 Posted : 30 July 2008 20:33:27(UTC)
Caplin
<br /> http://www.eisenbahnclinic.com/
I bookmarked this very interesting link. Thank you.Smile
Offline Caplin
#19 Posted : 30 July 2008 20:37:44(UTC)
Caplin
<br />If it is a DCM it should be possible to use the 60760. Sometimes it is necessary to mount the motor shield upside down, but other than that it should be OK.
Thanks Ray. I have a 60760 kit and I am anxious to have a go at it. Cool
Offline Caplin
#20 Posted : 30 July 2008 20:45:11(UTC)
Caplin
<br />Hi!
Thanks Tom. It is a bit confusing with all these types. [:o)]
According to Helmut Kerns page the 3301 is equipped with a DCM motor and the 60760 kit should be adequate. I am going to try that later on.
Online DasBert33
#21 Posted : 30 July 2008 21:08:13(UTC)
DasBert33
So no hints on how much I should (not) spend on it?
Offline Caplin
#22 Posted : 30 July 2008 21:41:10(UTC)
Caplin
<br />So no hints on how much I should (not) spend on it?
Well, I got it for 245 EUR. [:0]
Being a brand new one in its box (does this mean a mint condition?), I was determined to get it, so the bidding did go somewhat higher than I first anticipated. I will spend some money on upgrade starting with a 60760 kit - then see how that goes. I might even buy a better decoder later on.
Right now at ebay one 3302 for only 54 EUR including 2 smoke gens. http://cgi.ebay.de/3102-...WDVWQQrdZ1QQcmdZViewItem.
Wish I had seen that one before. [:(!]
Offline pserup
#23 Posted : 31 July 2008 00:13:57(UTC)
pserup
[size=1" face="Verdana" id="quote]quote:Originally posted by CaplinWish I had seen that one before. [:(!]
... don't worry, it'll go much higher before closing biggrin[}:)]
So enjoy your new loco without reservation ... congrats [:p]
Offline sudibarba
#24 Posted : 31 July 2008 05:20:02(UTC)
sudibarba
What am I missing here. That looks like a beautifull lok. Put a magnet and a ESU decoder in it for about $50 and play with the CV's if you don't like the way it runs. I have not noticed great improvement going to a 5 pole motor but maybe I'm missing something there also. I believe Dale S. made a similar comment - Dale if I'm wrong , please correct me.
Eric
Offline Caplin
#25 Posted : 31 July 2008 06:09:42(UTC)
Caplin
Eric, I can't really tell because I have upgraded this loco now with a 60760 kit (less the decoder) and a Lokpilot 3.0 decoder. The way I test the running is with a heavy load of freight cars/wagons and there was a tremendous difference before/after the upgrade. The loco would run erraticly both on accelleration and slowing down before and now it runs very smoothly in all steps. Could I have achieved this smoothness by a magnet and decoder alone I am not so sure.
You are right, it is a beautiful loco.wink
Offline sudibarba
#26 Posted : 31 July 2008 08:03:24(UTC)
sudibarba
I am really happy that your solution is fine. As each of us never knows, as we can not really due an A - B test unless we somehow do a double conversion and compare results,I thnk that we each have to do what makes sense to us.
I think that any real improvement over a simple conversion would involve roller bearings as mnentioned in an other post. But far too expensive.
Be very happy with your pretty locomotive.
I am very happy with an old 3048 I just did.
Eric
Online DasBert33
#27 Posted : 01 August 2008 19:38:50(UTC)
DasBert33
I just scored me a 3701 on Ebay for my birthday in 12 days ! I will also digitize it with a lokpilot, or with my own developed sounddecoder (more on that in a thread later). It will be my biggest steamer.
Bert
(Btw I will pay ~164euro incl. shipping, it remains to be seen whether it is in a shape as good as Bennys).
Offline Caplin
#28 Posted : 01 August 2008 20:12:51(UTC)
Caplin
Congratulations Bert, a very good price. Cool
Looking forward to follow your upgrade topic. Sounds very interesting with your own sound decoder. Has this been published before?
Online DasBert33
#29 Posted : 01 August 2008 20:33:20(UTC)
DasBert33
Nope,
It is not complete yet. The PCB is designed and individual circuits are tested on breadboard prints. (like eg. the sound amplifier). It is FPGA based, the (DCC) logic + motor control is already running on another FPGAboard. The logic + sound together is fully working in simulation only.
The only thing really left to implement is load control for the motors, but the PCB is ready for that so it should be no problem.
The decoder has 10 (!) function outputs (F0 front, F0 rear, F1-F8) and has 2 motor drivers (2 H-bridges). It measures 43*25mm. If you cut off one motorcontrol and 2 function outputs it can be 35*25mm.
But this is OT, I will post more on this and pictures when I have the final hardware up and running.
Bert
Offline mvd71
#30 Posted : 09 August 2008 09:55:20(UTC)
Hi Benny,
Do you mind if I ask how much it cost you to upgrade the loco? ie, the cost of the 60760 and the lokpilot decoder. Also, how do you intend to run the twin smoke units?
And a question for all the people who recommended the 60760 kit. Why? The 60921 kit, whilst more expensive is the correct kit for this loco, as it already has the additional funtionality to drive the smoke units, albeit with a relay to allow for the current requirements.
Cheers....
Mike.
#31 Posted : 09 August 2008 23:30:10(UTC)
Welcome to the forum, Mike.
Offline Macca
#32 Posted : 10 August 2008 07:57:56(UTC)
Macca
I have an analogue 3201 I purchased in the 1970s. I presume it can be converted to digital without too much trouble if I wished to do so? It has never been run.
Cheers, Paul
Quite a few Loks & bits & pieces but no layout yet, hope I never grow up
#33 Posted : 10 August 2008 08:17:24(UTC)
Mike, the 60760 does have function outputs, although officially they are undocumented. There are threads on the forum here that show you how to locate the function outputs. However, they are limited to around 150ma current output, so are probably no good for smoke units, especially two of them. You should be able to get the 60760 from the Lokshop for around $60 plus postage.
Lokpilot decoders are around $75 from Dion at Toottoot, and he has all the motor parts for a HE 5 pole motor upgrade, which would cost around $90. Dion also has the Loksound decoders for around $235. He can get the mfx Loksound decoders for $375.
So for this loco type you would probably go for the 60921, or either the Loksound or Lokpilot plus 5 pole motor upgrade, simply because of the extra functions it has. The 60760 is suitable for basic locos with no extra functions other than headlights, say for example, one of my BR111's, or a V100. Another point to note is that the 60760 has only 14 speed steps, so if you want 28 speed steps then go for a lokpilot, or for 128 speed steps go for a mfx decoder.
BTW, welcome to the forum. I recognise your user name from Trademe.
#34 Posted : 12 August 2008 02:58:32(UTC)
Congratulations, Benny.
A very nice locomotive.
BTW, according to old information, if you use two smoke generators, their power should be controlled by a relay, regardless of which Märklin decoder you use.
#35 Posted : 12 August 2008 02:59:40(UTC)
Welcome to this fantastic forum, Mike!
Offline mvd71
#36 Posted : 14 August 2008 13:38:47(UTC)
Hi Big daddy,
Thanks for the answer. You seem to be in agreement with me that the 60921 is the correct choice for this loco.
I only asked because a few people were recommending the 60760, and I didn't feel it was correct.
By the way, an mfx sound decoder from Dion is only $259.00, not $375.00
Cheers....
Mike.
#37 Posted : 14 August 2008 15:55:30(UTC)
60921 is obviously way better than the 60760, but also about 4 times the price. You get what you pay for (generally).
Offline mvd71
#38 Posted : 15 August 2008 13:52:03(UTC)
I would agree in all aspects ray, except that by purchasing the entire 60760 kit and a lokpilot decoder it is only $25 NZ cheaper, and you don't have an mfx decoder.
But as long as Benny is happy with the loco and its performance, that is all that really matters.
Cheers....
Mike.
#39 Posted : 15 August 2008 14:17:43(UTC)
Yes Mike, but I meant the 60760 set using its own included decoder. For most purposes the performance of this decoder is adequate.
Of course, if you want more functions then you will need to replace the decoder, but I haven't bothered to do this ever! I have 6 or 7 loks converted like this and I'm happy with their performance. I make the acceleration delay longer than usual to disguise the speed steps.
Offline Caplin
#40 Posted : 18 August 2008 20:42:53(UTC)
Caplin
[size=1" face="Verdana" id="quote]quote:Originally posted by mvd71
<br />Do you mind if I ask how much it cost you to upgrade the loco? ie, the cost of the 60760 and the lokpilot decoder. Also, how do you intend to run the twin smoke units?
Hi Mike.
Sorry for late answering.
The 60760 kit is 30 EUR and the LP 3.0 is 23 EUR (Lokshop prices) - Totally 53 EUR (appr. 109 NZD).
I have no plans to add smoke units.
Offline mvd71
#41 Posted : 20 August 2008 09:53:08(UTC)
Thanks Benny, the numbers don't quite add up on that combo in NZ. Interesting.
Still, I hope you get a lot of enjoyment from your loco.
Cheers.....
Mike.
This page was generated in 1.318 seconds.
