Offline monster134
#1 Posted : 18 March 2008 22:23:29(UTC)
monster134
Im almost ready for my third board.Ive measured the tracklength and im on just over 50m of track with the new board.I havent detected any running issues as yet,so-when must i start looking at a booster?
I reckon this is exactly 1/3rd of the track im going to have in the end.So a booster would definitely have to come into play at some time.
Thank you.
#2 Posted : 18 March 2008 22:49:07(UTC)
You need a booster when track voltage drops noticeably or boosters switch off.
The question is: how many trains are running at the same time and how many light bulbs burn?
You know you reached the limit when the booster or central switches off with overload ...
Two fully lighted trains could be too much while six locos with unlighted coaches work fine.
Old AC/DC motors (6080, Delta) draw more current than modern locos.
Offline mmervine
#3 Posted : 19 March 2008 03:16:44(UTC)
mmervine
You can avoid voltage drops by using larger power feeder wires at various points on your layout. Then, you will only need a booster if you are running more than four trains. Other factors can affect power usage such as car lights, turnout motors, signals, etc.
r/mark
Offline Larry
#4 Posted : 19 March 2008 04:42:22(UTC)
Larry
I am always amazed at how much can be put on the tracks and how large a layout can be run completely without boosters.
Offline tekin65
#5 Posted : 19 March 2008 08:27:33(UTC)
tekin65
Turkey
Checking out the track voltage in a MS + 60VA transformator set-up, you can run max 2 Br03 digital locomotives with smoke generators on (maybe some lighted coaches too). In this test layout there's no functions or lights connected to the power supply.
You may consider using a Delta control unit as booster.
Cem.
Now all eras but no ICE
Offline frankie
#6 Posted : 19 March 2008 11:30:32(UTC)
frankie
You have been a member since:: 27/10/2006(UTC)
If you have the upgraded CS you can now read the actual power consuption of your layout.
Alessandro
I have a CS1 Reloaded!
#7 Posted : 19 March 2008 11:42:05(UTC)
I continiously run 3 Trains, 2 steamers with Smoke Generators on, 6 up to 9 Lighted Carriages, Sound on 2 Steamers, an automatic Level crossing using track power and with the CS no problem.
Not a big layout but it workss
Offline monster134
#8 Posted : 19 March 2008 13:42:45(UTC)
monster134
[size=1" face="Verdana" id="quote]quote:Originally posted by frankie
<br />If you have the upgraded CS you can now read the actual power consuption of your layout.
Hey?Where?Mine is the upgraded one.What do i have to push?biggrin
Offline monster134
#9 Posted : 19 March 2008 13:46:50(UTC)
monster134
I did run the bigboy with 2 smokers,the BR53 with 2 smokers and a BR03 with a smoker and 6 lighted coaches with no problem whatsoever at 2 amp on the CS.
So,tell me more about the Delta controller.Thats the 1 with all the buttons that looks like a transformer with acne?[:p]
What was the amp rating on those?
Offline frankie
#10 Posted : 19 March 2008 13:56:35(UTC)
frankie
[size=1" face="Verdana" id="quote]quote:Originally posted by monster134
Is the icon on the right of the turnout/switch command panel, the one that seem an arrow on dial, version 2.0.4 though.
Alessandro
Offline Caplin
#11 Posted : 19 March 2008 14:24:17(UTC)
Caplin
<br />So,tell me more about the Delta controller.Thats the 1 with all the buttons that looks like a transformer with acne?[:p]What was the amp rating on those?
The Delta 4f controller (M* no. 66045) is a 32 VA unit (from the manual, no power decal on the unit itself).
Used as a booster two things must be applied to it:
- the two gray output contacts at the rear panel must be wired (shorted) to each other permanently,
- the gray address selector switch on the top panel left side must be set to the righthand STOP position permanently.
Benny - Outsider and MFDWPL
Offline frankie
#12 Posted : 19 March 2008 14:30:18(UTC)
frankie
To use a 66045 as booster, you have to
1. disconnect the 66045 from the power supply (transformer) so that it is unpowered
2. if you have skipped step 1 go back to step 1
3. disconnect the 6605 and bridge (i.e. directly connect) the two grey plugs
4. feed the digital signal from the CU's (red plug) track output into the blue plug. Use brown as common ground.
5. set the selector switch to the right stop position
6. power on your 66045
Alessandro
Offline mmervine
#13 Posted : 21 March 2008 03:14:14(UTC)
mmervine
Here is a link to a wiring diagram for a 'Delta booster':
http://www.ete-ene.org/LowCostBoosterArtile.htm
r/mark
#14 Posted : 21 March 2008 03:59:15(UTC)
Looks like Mark forgot to include the link to his diagram, so here's a picture of how it's done!
Don't forget the track isolators between powered sections, and you'll probably need some rocker insulators too - these lift the loco ski as it passes over so that the ski does not short together the 2 powered sections.
Edited by moderator 11 January 2011 14:01:26(UTC)  | Reason: Not specified
Offline sudibarba
#15 Posted : 21 March 2008 05:07:54(UTC)
sudibarba
And remember, the delta cannot give more than about 30 amp so a smaller transfomer is fine.
Eric
#16 Posted : 21 March 2008 05:59:04(UTC)
I think that is meant to be 30va, Eric. 30 amps would weld loco wheels to the track!
Offline Piper
#17 Posted : 21 March 2008 09:30:04(UTC)
Piper
Hi Riekus,
It's no question, if you do not have a booster or any of the old stuff, wait for the Marklin booster. If not get the Ecosboost from ESU.
Raait
Pieter
Era I-V / HO / C-Track / MS2, CS2 & CS3 Z gauge. Insider
Member of Märklin Modellers Group
#18 Posted : 21 March 2008 11:32:51(UTC)
Hello Monster.
My general advice when using Delta 66045 as boosters. ( I sell many, CHEAP )
The diagram shown by Bigdaddy is correct, WHEN using a 6021 as control unit.
When using a mobile-station or CS as control unit, you should IMHO NOT let
the trains run from a section powered by boosters, to a section powered by MS / CS.
The short you make between the two electrical systems might blow up your MS / CS
Example:
1 layout section powered by CS /MS + 4 sections powered by boosters is IMHO not a good solution
I would power all layout sections by 5 boosters, leaving the output from the CS / MS "unused".
"Unused" as in only used for programming track, and input signal for the boosters.
A have made a "beginners" instruction in Danish, which can be found here
I haven't had time yet to make a English version for you; but please look at the pictures.
[size=1" face="Verdana" id="quote]quote:And remember, the delta cannot give more than about 30 amp so a smaller transfomer is fine.
[size=1" face="Verdana" id="quote]quote:I think that is meant to be 30va, Eric. 30 amps would weld loco wheels to the track!
Both the above quoted statements are correct!
The Delta 66045 is designed to give 35-40 VA when used as designed.
It has NO electronic maximum-current-circiut; only a bi-metalic fuse.
If powered from a huge transformer, the current in case of a short, WILL BE 30+ Ampere;
until the bi-metalic fuse is heated, and shut the Delta 66045 of.
This period of time, where the current is 30+ Ampere, can be 1-5 seconds.
The short-circiut-current is the reason for me to ALWAYS recommend a small transformer.
In the article on the Danish forum is shown a setup, using 5 Delta 66045 + 5 x 6647 transformer.
I find this solution good, even though ONE big transformer could have delivered
the same current; I will not recommend anyone to use a big trafo.
Follow Me! and you will find my Delta 66045 offer.
Cut the crap and the silly jokes; the essence of the offer is true, I have lots in stock.
As you are my first potential customer in SA, I might be tempted to give you a discount!
Send me a E-mail / private message, and I'll make you an offer you can't refuse Cool wink
I'll be back.
#19 Posted : 21 March 2008 12:14:41(UTC)
Just 4 fun.
My offer on the Danish forum "Sporskiftet", 100 DKK = 13 EURO + shipment
My offer on this forum, 11 EURO + shipment
One of my first auctions; QXL is a Danish equivalent to Ebay. 270 DKK = 33 EURO
Believe it or not, I called the above buyer, and told him, that he had bid too high, and that
I only wanted 200 DKK, including shipment AND a good feedback in the QXL system.
We talked on the phone for half an hour, I trust him to give me GOOD feedback biggrin
Or, try Google, using these words: Purellum Delta Booster
Some people just don't do their homework well enough biggrin biggrin biggrin biggrin
The Purellum Trading Company is growing fast now biggrin biggrin biggrin biggrin
#20 Posted : 21 March 2008 12:34:42(UTC)
[:p]Smile[^][:(!][xx(][:(]Cool[B)]confused[:X][:0]Smile PEr Do Not forget 10% Commission to the CLAN. OR Beware. [}:)][}:)]biggrin
#21 Posted : 21 March 2008 16:31:04(UTC)
Nev; I haven't forgot about the Clan.
I haven't forgot about yours and the other's Wooden Hand Uncouplers either; I've just been too busy [:I]
+ I have a lot of additional bad excuses, in case you should ask again biggrin
You WILL recieve your Wooden Hand Uncoupler one day, so far only proto-types have been given out.
Test-reports show a somehow similar patern, most testers use more or less the same words:
I HATE to admit it, and I HATE to say it; but the Wooden Hand Uncoupler works very well [^]
Why they hate admiting and saying it, I don't know Cool
#22 Posted : 21 March 2008 20:25:48(UTC)
I find it very difficult to uncouple my cars with the Purellum Wooden Hand Uncoupler.
Maybe it is something wrong with mine, as it is a prototype.
The cars very easy derails, and even fall over on the side, when attempting to uncouple. I have even tested with some Danish cars, if the Purellum Wooden Hand Uncoupler should work only on Danish cars.
I have tested from the right side, from the left side, with my right hand hand my left hand all with both ends of the Purellum Wooden Hand Uncoupler. Very difficult.
I even asked my wife to test. She refused [:(]
A photografic evidence:
I need some advice.
Offline dntower85
#23 Posted : 21 March 2008 21:17:19(UTC)
dntower85
biggrin
DT
#24 Posted : 21 March 2008 22:03:42(UTC)
[V]
Offline jonquinn
#25 Posted : 22 March 2008 00:48:32(UTC)
jonquinn
It would be nice to get one of the authoritative views about digital setup to participate on here like Dr. Tom Catherall. Maybe Jeff Stimson could ask if he'd consider signing on?
People would just have to be mindful not to deluge him with questions.
Only reason I'm saying this it seems there are several opinions here responding to Monster's question.
#26 Posted : 22 March 2008 01:10:45(UTC)
In a semi-big layout I think I would devide my tracks into electrical sections, and fead each section by a separate booster.
Maybe like this?
Booster 1 - main station and shunting area with several switches, signals and locomotives in operation
Booster 2 - main line, longer track section, including block operation. Maybe three or four trains in operation simultaniously
(Booster 2b - if more trains and a double track main line I would feed each track with it's own booster)
Booster 3 - sidetracks, locomotive maintanance area etc.
Offline Caplin
#27 Posted : 22 March 2008 01:12:12(UTC)
Caplin
My earlier post here
quote
Posted - 2008/03/19 : 13:24:17 by Caplin
unquote
is not a setup to run trains by but how I intend to use one 66045 as the external power source for all turnouts to save digital power. The turnouts will be equipped with Viessmann decoders - either the k83 decoder 5211 or the inbuilt decoders 5231 and 5235. They all accept an external power source. The two requirements listed is quoted from the Delta Control 4f manual chapter 6.
Guest (17)
This page was generated in 0.772 seconds.
