Offline emanlooc
#1 Posted : 05 February 2008 18:55:05(UTC)
emanlooc
I found this in the forums:
You could wire it up using toggle switches, 1 single pole change over will do for the direction control, the common should be connected to the (L) and the two wires marked "I" in the diagram go to no/nc contact of the switch. Another toggle switch is used for the on/off function, the common being wired to "L" and the no contact of the switch wired to the wire in the diagram marked as "II"
The 7186 manual is here ftp://ftp.marklin.com/pub/Old%20Manuals/7186.jpeg
The jacks on the side of my turntable look like this:
O large gap O O O
(brown) large gap (orange) (black) (red)
Has anyone actually made a switch like this before? If so, would it be possible to post a diagram for an electrically inept guy such as myself? If I have some direction, I know I can make one.
Offline TTRExpress
#2 Posted : 05 February 2008 21:40:48(UTC)
TTRExpress
One needs a short current pulse to activate the switching solenoid and permanent current, which turns the turntable. The two red sockets represent the permanent current supply for the turntable motor engine. You can use Maerklin turnout control switches or use two TRIX function controllers.
If you use TRIX: The two red sockets represent the permanent current supply for the stage engine. These I would connect to both contacts on the Yellow controller No. 66594. Pushing one button moves the stage in the clockwise direction, the other one in reverse. The brown socket serves for the release of the switching solenoid. I connect these to the connectors on the TRIX Green controller No. 66595.
You will need to then attach the common to your AC transformer accessory outlets and attach the other to the Yellow and Green function controllers. You can attach both function controllers togther. The Yellow controller turns the table and the Green sets the current for the next spur track.
I can provide you some other instructions using toggle switches later this evening.
Offline emanlooc
#3 Posted : 05 February 2008 23:42:14(UTC)
emanlooc
I have a 7072 switch that I think I could use after reading your idea about the Trix switches. It's warped, though, and not very reliable. I would prefer to just make a new one with reliable parts.
Offline TTRExpress
#4 Posted : 06 February 2008 03:41:59(UTC)
TTRExpress
Hello again Troy,
I am attaching a link to a diagram that should help you out with the use of SPDT (single pole double throw) switch for operation of the turntable. Print a copy for your records. This was taken from the Layout Building Handbook for Operators of Marklin HO Trains by Carl Weaver. This book is available for purchase from Marklin USA via their website.
The Light bus in the diagram is used for other layout wiring that requires the yellow wire to the AC accessory outlet on your transformer. The BRown wire goes to the brown colored outlet on your transformer AC accessory side or a ground loop or bus if you use one.
Let us know if you got it working.
Edited by moderator 11 January 2011 14:09:31(UTC)  | Reason: Not specified
Offline sudibarba
#5 Posted : 06 February 2008 04:36:40(UTC)
sudibarba
That wiring diagram seems to be one where you would have to hit the switch on the house to pulse the turntable. That might be fine for some but ideally there would be a momentary switch to pulse the relay from a distance. I have a wiring diagram but it requires a relay (obsolete marklin) to work. I think you need to try to find the original simple box somwhere.
I post a thread on this sometime back but no one ever came forward with a simple solution using maybe two toggle switches. Will check my notes.
Eric
Offline sudibarba
#6 Posted : 06 February 2008 04:39:21(UTC)
sudibarba
Almost forgot. On this old turntable it is best to by pass the plugs and hard wire to the leeds under the turntable. Good connection is important.
Eric
Offline TTRExpress
#7 Posted : 06 February 2008 04:46:10(UTC)
TTRExpress
Hi Eric,
The diagram shows a turntable control panel and the wiring to the switches. The switches are located on a control panel for the turntable. The wiring goes underneath the layout from the turntable to the control panel.
Offline emanlooc
#8 Posted : 06 February 2008 06:06:46(UTC)
emanlooc
Thanks Maurice, it all makes sense now. The SPDT changes directions and the start button fires the release. I've never had the original switch, but I do have a 7072 and it has a very cheap feel to it. It doesn't really match the build quality of the other Marklin things I own. I can't wait to get the parts I need tomorrow. I'll post pics when it's finished. Thanks again for your help.
Offline TTRExpress
#9 Posted : 06 February 2008 06:25:16(UTC)
TTRExpress
Hi Troy,
Thanks for the reply. I am glad that you were able to use the information and proceed with your layout work. I look forward to seeing the photos when you complete the project.
Offline sudibarba
#10 Posted : 06 February 2008 07:28:24(UTC)
sudibarba
Is the start button a momentary toggle switch?
Eric
Offline TTRExpress
#11 Posted : 06 February 2008 14:52:32(UTC)
TTRExpress
Eric,
It is a momentary toggle or push button switch. I can get you the Radio Shack part numbers for these switches this evening when I get home from work.
Offline emanlooc
#12 Posted : 06 February 2008 15:28:19(UTC)
emanlooc
Maurice
I was looking at SPDTs and found everything from 20 amp to 1 amp. My "Marklin Super" transformer has German writing all over it, which I can't read, but at one point is says 2,0 amps. Does that comma represent a period (2.0)? Should I play it safe and just buy 20 amp switches?
Also, I have an old 451 (7051) crain that also doesn't have a switch. Does that Carl Weaver book also have a diagram for this switch? I was about to start a new thread, but I thought I'd ask you first. I have looked for the book, but apparently it's out of print and selling for $99 used. Thanks again
Troy
Offline Diggum
#13 Posted : 06 February 2008 15:56:52(UTC)
Diggum
THANK YOU for the schematic, Maurice! I've wondered for quite some time how to get my turntable to go (eBay'd with now switch or instructions).
Old Marklin: tough enough to take 3 generations of enthusiastic play.
Offline TTRExpress
#14 Posted : 06 February 2008 17:14:20(UTC)
TTRExpress
Hi John and Eric,
You are very welcome and glad to have been of some assistance. The text is listed for sale on Marklin's web site http://www.marklin.com/newprod/special_items.html
You could also try calling the Roman or Rey at Reynaulds in Elburn, IL they may still have some copies of Carl Weaver's book also.
In Germany the comma represents a decimal point so 2,0A = 2.0A. I can check my Carl Weave book this evening when I get home and get back with you on a switch for the crane. I think you could use another SPDT type. You could also call a Marklin dealer and see if they have a compatible switch that comes with the newer model cranes. I will also list the Radio Shack part numbers of these switches and buttons so you know which ones to purchase.
Since turntables operate from the AC accessory outlets of your transformers I wonder whether you could even use a Fleischmann 6910 turntable controller which retails for around $37.00. This controller is used for their DC turntables. Maerklin's 7286 turntable was a joint venture with Fleischmann so this controller may work?? Maybe the controller for the Maerklin 7286 would work for the 7186??
Train electronics are so much fun especially when we have to improvise. I think that the newer digital controllers would also operate the turntables and cranes however they are much more expensive. Enough of my rambling.......I will post the SPDT part numbers etc. this evening.
Offline emanlooc
#15 Posted : 06 February 2008 18:30:20(UTC)
emanlooc
Maurice
You are so right about the fun of train electronics. I have a box of old track, a "Super Transformer," the crain, the turntable, and an "S" series starter set from the '70s. My dad picked it all up back in the '70s as un upgrade from his Tyco set, but never completed a set-up because he got busy with life. I dug it all up a few months ago to have a train around my Christmas tree. Now, as I get into the workings of the turntable and the crain and the endless track possibilities, I'm hooked.
I mentioned earlier that I have a 7072 switch, but it feels kind of cheap. I have this image in my head of a switch-board I can expand on as I aquire new things. I think I'm just going to make my own switches from now on. Thanks again for your help.
Troy
Offline TTRExpress
#16 Posted : 06 February 2008 19:00:04(UTC)
TTRExpress
Hi Troy,
Thanks for the reply. This train bug does get us hooked. There is always something new to learn and try. I resurrected all my old stuff about 5 years ago and am still building and operating 2 separate layouts. I plan on making a small travelling layout that will fit in the back of a mini-van to take to train shows at some point.
There are lots of exceptional folks in this users forum with superb modelling techniques and experience. You will be able to get all your questions answered here by someone.
Offline TTRExpress
#17 Posted : 07 February 2008 01:23:55(UTC)
TTRExpress
Troy and Eric,
Here are the Radio Shack part numbers for the SPDT, SPST and Momentary On Button:
SPDT # 275-325
SPST # 275-324
Button # 275-1549
You can also choose any brand of equivalent switches from your own electronic supply store.
There are no instructions in the handbook for the crane operation. You can send Maerklin in Germany a request for a copy of the operating instructions for the crane if you have the Crane Model Number. If you have the instructions you can see what type of controller it uses. I would think that either a SPDT or DPDT switch would work for it. If you use a Double Pole, Double Throw (DPDT) then you will want Radio Shack # 275-1533. Your 7072 function controller is ideal for the crane!! If you think it is warped there are a number of them for sale for about $6.00 on E-bay if you search Marklin.
These may be of use to you also.
http://cgi.ebay.com/Mark...geNameZWDVWQQrdZ1QQcmdZV
http://cgi.ebay.com/Maer...dZ1QQcmdZViewItemiewItem
http://cgi.ebay.com/Gree...WDVWQQrdZ1QQcmdZViewItem
Offline emanlooc
#18 Posted : 07 February 2008 16:34:34(UTC)
emanlooc
Ok, I have not been able to get out to Radio Shack yet, but I did have some switches around the house. I took the reset button off of an old computer to be the release button and a pick-up selector switch off of a guitar to change direction. The button worked great, but I could not get the switch to work. I think I know the problem though. Tell me what you think; the switch resembles an STDP with three connections on the back, but the lever on the switch is only two-way, up and down. I know that STDPs have a three-way lever, with off in the middle. With my attempt, I ran the yellow accessory wire to the middle connection on the back of the switch and the two reds from the table ran to the connections on either side of the yellow (just like in the diagram). I had the ground (brown) wire connected to the transformer and the release button from the computer connected, also. The button worked, but the switch did not. Should this switch have worked? Do I maybe have a bad motor on my table?
Offline TTRExpress
#19 Posted : 07 February 2008 17:10:23(UTC)
TTRExpress
Troy,
The wiring to the SPDT is yellow from your light bus or transformer to the middle connection of the switch and the 2 red wires to the outer connections. You need to run the blue wire from the turntable to your start button and the yellow through to the SPDT middle connector. The brown wire goes to ground. Give that a try.
Offline emanlooc
#20 Posted : 08 February 2008 16:14:54(UTC)
emanlooc
IT WORKS!!! Like I said earlier, it's a 410 table, which I read on this board means it's pre-1957. I wasn't sure if it would go. The one problem is that it makes a screaming, whistling sound when it turns, and sometimes it just stops. I oiled the gears on the motor and it sounds like a million bucks. I can put a little pressure on the middle of the rotating track and it connects and works again. The turntable itself is pretty dirty with years of caked on dust. Do you think maybe it just needs a good cleaning?
Offline TTRExpress
#21 Posted : 08 February 2008 18:25:42(UTC)
TTRExpress
Troy,
Superb!! Cleaning the turntable would certainly aid in its operation. Use a soft cloth and an old shaving brush. Some TRIX track cleaning fluid used sparingly would help.
I am happy that your systems are operational and seeing the light of day again!!
Offline emanlooc
#22 Posted : 09 February 2008 05:20:54(UTC)
emanlooc
I bought a project box from Radio Shack, part #270-1802. It's the perfect sized housing for this switch. Right now I have the wires just running out of the box straight to the table. I'm looking into a way to set up a kind of connector on the side of the box so that I can disconnect the wires if I want, similar to the Marklin switch boxes in theory. I was checking out some spring-loaded speaker wire clips that go on the back of speakers. I'll keep looking and see what I find.
I ran the table a few times and it started to sound better. I think a few more laps and it will be fine. Here it is:
Offline TTRExpress
#23 Posted : 09 February 2008 18:26:39(UTC)
TTRExpress
Troy,
Great job!! That is a nice compact box to house switch, button and wiring. Glad it is working well for you.
Nice photos also. Keep us posted.
Guest (4)
This page was generated in 0.581 seconds.
