Offline Gkar
#1 Posted : 08 January 2008 04:40:40(UTC)
Gkar
You have been a member since:: 05/01/2008(UTC)
Hi, all, I have a question regarding the various motors that are in the Marklin engines, in particular, the high efficiency motor, this is a magnet armature with a 5-pole rotor, correct? This is different from the earlier motors that have an electromagnet and a 3-pole rotor, is the 5-pole a better motor? Also, the C-sine motor, how does that differ from the 5-pole, and is it a better motor as well. And, for me, many newer engines are coming with "can" motors, what are these, and how do they compare with the other motors (as far as I can see, the can motors are sealed and require no maintenance, but otherwise?) How do these motors rate to each other? Thanks!
"You know, the very powerful and the very stupid have one thing in common. They don't alter their views to fit the facts, they alter the facts to fit their views. Which can be uncomfortable if you happen to be one of the facts that needs altering."
Offline TimR
#2 Posted : 08 January 2008 08:35:09(UTC)
TimR
Indonesia
Welcome to the complicated world of Marklin motors & welcome to the forum.
The variety of the motors out there do overwhelm many beginners as they begin their hobby as I learnt myself.
In short here are the differences:
3-pole motors - introduced in late 80s and has been discontinued. It is available with many older Delta (34xxx series) and digital locos (3xxx series locos)- largely seen as being more limited in capability compared to the 5-poles.
5-Pole motor - gained popularity at the dawn of high efficiency decoder (C90 type and above) from mid 1990s onwards largely replacing the 3-poles. Most locos with 37xxx digits have 5 pole motors though there are exceptions. By default this is considered to be the most trusty and reliable propulsion for Marklin locos & the propulsion of choice to convert many older Marklin models.
C-Sine motors are the next generation Marklin motor - maintenance free, brushless motor, promising considerably smoother and quieter drive than the previous conventional propulsion (as above) - though they do not as yet completely replaced the old and trusty 5-pole motors yet.
First introduced in late 1990s and early 2000s - most locos with C-Sine motors have Marklin 39xxx serial.
The C-Sine is now in its third incarnation - known commonly as the SDS.
Can motors are basic motor type (commonly used in many hobby modelling) to equip the entry level Marklin 36xxx locos. They are equipped with "basic" digital decoders - which apparently are quite competitive in its smoothness to the 37xxx or the 39xxx.
Generally you can't just isolate a motor on its own. What digital decoder that comes with the motor largely influenced the characteristic of that motor. Generally you would want a high performance decoder (type C90) or the latest generation MFX for superior driving characteristic.
That is basically the gist of it. I'm not an expert of course, but if you search around the forum, there are lots of more detailed information in regards to each type motor with their advantages, and limitations.
Now collecting C-Sine models.
Offline Lars Westerlind
#3 Posted : 08 January 2008 09:14:16(UTC)
Lars Westerlind
Yes,
for the first decades of my lifetime there where only 2 different types of Märklin-motoros - small and large. We call them SFCM and LFCM; Small Flat Commutator Motor and Large. LFCM fitted in larger wehicles, draw more current and was more powerful. They where both 3 pole with electromagnetic field coil. The field coil could be replaced by a permanent magnet that is still available, called HAMO, as it was used in Märklins DC series of locos. I doubt these types are present in new locos, certainly not in new toolings, but they have remained in old toolings for a long time after. I think I bought one 10 years ago.
Then came DCM, Drum Commutator, where the brushes don't stick axially but radially. This was also 3 pole, I think this is what TimR thinks of as "late 80s". There was also a 5 pole analog motor at this time or earlier, that I think should be regarded as dead end, possibly with the loco number 35xx.
The "hight efficiency motors" 37xxx and c90, had the same measures as DCM, and could replace such a loco. Could/Can, still available to some extent. It containted a strong permanent magnet, a suitable reliable decoder, and a 5 pole motor. IMHO, the first two components are more important then the latter.
The CAN motors, IMHO are mainly used in models development at other places than Göppingen; at Trix or at special models not developed by Märklin themselves. Possibly also as experiments. There are also "special motors" in a few very small models, and another creme a la creme - motor: the bell armature / Faulhaber type /Coreless ones, a bit expensive.
It's very true that the decoder is more important that the motor; it may be able to compensate for bad behaviour of the motor. The motor choice of course is important for noise, power consumtion and such.
I personally avoid locos that don't have speed regulation; field coils is also avoided (and not very present at new models). 37xxx, 39xxx are secure, and the 26xxx sets. Delta is avoided (if you can afford), but not without exception. There are good Deltas as well. C-sine I guess is good; I only have one, a SDS with very good running characteristics, little noise etc. mfx is a little shaky, but I think the initial problems may have been overcome by now; they were sensitive to dirt on track, bad M-tracks etc.
/Lars
Offline Gkar
#4 Posted : 08 January 2008 15:22:02(UTC)
Gkar
Thanks again for all the info! IS ther a way to tell which decder type you have in an engine? Is it marked on the board, or is it just a matter of looking up the engine number on a list?
Offline MARKLIN LOVER
#5 Posted : 08 January 2008 16:36:14(UTC)
MARKLIN LOVER
This is fantastic info, thanks all for this, it clears alot for me a MARKLIN beginner!
Keep em on the rails!
Ivan!
#6 Posted : 08 January 2008 16:38:45(UTC)
Lars Westerlind
This forum ;-)
In the past you could more or less know what you bought, if you had the catalog. We now live in modern times... :-(
There is no systematic ways to know all, but several things anyway. Article numbers give a great deal, and conclusions may be drawn from what they write, but not without exceptions.
/Lars
#7 Posted : 08 January 2008 23:57:30(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Gkar
<br />Thanks again for all the info! IS ther a way to tell which decder type you have in an engine? Is it marked on the board, or is it just a matter of looking up the engine number on a list?
Often you can tell the decoder type from the article number (ref. number) - there are some exceptions like 30000 (Delta or fx decoder (PIC)) or 37724 (6090x fx decoder, later mfx decoder) or 37652 (6090x fx decoder, later PIC fx decoder).
37xx locos have the 6090 decoder.
36xx locos should have the 6080 decoder.
37xxx locos normally have the 6090x decoder, but some have the 6090 decoder.
Offline Falconrep
#8 Posted : 09 January 2008 00:23:57(UTC)
Falconrep
Just for the beginner, another effect with hte different motors is an effect known as cogging. This has a lot to do with how slow a motor can turn and how choppy they end up. a 3 pole motor is the worst of the Marklin motors for cogging. This is because the rotor must "jump" from one pole to another. and being only 3 poles the jump is far. this is cogging. soe in order to keep the engine moving these jumps are spaced widely and when a loco is going very slow, you might even be able to see these jumps which look like small start and stops. These flat commutator motors are indestructible. I have one working from 1935! The 5 pole motor improves on start up by making the jumps smaller because ther are 5 poles and shorter spacing. This results in a smoother look and slower speeds can be attained. The C Sine motor has 12 poles, again more poles, smaller jumps. Very smooth operation. Can Motors, can have as many poles as the manufacturer feels necessary, they are cheap to produce and have reasonable life expectancy but are generally not rebuildable like their Flat commutator brothers. They may have replaceable brushes. But usually that is all you can do with them. One way to produce a better start effect in a rotor is by making a skewed armature, this is done by stacking the rotor elements rotated slightly one to the next, giving the rotor a spiral look, in a 5 rotor skewed armature the cogging effect is less noticeable because the distance from the rotating element to the field is reduced by the skew.
I only have one C-Sine powered loco, a Taurus and it runs magnificently. But for shear reliability I like the old flat commutators, besides, I'm playing with toys here, they don't need to mimic reality too closely. Do they?
Thomas Wondrock
#9 Posted : 09 January 2008 02:17:03(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Falconrep
<br />a 3 pole motor is the worst of the Marklin motors for cogging. This is because the rotor must "jump" from one pole to another. and being only 3 poles the jump is far.
I have a 3 pole motor with HAMO magnet and ESU decoder - and the loco does a very good job at slow speeds.
3 pole motors in analog, Delta, or 6080 locos really behave badly.
Offline Gkar
#10 Posted : 09 January 2008 04:09:19(UTC)
Gkar
So Falconrep, when you say you like the flat commutator type, I assume you are speaking about the 5 pole type, correct? insofar as they can work with digital decoders, whereas the 3 pole cannot...
#11 Posted : 09 January 2008 04:57:44(UTC)
Gkar, it is not quite correct to say the 3 pole motors cannot work with digital decoders. The ESU decoders can work with a conventional AC motor, but you do not get any load regulation with that setup. By changing the AC coil for a HAMO permanent magnet you get the benefit of load regulation. This is by far the simplest conversion, as not as many parts need to be changed as for the 5 pole upgrade. I know RayPayas, h-Zero and others use this configuration, and it can be useful where an older model will not take a full 5 pole upgrade.
Other types of decoders that can work with AC motors includes the PD101:- http://www.pd101.com/e/pages/index.asp
#12 Posted : 09 January 2008 10:07:53(UTC)
I can testify to that.
The SFCM 3 pole motor with a lokpilot V3 and Hamo magnet is not quite as smooth as a full 6090x conversion, but it is about as good as a 60760 conversion on a DCM motor.
The cogging effect mentioned above by Thomas is noticeable on some loks, but it depends very much on the gearing. I have an E 32 Primex model converted with the Hamo + lokpilot combination which is super smooth crawling along at minimum speed.
Offline Falconrep
#13 Posted : 11 January 2008 10:11:52(UTC)
Falconrep
I guess I really didn't specify, when I said I liked the Flat commutator, but I think out of my 100+ locos, mor ethan 50% are 3 pole flats, have not been converted to digital and I operate them (when I atually operate at all) I run them conventionally. Whether the 3 poles can be made to operate digitally isn't really a point here, as I think the 3 poles work fine for toys which is what they are. But technologically I like the C-sine, I like to stay open to technology but stay dirmly grounded in tradition.
Thomas Wondrock
#14 Posted : 11 January 2008 11:10:30(UTC)
Lars Westerlind
<br />So Falconrep, when you say you like the flat commutator type, I assume you are speaking about the 5 pole type, correct? insofar as they can work with digital decoders, whereas the 3 pole cannot...
No problem to run 3 pole in digital. It's removing the field coil and replace it with hamo magnet that is important.
For my standard, any conversion that uses a decoder which have a speed regulation and automaticly maintains also slow speeds, are good enough. This is easiest to do with permanent magnet motors of the traditional ones; C-sine with variations has it "built in".
Then there ARE differences also among the "good enough". I do like the motors that have "spiral shaped" magnet; Roco has one 5 pole, and Märklins SDS also. I think that this reduces the cogging more than the increase from 3 to 5 poles, and possbly even 12. But C-sine may also appy power to the motor in a smother way, so perhaps cogging can be avoided totally has with a straight C-sine.
The main problem with cogging AFAIU is not that the running is bad; I doubt you may notice this by eye. I think the main problem is the sound that is generated and easily amplified by resonance if you are unlucky.
/Lars
Offline banco
#15 Posted : 11 January 2008 11:53:57(UTC)
banco
There is one minor piece of advice I feel I can add. The motor plate, brushes and its state of repair make a difference to the running of a digital conversion. Cleaning and new brushes go without saying but, I find it is important to ensure that the brushes sit well on the commutator, eg at 90 degrees and with little "play " within the brass container . If this is attended to well, it can maximise the smoothness of running and allow the decoder to do its job of regulation well. Check the condition of the motor plate well don't assume that a brand new one will be fine. It seems to be a weak point of Marklin as to the set up of anew plate. I find most need a little attention before they will give their best even new ones!
C track,6021,large digital loft layout modelled in the legendary European land of "Moresnet"
Offline Gkar
#16 Posted : 11 January 2008 22:24:29(UTC)
Gkar
I purchased the stater set ICE 2 which has a can motor, and I noticed that it seems to "cog", particularly at slow speeds, but even at modest speeds I can hear the engine (more than visually "see" the hesitation) of that engine "cogging" or stuttering on the track. Any ideas or comments?
This page was generated in 1.112 seconds.
