Offline Sander van Wijk
#1 Posted : 03 November 2007 23:11:11(UTC)
Sander van Wijk
It seems like I have a problem with my ESU Lokprogrammer. As of the moment I've installed the new firmware into my Lokprogrammer it is not capable of reading (or even recognizing) any of the ESU Lokpilot MFX or Loksound MFX decoders. (I've tried this with four different decoders, using the 21-pole plug, the 8 pole plug and a hard wired one.) It functions perfectly with non-MFX decoder though...
I'm using software version 2.6.5. at the moment, downgrading to software version 2.5.6. results in errors, probably due to the fact that I can not downgrade the firmware version anymore.
Anyone else experiencing the same kind of troubles?
Good evening!
Sander
Offline pa-pauls
#2 Posted : 04 November 2007 00:10:41(UTC)
pa-pauls
Hi Sander Smile
This is interesting as I was thinking of getting a Lokprogrammer to program just mfx decoders wink[:p]
Was the ESU Lokprogrammer easy to use and program before you got this problem confused English software confused
Sorry that I can't help you with your problem do [:I]
Pål Paulsen
Offline rschaffr
#3 Posted : 04 November 2007 01:15:37(UTC)
rschaffr
I was using mine just the other night to program a Marklin mfx decoder. I'll have to go down and check the softare version.
-Ron
#4 Posted : 04 November 2007 01:26:56(UTC)
Sander van Wijk
[size=1" face="Verdana" id="quote]quote:Originally posted by pa-pauls
<br />Hi Sander Smile
It was working well and was fairly easy to use. English software is included. Shortly it will be working again, I presume, the question remains (for now); how?
Sander
Offline rschaffr
#5 Posted : 04 November 2007 02:41:33(UTC)
rschaffr
Ok. Mine is also at 2.6.5. It recognizes and works fine with the mfx decoder in my Unicef lok, but won't read the decoder in my new BR05 insider. Interesting. Sander: I would recommend reloading the software update and trying again.
I would bet that if I pulled the decoder out of the '05 and put it on my 21 pin adapter it would work (as did my Scheinenbus), but the '05 is running perfectly and there is nothing I care to change, so why take the chance of messing something up?
-Ron
Offline renevoorburg
#6 Posted : 04 November 2007 08:41:49(UTC)
renevoorburg
[size=1" face="Verdana" id="quote]quote:Ok. Mine is also at 2.6.5. It recognizes and works fine with the mfx decoder in my Unicef lok, but won't read the decoder in my new BR05 insider. Interesting.
That is documented by ESU. It is cause by electronics on the C-Sine board:
"Ich habe eine Lok mit mfx-Decoder und C-Sinusmotor. Leider lässt sich diese mit dem LokProgrammer nicht auslesen. Es erscheint immer eine Fehlermeldung. Was ist zu tun?
Die in der Lok verbaute Steuerelektronik des C-Sinusmotors stört die Kommunikation zwischen LokProgrammer und mfx-Decoder. Abhilfe ist nur möglich, indem Sie den Decoder aus der Lok ausbauen und direkt mit dem LokProgrammer verbinden. Sie müssen hierzu nur die beiden Schienenausgänge des LokProgrammers direkt mit dem Decoder verbinden, weitere Leitungen sind nicht nötig."
Cheers, René - whom Sander was trying to help when he came across this issue -
Offline pa-pauls
#7 Posted : 04 November 2007 13:58:44(UTC)
pa-pauls
Thank's Sander,
I will look out for one on eBay
Pål Paulsen
Offline DamonKelly
#8 Posted : 04 November 2007 15:54:54(UTC)
DamonKelly
I just tried my installation:
LokSound Programmer 6.2.5
LokProgrammer Firmware 0.0.1447
I think these are the newest.
It reads my mfx LS decoders correctly.
Damon
Offline Hemmerich
#9 Posted : 04 November 2007 22:54:07(UTC)
Hemmerich
Hi Sander,
I'm using the LokProgrammer with Firmware version 0.0.1447 and Software 2.6.5 (thus both the most current ones); I didn't have any problems in getting those installed and working.
Have you tried to reload the firmware again?
One more info: When I could not read a mfx decoder directly out of the loco in the past, I moved it to another loco with less "disturbing electronics for the programmer". Now I'm mostly using the new "Profi-Prüfstand" and I also didn't encounter any problems so far with that (other than it doesn't have a SDS motor biggrin); it also works fine with the CS.
Following two pics showing it while testing a LoPi-mfx3.0.
Hope you can get your LokProgrammer working again soon (if not you might have to send it to ESU). wink
Offline pa-pauls
#10 Posted : 05 November 2007 00:42:36(UTC)
pa-pauls
Hmmm Cool
Was thinking a little bit, yes a little bit, don't worry [:I]
Maybe a stupid question but anyway : [B)][V]
If I hook up my computer to my CS is it then possible to program a decoder without the Lokprogrammer confused
Pål Paulsen
Offline Hemmerich
#11 Posted : 05 November 2007 01:08:31(UTC)
Hemmerich
Hi Pål,
you don't even need the CS for that - unless you want to modify a mfx decoder - as there exist already several SW programs doing just that. wink
#12 Posted : 05 November 2007 08:44:05(UTC)
renevoorburg
Lutz, thanks for your thoughts on this issue
I am sorry for all the troubles. Sander, I should have told you that my BR50 has been cursed by Murphy wink
[size=1" face="Verdana" id="quote]quote:Have you tried to reload the firmware again?
That sounds like a viable option to me. Hope it works.
René
#13 Posted : 05 November 2007 15:29:03(UTC)
Sander van Wijk
Thanks for all your interesting replies, I'll have time to check the results of your suggestions this Saturday.
If anything else pops up, please let me know!
Sander
#14 Posted : 09 November 2007 16:09:17(UTC)
Sander van Wijk
Update: after a renewed firmware update it is still not working, tried it (again) with different decoders and locos. I'm starting to believe it is truely a hardware failure. ;-(
Sander
#15 Posted : 09 November 2007 16:28:14(UTC)
renevoorburg
[size=1" face="Verdana" id="quote]quote:Originally posted by Sander van Wijk
<br />Update: after a renewed firmware update it is still not working, tried it (again) with different decoders and locos. I'm starting to believe it is truely a hardware failure. ;-(
Not much other options left, I think. Sorry to hear. [:(]
I wonder how such a thing happens. Hope that ESU can help you out.
René - feels slightly guilty -
Offline pa-pauls
#16 Posted : 09 November 2007 19:06:44(UTC)
pa-pauls
Hello Sander Smile
Sorry to hear this [:(]
Did it work i.e. could you read mfx decoders BEFORE you did the firmware update confused
Maybe it is a software bug in the new firmware or is your lokprogrammer hardware to old confused
I would ask ESU about this [}:)]
Otherwise I agree with you that is most likely is a hardware failure as Lutz, among other's, have done the same without problem wink[:p]
Pål Paulsen
#17 Posted : 09 November 2007 22:09:34(UTC)
Sander van Wijk
It did work properly a few weeks ago. In order to be sure about that, I took the last loco equipped with an MFX decoder that was programmed successfully. Currently, it shows the very same error as all other MFX decoders do...
Anyhow, I'll keep you informed!
Sander
#18 Posted : 09 November 2007 22:21:04(UTC)
Sorry to hear that, Sander.
#19 Posted : 20 November 2007 10:07:25(UTC)
Sander van Wijk
Short news: Luckily, I was able to borrow a friends' lokprogrammer, it is equipped with a lower firmware version and works properly with my computer. So, it seems like the programmer itself is causing the troubles, either due to the software (firmware version 0.0.1447) or a hardware issue. I've send an email to ESU support explaining the problem, let's see what happens...
Sander
Offline pa-pauls
#20 Posted : 20 November 2007 10:10:22(UTC)
pa-pauls
Hello Sander Smile
Have just got a lokprogrammer on eBay biggrin
Will I then get the same problem you think confused[:I]
Pål Paulsen
Offline Hobbit
#21 Posted : 28 November 2007 04:25:09(UTC)
Hobbit
I have read this topic with interest, and it reveals something I do not understand. Some time ago I took one of my Marklin MFX locos to a friends place where his LokProgrammer could not recognise the decoder, so we cold not change anything. However it has worked for him with other ESU decoders such as LP3. From this we concluded that the LokProgrammer could not change Marklin MFX.
However from the above discussion it would seem that the LokProgrammer can change Marklin MFX, except in some configurations. Is this correct? If it is correct then which situations cause it it not work?
PS: We were able to change setting with a 6021 so the decoder is not faulty.
There is no place like The Shire...
Offline Omo
#22 Posted : 15 December 2007 23:24:55(UTC)
Omo
I have just put the below contribution on another similar topic. It might be helpful here also.
I have actually managed to program my BR 01 (Mä 39015 with a compact sinus motor and mfx decoder) with my Lokprogrammer several times. When programming, the program sometimes show a fault message - however, mostly the programming is done anyway. If not - just try once more. The newest software for Lokprogrammer seems to do it better.
I have been told by ESU/Loksound that the problems lies with the sinus motor electronics. This is why they advice you to take the decoder out and connect it to a test bench or another non-sinus motor. A mfx decoder controlling an older motor should work well.
#23 Posted : 16 December 2007 13:10:11(UTC)
welcome to the forum, Omo.
#24 Posted : 16 December 2007 19:08:36(UTC)
I have heard and seen that ESU lokprogrammer is not suitable for mfx decoder...
I wonder if you should choising Marklins own mfx decoder instead...?
Because,they are already finished programming decoder such like sounds and other functions too...!
Goofy confused
Offline Hemmerich
#25 Posted : 16 December 2007 19:38:12(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by Goofy
<br />I have heard and seen that ESU lokprogrammer is not suitable for mfx decoder...
Wrong! (whoever told you that). Cool
Please see the list of decoders supported by the LokProgrammer here or read version 5 (Nov. 2007) of the LokPilot handbook:
http://www.loksound.de/index.php?showId=276
[size=1" face="Verdana" id="quote]quote:I wonder if you should choising Marklins own mfx decoder instead...?
Any ESU sound decoder comes preinstalled with a specific loco sound which you can order and even customize with own sounds as desired, whereas Märklin sound decoders are offered as spare parts, mostly not even orderable and not customizable with own sounds. ESU sounds are available as project files; Märklin sounds are not (yet). wink
This page was generated in 0.569 seconds.
