Offline charles Sharpe
#1 Posted : 12 December 2007 20:40:45(UTC)
charles Sharpe
Hello All
I have some K track sidings next to my round house and I would to know what sort of track ballast looks good. Smile
CHARLES SHARPE
#2 Posted : 12 December 2007 21:01:33(UTC)
The stuff made by Merkur/Noch is good
Offline rschaffr
#3 Posted : 12 December 2007 21:13:00(UTC)
rschaffr
I use Woodlands "Gray Mix"
-Ron
#4 Posted : 12 December 2007 21:24:55(UTC)
Just to spread things about I use Busch.
David
Offline hmsfix
#5 Posted : 12 December 2007 23:04:10(UTC)
hmsfix
Depends on your taste, and on the prevailing colors of the environment of your tracks. I mainly use an ocher-brown ballast with a grain size of 1-2 mm, as usually recommended for H0 (from Vollmer, but you can use anything). This is mixed with a finer (i.e. 0.5 mm) black ballast (on the coal yard), or with fine yellow/gray sand as used for aquariums. The mixing ratio of the ballasts varies rather strongly.
Hans Martin
P.S. Usually it is recommended to use a more or less constant grain size to achieve a realistic look of the ballast. IMHO, a mixture of ballasts with different grain sizes, each species with another color, gives good results, too. And it helps to disguise the pukos a little.
Offline PierreGILLARD
#6 Posted : 13 December 2007 01:10:36(UTC)
PierreGILLARD
For less used sidings, you may also add some grass to the ballast as I did for the tracks next to my roundhouse.
Pierre.
Click on the picture !
Offline perz
#7 Posted : 13 December 2007 01:24:52(UTC)
perz
I haven't used K track on a layout, but I have made some experiments. My conclusion is that "H0" ballast is usually to coarse. When I tried "N scale" ballast it looked much better. Of course the grain size vs recommended scale can be different between different brands, but 1-2 mm as proposed in a previous post is too coarse to be to-scale if you want to model normal ballast. I think 0.4 - 0.8 mm would be more accurate. But real life also has a lot of variation so there is no absolute truth.
#8 Posted : 13 December 2007 01:39:17(UTC)
Nice web-site and roundhouse, Pierre!
Thanks again for the inspiration.
#9 Posted : 13 December 2007 11:31:50(UTC)
I use Friskies Aquarium decoration sand.
After painting it with brown, gray and black acryllic washes it looks pretty good. -and it is dirt cheap.
Offline al_pignolo
#10 Posted : 13 December 2007 11:37:20(UTC)
al_pignolo
I use grey ballast (produced by "linea secondaria", a small italian company). Whatever colour, size, brand you choose my tip is to wheater it!!! wink
Pietro
Offline RDRBerry
#11 Posted : 02 January 2008 18:45:52(UTC)
RDRBerry
[URL=http://img242.imageshack.us/my.php?image=dsc7664aa6.jpg][IMG]http://img242.imageshack.us/img2
Ralph
HO digital ,Intellibox and 6021
Offline RDRBerry
#12 Posted : 02 January 2008 18:55:53(UTC)
RDRBerry
Sorry posted before text.
Finer N gauge ballast seems to work best. The above is Erbert pukos on peco points [older locos cannot go through these] and then peco stud strip on peco track.
I needed the curved points at this spot.
The challenge next is to try and find a way to ballast the K points without ruining the mechanism.....
UserPostedImagee
Ralph
Offline rschaffr
#13 Posted : 02 January 2008 20:25:12(UTC)
rschaffr
I never ballast turnouts. I print a gray stone pattern on paper and cut it out for under the turnouts.
-Ron
Offline ulf999
#14 Posted : 02 January 2008 21:08:18(UTC)
ulf999
I haven't done turnouts yet, but WS HO ballast is fairly ok. Here is a pic with Peco Code 83 with Herbert stud stip.
(https://www.marklin-users.net/forum/default.aspx?g=posts&t=3742&whichpage=5)
Offline RDRBerry
#15 Posted : 02 January 2008 21:09:12(UTC)
RDRBerry
That sounds sensible.I have some styro plast sets which are fine, just the wrong colour...
There is some abrasive sheet that looks near..
Ralph
Offline RDRBerry
#16 Posted : 02 January 2008 21:33:28(UTC)
RDRBerry
Any good sources for Erbert stud strip...Its loads easier to set up than peco...
The points are very clever , need a bit of adjusting, and so far I have a few locos that 'ground' on them, however once set up, and wired with motors I am going to profile the pukos.
Erbert is in my opinion a very good set up.
Ralph
Ralph
Offline rschaffr
#17 Posted : 03 January 2008 04:35:26(UTC)
rschaffr
Here is an example of what I meant about the stone paper under the points:
[image]http://www.sem-co.com/~rschaffr/trains/images/switch_ballast1.jpg[/image]
[image]http://www.sem-co.com/~rschaffr/trains/images/switch_ballast2.jpg[/image]
The area around the turnouts are not yet landscaped, so it looks a little bare.
-Ron
Offline RDRBerry
#18 Posted : 03 January 2008 23:28:26(UTC)
RDRBerry
I like that idea, Marklin points have too may delicate parts to pva ballast..
I am looking at this as a way to keep the continuity of colour..
Thanks for the tip !
Ralph
Offline kbvrod
#19 Posted : 04 January 2008 01:33:30(UTC)
kbvrod
I'd go with the Merkur/Noch,...so easy,...points too!
Dr Dirt
#20 Posted : 04 January 2008 01:54:57(UTC)
Great to see you back on track, Kevin! Smile
Offline kbvrod
#21 Posted : 04 January 2008 02:04:55(UTC)
kbvrod
<br />Great to see you back on track, Kevin! Smile
Tank you oh great,wise Webmaster!Cool
#22 Posted : 04 January 2008 02:58:05(UTC)
yes good to see you here Kevin.... BTW your profile says you are 14 years old. The dirt making the clock go backwards....
Offline kbvrod
#23 Posted : 05 January 2008 00:18:36(UTC)
kbvrod
Hi Dale,all
[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz
<br />yes good to see you here Kevin.... BTW your profile says you are 14 years old. The dirt making the clock go backwards....
Thanks,you make me feel young again,....wink
"Old dirt never dies,it's just used on a layout."
Dr Dirt(in person)
Offline nfotis
#24 Posted : 05 January 2008 00:39:52(UTC)
nfotis
Regarding ballast inside turnouts, there is a trick another Greek modeler showed us (I do not remember the exact details, sorry):
you cut a piece of transparent plastic sheet and insert it under the turnout, covering the mechanical parts. You fix the plastic piece with track fixing pins (I think, my memory is a bit hazy there)
You ballast as usual, and take care to leave not even one grain fouling the blades when moving (a small paintbrush helps here)
you remove the transparent sheet *after* you paint the rails.
I will try to arrange for a demo our local expert, in order to shoot some photos and show how it was done.
N.F.
Offline Macfire
#25 Posted : 06 January 2008 00:03:08(UTC)
Macfire
I'm going to use double-sided foam tape for the track, ballasting made easy.
And black builders paper (tar paper) under the working parts of the turnouts.
Lord Macca
Offline kurtjr
#26 Posted : 06 January 2008 01:20:36(UTC)
kurtjr
Noch also makes another ballast which is more flexible than the Merkur one, it's called Moessmer Ballast and you can get it in rolls of 5m for a reasonable price. Colors are gray or brown. For the switches you can buy already premade ones as well which fit the k-track motor as well.
Kurt
All SBB's, SNCF and US/CDN model's.
This page was generated in 1.176 seconds.
