Hi I need a sanity check from the electonic experts... Topic 1. I have long wished for LED bulbs that can be screwed into the standard Märklin light bulb sockets and now Adarsh is making them. See http://www.trainaidsa.com That is great. The problem I foresee, however, is that while each light has its own resistor, there is no room for a diode to prevent damage due to the reverse current that is present if the light is supplied with AC. In a digital loco it is not a problem because lights can be supplied with DC current from the decoder, one just needs to ensure that the polarity of the light is correct. In non digital situations however, (such as street lamps or ananlog locos) there will be 16V running both ways through the LED. I believe that typical maximum reverse voltage for LEDs is 5 Volts. The LED can probably withstand 16V reverse current for short periods so my question is this: Are the periods when the 5V reverse current is being exceeded short enough to not destroy such LEDs? I also suspect that even if the LEDs manage to survive the 50 or 60 Hz reverse current, this environment will drastically shorten their life span. The solution of course is to insert a diode into the circuit to prevent the reverse current but that is not always possible, nor obvious to people if they think they can simply replace the old light bulb with the new one. Tim Eckert, who is selling them on eBay claims that since an LED is a type of diode, no diode is needed but my understanding is that LEDs have a very much lower reverse current rating than sat a 1N4148 or 1N4001. Opinions ? Topic 2 Adarsh is also selling some very nice looking LED strips for interior lighting. I have tested them and they look very promising. The strips have multiple sets of 3 LEDs, each set containing a 130 Ohm series resistor. Using my LED circuit formuli, this tells me that such strips should not be supplied with a voltage greated than 13V as that would put more than 30mA through the LEDs. Current measurements confirm that at about 12V about 23mA is passing through the LEDs and I therefore belive that these strips have been designed for 12V usage. Tim claims to have tested the strips at 20 Volts. I calculate that at 20V the LEDs will have 84mA passing through them. LEDs typically have a maximum forward current of 30mA. Am I crazy or will these things not last long with supply voltages above 13V ? (OK I probably am crazy but still...) |
Joined: 10/09/2004(UTC) Posts: 959 Location: Copenhagen, Denmark
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz <br />In non digital situations however, (such as street lamps or ananlog locos) there will be 16V running both ways through the LED. I believe that typical maximum reverse voltage for LEDs is 5 Volts. It all depends on the LED's used. Some is very vulnerable already at 5-6V reverse voltage. Other types can go much higher without problems. The only way to tell for sure is to find the exact LED type used, and then have a look in its datasheet. I always throw in a diode just to be on the safe side. But I can see your problem with the ready-made screw-in type bulb. Quote:[size=1" face="Verdana" id="quote]quote:Are the periods when the 5V reverse current is being exceeded short enough to not destroy such LEDs? If of a type that can't tolerate high reverse voltage, I would say no. It may last substantially longer than pure reverse DC, but most likely also considerably shorter than what is to be expected. Quote:[size=1" face="Verdana" id="quote]quote:Tim Eckert, who is selling them on eBay claims that since an LED is a type of diode, no diode is needed but my understanding is that LEDs have a very much lower reverse current rating than sat a 1N4148 or 1N4001. Again, it all depends on the LED in question, or rather what process has been used to produce it. Quote:[size=1" face="Verdana" id="quote]quote:Tim claims to have tested the strips at 20 Volts. I calculate that at 20V the LEDs will have 84mA passing through them. LEDs typically have a maximum forward current of 30mA.
Am I crazy or will these things not last long with supply voltages above 13V ? (OK I probably am crazy but still...) Once again, it will depend on the LED. You are absolutely right that standard LED's are 30mA max. But other LED types do exist. I have some rated at 80mA, but only if mounted on a board where the copper tracks are designed to carry away a certain amount of heat. But if that is the case, they are so bright that I would never dream of putting them inside anything on my model layout, with the possible exeption of big floodlights at a football stadium  I would just replace the resistors on the strip with some of a more suitable value.
Thanks.
the LEDs on the strips are surface mounted but I don't know the manufacturer so don't know what data sheet to look for. I'll ask Adarsh is he can get that info.
The resistors are also surface mounted so difficult to replace.
For station lighting they are probably ideal as I have 12V Dc available, but I think for interior lighting of wagons a 12V regulator may be in order... |
Joined: 06/02/2005(UTC) Posts: 1,383 Location: Darmstadt,
Hi Dale, I fully agree with what Mikael has written: Using the LEDs with 16 V AC should is not recommended. I had a view on the respective www.trainaidsa.com web page, and my impression is that their LEDs don't have any special protection against a reversal breakthrough, they are just standard types. Why else do they offer a special rectifier for using the LEDs with AC voltages ? IMHO the only safe method is to use an extra rectifier diode (1 N 4148, 1 N 400x or so) in the circuit. Hans Martin
Joined: 19/10/2001(UTC) Posts: 2,379 Location: Lindome, Sweden
If two or three LEDs can be used, they can simply be mounted parallell in different directions. /Lars
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz <br />The resistors are also surface mounted so difficult to replace. Actually, I find surface mount resistors easier to replace than leaded. It takes a bit of practise and a steady hand, but then it takes no time. One other thing about running LED's from AC is the flickering. I can't stand the 50/60 Hz flicker that will cause. Two diodes in anti-parallel gives 100/120 Hz and is much better, but you can't beat DC
Joined: 16/02/2004(UTC) Posts: 15,463 Location: DE-NW
Please note that with 16 V AC the diode will get a maximum voltage of 16 * sqrt(2) = 22.6 V (can easily reach 24 V if the transformer load is low).
I'd use them with AC only if the producer specifies them for AC operation.
EDIT: looked at the homepage - the resistor was calculated for 12 V DC, but they claim they work with 12 through 18 V DC ...
Using a rectifier as recommended will secure the LED from reverse voltage, but will also supply twice as much forward current.
Silicon semiconductors get damaged if the silicon gets too hot. I think I'd use 7812 voltage regulators to be on the safe side. |
 1 user liked this useful post by H0
Tom, just to be clear...
I think his web page states designed for 12V because I have suggested that to him.
I think a 7812 (plus caps) is indeed called for for the interior lighting, but that will produce some heat which needs to be dissipated and will require some space.
Mikael, I agree with flickering, (especially for lights in a train that will be moving) and is why I run 12V DC for stationary lighting. I also think interior lights need a capacitor to prevent flicker from momentary power losses. |
Joined: 02/10/2007(UTC) Posts: 153 Location: Surrey, England
Wouldn't it be the easiest solution to use a DC power source for all lighting? Even if not all conventional bulbs are yet exchanged with the new LEDs, they won't mind running on DC instead of AC, would they? Using a DC control transformer even delivers the additional charm of a dimmer...
Regards, Arthur
Arthur that is not the point. The point is that these are being advertised as replacements for AC bulbs - such as in analog locos. In that situation DC is not available.
Next, for interior lighting, whether it is analog or digital, rail current is not DC (in the context of Märklin) so those also have to be rectified and the components on the light strips wont handle the current in my opinion.
On my layout I use a 12V DC supply for stationary lighting. Inside rolling stock I will always ensure that LEDs get fed DC power and not more than 25mA current. |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz <br />I think a 7812 (plus caps) is indeed called for for the interior lighting, but that will produce some heat which needs to be dissipated and will require some space. To reduce heat you could use 7815 or even 7818 and put more LEDs in series (you couldn't use their strips for that configuration). Will there be one 7812 per car (no heat problem) or per train (potential heat problem)? |
good point, since the heat is related to the load it would make sense to place one on each car (given space) |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz <br />good point, since the heat is related to the load it would make sense to place one on each car (given space)
There's an 0.1 A version of the 78xx series with a TO-92 casing (transistor size) - not sure if you can hide it in the toilet ... |
Hi, Here comes another proposal using LEDs with AC. The highest reverse voltage that can occur at each diode is limited to the forward voltage of the other one, and that's safe, too:  Hans Martin
 1 user liked this useful post by hmsfix
Joined: 26/03/2006(UTC) Posts: 1,423 Location: Brisbane, QLD
Excellent suggestion Hans Martin! Dale: Note that you'll still get "flicker", but it won't be as noticeable - especially if the LED's share the same light diffuser. The TO-92 versions of the regulators are usually called 78Lxx. Also note that there are plenty of linear regulators in tiny surface-mount packages (eg. SOT-23, or the even smaller SC-70) but they need careful mounting. Flying leads, a blob of non-acidic silicone glue and some heatshrink is very effective. About input rectifiers: Indeed most linear regulators don't like negative inputs, but since the Märklin "AC" signal is chopped ±18Vdc, a simple bridge rectifier with a very small capacitor would provide a good enough source for most regulators. Actually, I just re-read the data sheet for the LT1121 series, and noticed it is available in TO-92. This regulator tolerates negative input voltages (but obviously won't regulate them). You could use a LT1121CZ-5 with no input bridge rectifier or capacitor at all, and get a tolerable 5Vdc output. You'll still need at least a 330nF output capacitor, but they're tiny now-days. I'd try and fit at least 1µF. Just solder one (or more) across the legs as you have done before. Linear Technologies have an on-line store (using credit cards), so you could order LT1121CZ-5 (5V, commercial temperature range) or LT1121IZ-5 (5V, industrial temperature range), or LT1121CZ-3.3/ LT1121IZ-3.3 for the 3.3V versions. |
Cheers, Damon |
Dale, I just remembered that you want to power your LED's from 16Vac, so tha comment about Märklin digital being ±18V is not relevant [:I][:I] Still, my comments about negative input-tolerant regulators stands -- you might need a bit more output capacitance, though. Also look for: Micrel MIC2950-05BZ or MIC2950-06BZ Micrel don't have on-line sales -- I'll investigate retail outlets for them if you want. |
Cheers, Damon |
Quote:[size=1" face="Verdana" id="quote]quote: Originally posted by hmsfix<br />Hi, Here comes another proposal using LEDs with AC. The highest reverse voltage that can occur at each diode is limited to the forward voltage of the other one, and that's safe, too:  Hans Martin Good as I already suggested it. But your figure makes it clearer I admit.
Hi all
this is all excellent info.
Indeed the 18V statement is relevant too. I am trying to help the guy selling these items as I think we may all benefit - and he knows almost nothing and I know a bit more than him....
He has three sets of LED products:
1) regular 3mm LEDs already soldered to a resistor and some wires for easy installation (various colors) 2) LED light strips for interior lighting 3) LED replacement bulbs in the same format as Märklin lamps
My concerns were: a) That his claim that all the LEDs could be used up to 20V b) That the light strips & replacement bulbs have no reverse voltage protection c) That the light strips have no protection for voltages above 13V
so to be clear I am not intending using these in an 16V AC environment at all, I just expect others to try and use the replacement bulbs with 16 V AC by screwing them into an analog loco.
I am interested in using his light strips in passenger cars and station lighting. For station lighting I will use 12V DC - so zero problems there, but for car lighting a solution will be needed. That solution needs to handle 16vAC and 25V spikes for (analog operation) and the 18V chopped digital power for digital operation.
I suspect that for the light strips he may to limit them to digital use and rectify and or regulate to 12V. That LT1121CZ-5 sounds good as it states that is has adjustable Output from 3.75V to 30V. So presumably one of those plus 2 small caps and a resistor (to set the output) would enable him to create a 12V DC supply good for a digital power source. Then, just as I think I understand it all, I see something that muddles me - the TO-92 package has only 3 connections - does that mean that one is not adjustable?
Would there be flicker when such a regulator is fed with digital power?
I am interested in your phrase 'chopped ±18V '. I take that means it is not a sine wave and so I we pass that source through a normal bridge rectifier, the output will not exceed 18V ?
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz <br />I am interested in your phrase 'chopped ±18V '. I take that means it is not a sine wave and so I we pass that source through a normal bridge rectifier, the output will not exceed 18V? It's 22 V, not 18 V. That's what you get if you rectify 16 V AC. Digital current is rectangular AC, no sine wave. Voltage will not increase if rectified again. |
Quote:[size=1" face="Verdana" id="quote]quote: Originally posted by h-zero<br /> Quote:It's 22 V, not 18 V. That's what you get if you rectify 16 V AC. Digital current is rectangular AC, no sine wave. Voltage will not increase if rectified again.
My understanding was it was ±18V -- but I can't remember where I read that, so I might be wrong (although I wouldn't normally admit that   ) I will take my MS to work tommorrow and check the signal with the 'scope. Dale, If you are going to rectify the input voltage, there is no need for an expensive regulator like the LT1121. An ordinary 78L12 will do fine -- no adjustment neccessary. I only suggested this one because it might not need an input rectifier. If my voltages were wrong (i.e. Märklin digital is ±22V), then the LT1121 wouldn't be suitable anyway: 22V is above the Absolute Maximum -- not by much, but unacceptible for a commercial product. For a home-brew product, I'd probably try it. You are right, a 3-pin regulator of the LT1121 type is not adjustable. The LM317L is an adjustable 3-terminal regulator that requires 2 resistors to set the voltage, but it doesn't like negative inputs. If your input (or output) capacitor is large enough, you won't see flicker at 50/60Hz. |
Cheers, Damon |
It's 16* sqrt(2), ca 22,6 V actually. Reason: when you measure voltage of AC, the convention is so that 16 V AC and 16 V DC gives the same amount of power through a resistor. As the AC sometimes is 0, it has to be higher as 16 V for a period of time as well. /Lars
Joined: 02/08/2006(UTC) Posts: 897 Location: Ramløse, Denmark
If you see flicker doesn't that mean that the frequency is below 25 Hz? I thought the human eye was incapable of detecting frequencies as high as 50 Hz...? |
CS, Denmark/Germany Ep. I - V, Switzerland Ep. II - V, USA Ep. III/IV |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by pserup <br />If you see flicker doesn't that mean that the frequency is below 25 Hz? I thought the human eye was incapable of detecting frequencies as high as 50 Hz...? Try 60 or 72 Hz on a large computer monitor - I see flicker there (too much to work more than just a few minutes). |
Quote:[size=1" face="Verdana" id="quote]quote: Originally posted by DamonKelly<br />My understanding was it was ±18V -- but I can't remember where I read that, so I might be wrong (although I wouldn't normally admit that   ) I will take my MS to work tommorrow and check the signal with the 'scope. It's more than 22 V with a 16 V AC transformer and "old" equipment like CU6021 or Delta Control (4f). It might be 18 V with a MS and an 18 V DC transformer, but should be more with an 16 V AC transformer. I wouldn't design anything for 18 V (no matter wot your 'scope 'll show) - imagine you'll upgrade to an CS or an 1.9 A MS with a 60 VA transformer and all your "maintenance free" LEDs burn out ... |
So it seems, given a 12V light strip, a practical solution for interior lighting (digital power supply) would be:
Bridge rectifier plus 78L12 voltage regulator plus two small caps for the regulator... |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz <br />So it seems, given a 12V light strip, a practical solution for interior lighting (digital power supply) would be:
Correct. |
Cheers, Damon |
Ok great. I started drawing a circuit diagram for Adarsh and looked up LM317 and 78L12 etc. I found this great web page: http://www.eleinmec.com/article.asp?16which contains the circuit that I was arriving at as well as a circuit board layout for a 5V supply. Instead of using a 7805 he should use the 78L12. If the load is very low - I would assume 40mA for two light strips in a coach - 60mA for three I would hope that he would not need a heat sink for the 78L12.... Would the capacitors shown for the 5V supply be just as appropriate for 12V ? |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz <br />Would the capacitors shown for the 5V supply be just as appropriate for 12V ?
He uses a 63 V capacitor - that'll do even with blue transformers in analog operation! A 25 V capacitor should be sufficient for digital operation only (but could explode in analog operation) - but it's smaller (easier to hide). Edit: if you're using the 78L12, a smaller capacitor will do. If you're making a "digital only" version, a much smaller capacitor will do (rectangular voltage, no sine wave) - if you have clean tracks! AFAIK there's a rule of thumb: 1 mF for 1 A (this rule is for 50 Hz and sine wave). Capacity C = (Current * Period) / voltage drop [As/V] I think the 7812 needs at least 15 V input. With 22 V track voltage there are 7 V "reserve". With 0.1 seconds, you get: 0.06 A * 0.1 s / 7 V = 860 µF With 0.01 seconds, you get: 0.06 A * 0.01 s / 7 V = 86 µF 470 µF should hold the voltage less than 1/100th second. 470 µF should hold the voltage for 5/100th seconds. Not sure how much you'll need to prevent flickering with dirt on the track ... Too big can be harmful, too: when you turn on the power, all capacitors will be charged at the same time (this can give your booster a hard time). Some folks use 10,000 or even 22,000 µF per loco - a handful of 470 µF shouldn't do much harm. |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz <br />If the load is very low - I would assume 40mA for two light strips in a coach - 60mA for three I would hope that he would not need a heat sink for the 78L12.... It might be possible. It all depends on how confined the space around the regulator is, and to what temperature this space will rise to. If placed in an open area at 30 degrees Celcius, an 78L12 can tolerate a dissipation of around 0.6W, possibly a bit more. Which at about 21V input voltage (16V AC rectified) means a max load of 65mA. So placed inside a coach, 40mA could very well be possible. I'm less optimistic about the 60mA.
Joined: 17/09/2006(UTC) Posts: 18,778 Location: New Zealand
Quote:[size=1" face="Verdana" id="quote]quote: Originally posted by DaleSchultz<br />Ok great. I started drawing a circuit diagram for Adarsh and looked up LM317 and 78L12 etc. I found this great web page: http://www.eleinmec.com/article.asp?16which contains the circuit that I was arriving at as well as a circuit board layout for a 5V supply. Doh! Dale, if I realised earlier you were looking for a power supply circuit of this nature I could have posted it. I'm using a 12v version of this circuit to power some 12v bud lights on my station platform. I think you can pretty much replace the 7805 with a 7812, or 7815 to get 12v, 15v, etc. The other components can stay the same - I've got 470uf caps in my circuit. I'm running my circuit off a standard 40va Marklin lighting transformer. Remember to heatsink the 7805, otherwise current draw is very limited due to thermal shutdown - although I managed to run 4 incandescent bulbs before mine shut down (I didn't measure the current draw though) - but I would guess that for small current draw of 60ma you won't need a heatsink. Try it and see, if the current draw gets too large the regulator will just shutdown. Twas what happened to me... I think the regulators are rated for 1 amp, correct me if I'm wrong. Don't know if you can get pigtail capacitors in this size but that may be worth a try - smaller profile.
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by Bigdaddynz <br />Remember to heatsink the 7805, otherwise current draw is very limited due to thermal shutdown Inside a 7812, the voltage drops by about 10 V, so at 0.06 A you have 0,6 Watts (assuming 22 V track voltage). Dunno if you need a heatsink at that rating ... |
this is a fantastic group effort !
I think the next step would be for him to look for the smallest sized components and do some burn tests... and if the 7812 gets too hot then add a heat sink. Hopefully he can use a small heat sink and small caps - some coaches don't have much space to hide things.
I will suggest that he runs a number of his light strips at a time so he can check the temperature build up at higher loads.
now a more philosophical musing... are there chips/components available that do the rectification, smoothing and power regulation all in one component? It would seem that such items would be called for in typical outputs such as 1.5V, 3V, 5V, 12V, versions... enough for manufacturers to produce and sell such items... with inputs that go to say, 35V?
Are there surface mount versions of these items or does the heat dissipation issue simply preclude such miniaturisation? |
I just realised that his power strips have one 20mA circuit for every 5cm of strip. This means one may end up with 5 x 20mA = 100mA in a long passenger coach. This suggests to me that heat may be an issue. |
Dale, with 100ma of current draw, I think you can get away without a heatsink. However, the back of the regulator can get quite hot to the touch, although I think I was drawing much more than 100ma through mine. I suggest you try the circuit out of a coach, and see how hot it gets. I think the regulators are only available in the TO220 package type. I've just had a look at the spec sheets on these regulators - maximum input voltage is 35v, maximum current draw is 2.2A. Check out the specs here (there's a link to the spec sheet from this page):- http://www.rsnewzealand....ch.jsp&BV_SessionID=@@@@0246104571.1194734785@@@@&BV_EngineID=ccdhaddmghgdkhfcefeceeldgondhgn.0&cacheID=nznetscape At the bottom of the sheet there are some typical applications, and circuits to match. More specs can be found here:- http://www.eleinmec.com/article.asp?20Whoops, I lie, they are available in a D-PAK package type, which by the looks of it are smaller than the TO220. Check page 26 of the spec sheet. Here's a thought.... If the coaches you are using are metal types, you may be able to use the coach as the heatsink. Just a thought!! You can get the rectification (pictures of types here: http://www.maplin.co.uk/...ria=AR83E&DOY=10m11) in a single package, but I don't think there is one that will do everything.
An alternative for powering the LED strips is a switch-mode module (aka DC-DC convertor) This company makes some very small units Recom. Other companies do too, but these are about smallest I've seen. They may not be small enough to fit in a passenger wagon, though. Regardless, the advantages are that this unit will provide 500mA at 12V from 22V input, with no heatsink. Go the the Products->Innoline page, and look at the R-78xx-0.5 range. |
Cheers, Damon |
The Recom units certainly look to do the business!!
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by Bigdaddynz <br />The Recom units certainly look to do the business!!
I just found an even better one! They used to be Datel, then Newport, then became C&D Technologies, and now have been bought by Murata. Is that clear? Good... 7812SR-C is smaller than the Recom unit. The "H" package is particularly useful for inside a passenger wagon. Buying small quantities may be a problem...I'll hunt around. |
Cheers, Damon |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz <br />I just realised that his power strips have one 20mA circuit for every 5cm of strip. This means one may end up with 5 x 20mA = 100mA in a long passenger coach. Oh, so you will have more than one strip in each coach. Then how about taking the strips and put them in series two and two? Then they can withstand 24V together, and no regulator is needed in the first place.
Hi Damon,
that 7812SR-C only replaces the 78L12 right ? It can't take negative input so the rectifier and smoothing cap would still be needed. I understand it solves any heatsink issue though.
I suspect that the size it starting to approach a small loco function decoder ! (which produces DC output) |
Mikael,
the strips that he has can be chained together but each 5cm of strip inludes a resistor and 3 LEDs, so this means that each 5cm contain its own LED circuit and thus its own 20mA load. When chained together, their input voltage is still 12V, they just double the load. |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz <br />When chained together, their input voltage is still 12V, they just double the load. Yes, if done as intended, but I guess we can do what we want with them, right? If a coach is in need of 4 strips, I would chain 2 together in one end, and the other two in the other end. And then I would connect those 2x2 modules in series at the middle. It may take a bit of soldering, but surely not as much as connecting a regulator.
yes, if modifying the lights strips, to connect two sets in series one would need to cut two traces and solder on an additional connection between the two sets. This would give you 6 LEDs and 260 Ohms of resistance. At 22V it would run at 15mA but if only 18V is available some LEDs might not illuminate...
I am trying to tell Adarsh what he would need to use his strips as he gets them. Those who are adept at soldering could make up their own light strips, with 6 LEDs evenly spaced over the length of the coach and a single resistor to run off 22V (or 5 LEDs if 18V is available)
Damon - did you measure the rectified digital track current?
Dale, yes I did measure the MS output -- ±18.3V or so. However, after doing some research I realised I was guilty of overestimating the sophistication of Märklin's controllers and boosters. [:I] I assumed the output was regulated -- instead, the controllers/boosters just chop the unregulated supply, so indeed with a 16Vac supply, the track voltage would be around ±22.5V. These are the perils of being an electronic engineer, and assuming the same things that matter to you matter to someone else. In my design work, every mA costs, and I routinely specify voltage references to the mv, and power supply voltages to ±1%... We're not in Kansas anymore... Anyway, back to the question at hand... I had a thought on multiple LED strips. You only need one 12V regulator per strip (with small output capacitor). Each strip needs 23mA, so even at 23V input (i.e. 16Vac, rectified), total power dissipation in each linear regulator would be 0.25W There is no shortage of surface mount or through-hole linear regulators in this range. You only need one bridge rectifier and filter capacitor per coach, which would be easier to hide than several. You then connect each LED strip with integral linear regulator in parallel. eg. Maxim MAX1616 or Texas Instruments TPS71501These are both "adjustable" types, and hence need 2 resistors, and an output capacitor, but may be a possible solution. To make surface mount manageable for non-mass production, you could use the small adapter boards like Aries, that take an SOT23-5 (or similar) and provide a small pinned package. |
Cheers, Damon |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DamonKelly so indeed with a 16Vac supply, the track voltage would be around ±22.5V. Thanks, good to know. Quote:[size=1" face="Verdana" id="quote]quote:You only need one bridge rectifier and filter capacitor per coach, which would be easier to hide than several. You then connect each LED strip with integral linear regulator in parallel.
yes the strips he sells plug into each other and in doing so connect to each other in parallel. I have suggested he builds some prototypes and tests them for long periods with 5 x 5cm strips attached - representing an estimated load of 105mA |
update, I measured rectified track voltage on my layout and got 27 Volts ! |
