Offline Martin T
#1 Posted : 03 September 2007 18:07:14(UTC)
Martin T
Hello!
I'm looking for a couple of locos suitable to pull track cleaning wagons. I have two Roco cleaners with AC-wheel set. Woundering if anyone has experience in this field?
What are the pulling capabilies of the Swedish Ub loco?
I have one in order for this winter, so I'm thinking of extending it with additional locos if suitable.
Since track cleaning is made whenever it neccesary, its important that the loco is somewhat resistant to dirty rails too, which might not be the case with the rather short Ub-loco... The 5-pole motor + mfx, isn't very great either, since most of them stops instantly dead at any dirt. Very bad in the tunnels!
Looking forward to some input of your own experiences would be great.
/ Martin T
Regards / Martin T
Offline Davy
#2 Posted : 03 September 2007 21:26:12(UTC)
Davy
I use a delta E44 Marklin 34440. He pulls everything I have (the loc pull a train of more then 9 meters) and can handle dirty track very good.
M-track with a CS2.
Offline pserup
#3 Posted : 04 September 2007 02:22:35(UTC)
pserup
PA-1 double headers are among the least sensitive to dirty track in my experience. Otherwise two heavy metal loks setup as a consist (easy with CS) should also do well... Never had my MY1111/MY1112 NOHAB double header stall on me Cool
Lastly, let the loko(s) push (rather than pull) the track cleaning cars.
Offline laalves
#4 Posted : 04 September 2007 04:54:06(UTC)
laalves
Use any heavy metal Märklin electric or diesel lok with a Delta or 60901 decoders, pushing the cleaning cars. That way when the lok arrives to the track, it has been cleaned at least once.
Deltas may be better because they have much more momentum and will consequently ignore most power interruptions, simply overruning them even with no power feed. In strict terms it's not momentum, what they don't have is nothing like a magnet braking them, which is the case of the 60901/mfx loks.
Flywheel equipped loks may also do fine, but among Märklin, that used to be rare. 3rd gen c-sine loks now feature flywheels.
Offline Martin T
#5 Posted : 05 September 2007 16:04:30(UTC)
Martin T
Thanks all! Unfortunately I got rid of all my noicy DELTAs locos a few years ago. [xx(] Hmmm.. Maybe I should go looking for a second hand NOHAB diesel engine with DELTA decoder then. They look good too.
laalves.. Pushing the cleaning car? No, I dont think that would work on my layout. I better have a haevy, fast and dirt resistant loco doing the pulling job.
Talking about dirt.. I'm quite conviced that the problem is not so much dirt, but rather oxidation of the tracks. Guess the air in my garage isn't very dry unfortunately. Takes a whole lot of rubbing before that oxide comes off. I've cleaned some of the tracks with aceton and a soft cloth until there were no black stains left. Then I still had the contact problems. After use of sanding paper 800 it was perfect again.
Regards / Martin T
Offline Red Moose
#6 Posted : 05 September 2007 16:50:13(UTC)
Red Moose
Try to get a air dryer, either a mechanical one or just a chemical one (aka Torrbollen). I have 2 in my train room in the basement, and they gather quite a lot of water during the humid season.
Have tried Rocos track cleaning wagon, but didnt like it. Have ordered a Märklin waggon with the so called System Jörger cleaning pads. You can find more info about them in this fora.
I have 2 RC loks with DCM 5 pole engine and 6090x decoder, they are a good pull. Have them set on the same address, so I can run them on my MS. When one stops for some reason (dirt) the other one pulls/pushes it. They are calibrated to accurate (and same speed) using a Fleischmann 5555 Tachowagen.
//Erik
Offline Red Moose
#7 Posted : 06 September 2007 00:07:11(UTC)
Red Moose
Correction. I had the Roco cleaning Wagon after the two RC loks, but it just gve up and decoupled. So I put it inbetween the two loks, and things started working much better. Only remember to drive slow... But, the best cleaning tool so far is a chunk of wood which you draw along the tracks. And the cheapest. Someone here in this fora got me on the right track!
Offline rschaffr
#8 Posted : 06 September 2007 00:16:18(UTC)
rschaffr
I use one of my heavy metal kroks for the job.
-Ron
Offline Martin T
#9 Posted : 06 September 2007 10:23:45(UTC)
Martin T
[size=1" face="Verdana" id="quote]quote:Originally posted by Red Moose
<br />Hi,
//Erik
Thanks Erik!
Very good information!
I'll probably be much better off trying to get the humidity out of the air, rather than removing the oxide from the tracks.
My experience so far with the two Roco trackcleaning wagons:
- Doesn't do miracles. An oxided and dirty track (loco-stops-track) will not be cleaned, no matter how many passes you run the cleaning train. It doesn't clean the center rail either. I would say that 1 of 4 voltage dropouts is due to dirt/oxide on the center rail.
I've added a pick-up shoe under one wagon, on to which I glued 800 sanding paper. That wagon goes with one of the cleaning trains and takes care of the centre rail cleaning.
I have like 60 meters of tracks. I use two trains, which I run for one hour around on all tracks. This while I'm doing other things in the house. The cleaning must be repeated like every second, or every third week to maintain perfect driving conditions.
Regards / Martin T
Offline hemau
#10 Posted : 07 September 2007 11:46:44(UTC)
hemau
Hi Martin,
Once you start with sandpaper om M-track it's hard to stop ( .. one hour every three weeks .. ). Maybe lowering the humidity works to some extent. Best is if you could get a corrosion-preventing layer back (contact spray?)as is original on M-track but the problem is it could attrack dirt.
The Seuthe smoking fluid I have is also indicated for cleaning. Maybe that would help.
Cleaning with aceton will get every trace of protection from the tracks and they will rust faster than ever.
Best Regards, Henk.
C and M track; CS1R and 2 MS
Offline Martin T
#11 Posted : 07 September 2007 15:19:12(UTC)
Martin T
Interesting information! I'm quite familliar with both coatings and platings to achieve good electrical contact properties since I work in that field.
Tin plate is in general the best way to go, since the oxide of tin actually increase conductivity. They usually needs to be applied using electro plating and I'm doubtful if Märklin really put that much of effort into the making of the M-rail. Maybe I'm wrong and if so, then I must admit that sanding the rails, or even using these cleaning wagons is a BIG mistake, since they eventially will remove that plating.
Enviro coatings, like yellow, or clear Chromate is easy to apply by dipping, but they wear also off almost instantly. The method is cheap, but the coductivity usually suffers from it, even if the surfaces remain at a stable conductivity level over a longer periode of time.
Yeah.. I don't know.. But if somebody has a deeper knowledge about the material and finish used on M-rail, please fill in here.
Regards / Martin
Regards / Martin T
Offline hemau
#12 Posted : 07 September 2007 23:03:01(UTC)
hemau
M-rail definately has no tin-plating. It is 'blech', blik or steelplate if that's the english name but without a tin-plating.
Tin-plating yuor M-rail would be great, beware not to use any corrosive soldering fluid (I did that 40 yrs ago and still am sorry for it). But on 60 m of tracks ...?
I have to correct my previous mail. The smoking fluid is not from Seuthe but from www.Conrad.com. It is called Smoke and Cleaning Fluid (Dampf- und Reinigungs Destillat). In German it says on the bottle "ideal cleaning compound (Reinigungsmittel) for instance for tracks, locs etc." On the bottle it says it contains Iso-paraffin. Good chance that this fluid evaporates while leaving a certain layer. I will try that on my M-track part and maybe also on the C-track as that has some oxidation trouble as well if not used for a long time.
And yes, maybe it will attract some dirt but that is better to handle than rust.
Regards, Henk
Offline Martin T
#13 Posted : 10 September 2007 11:01:12(UTC)
Martin T
No Henk, I wouldn't worry about doing tinplate on the tracks. I'll then rather upgrade to C-tracks, or something. No, the track cleaning is a part of the work on the railway, both in the real world and in my basement.
Also I like the realistic blank look of the rails after running the cleaning wagon a few rounds.
Regards / Martin T
This page was generated in 0.430 seconds.
