Offline 2ndChancer
#1 Posted : 31 August 2007 06:01:17(UTC)
2ndChancer
Views messages in topic : 587
Hi friends
I notice that there are Trix HO & Trix Express, what are the difference?
Thank you
Eric
Offline pat
#2 Posted : 31 August 2007 06:44:03(UTC)
pat
Originally posted by 2ndChancer
<br />Hi friends
Thank you
Eric
The big difference
Is the Trix Express system uses the larger wheel flanges, making derailments rather uncommon, but at the same time making their rolling stock incompatible with more modern NEM systems unlike trix ho
worse things happen at sea
Offline Weltenbummler
#3 Posted : 31 August 2007 09:17:32(UTC)
Weltenbummler
O.K.,
you can hit me if I'm wrong. But I always thought the big difference was that Trix Express was also runing on a kind of track system like Marklin only using DC instead of AC. Locos had some kind of shoe underneath nearly the same way like Marklin does.
And the big advantage was running 2 trains on the same track with different speed using two transformers long before someone had a digital system in mind.
Picture linked from Wikipedia
Loads of more pictures can be found here:
http://www.ig-trix-express.de/
Regard from Karachi
Thomas
Offline Lars Westerlind
#4 Posted : 31 August 2007 10:04:54(UTC)
Lars Westerlind
Yes,
Trix Express AFAIK is 3-rail, with the rails separeated. This allows for running two locos simultaneosly at the same track. Don't know which is 0; the logical should be mid rail, but if one of the rails is used it allows for one ordinary DC train and one "Express" train (provided, the flanges are OK).
/Lars
Offline MärCo
#5 Posted : 31 August 2007 18:35:35(UTC)
MärCo
For the Dutch members, who want to know more —&gt;
http://home.planet.nl/~gesku011/home.html
Absolutly AFB-NOHAB fan ;-)
#6 Posted : 31 August 2007 20:12:38(UTC)
Offline plavnostruev
#7 Posted : 23 December 2007 22:10:35(UTC)
plavnostruev
Which modern M* controller can be used to operate old Trix Express train?
Offline Markus Schild
#8 Posted : 24 December 2007 00:45:05(UTC)
Markus Schild
[size=1" face="Verdana" id="quote]quote:Originally posted by plavnostruev
<br />Which modern M* controller can be used to operate old Trix Express train?
Hi Mike,
NONE.
Most TRIX-EXPRESS (TE) is DC. Only early models before ~1953 can be run with AC. But all Marklin transformers (execpt for Z and SPRINT) are delivering AC. So look out for any 12-14VDC-controller. Almost all US-brands used that system.
Markus
#9 Posted : 25 December 2007 01:34:57(UTC)
plavnostruev
Markus,
Thank you.
Offline Schienenbus
#10 Posted : 25 December 2007 21:31:02(UTC)
Schienenbus
I had Tris Express when I was a boy in the Sixties. It is DC 3-rail. Common ground is on the center rail (which was a real rail, not pukos). Including catenary you could run 3 trains independently on one track - great at the time!!!
My two locos are 40 years old and still run fine - quality was good. Made in Nuremberg...
Arthur
Offline TTRExpress
#11 Posted : 26 December 2007 01:19:55(UTC)
TTRExpress
Eric,
The roots of the company TRIX can be traced back to 1838. In 1925 the merger between metal toy makers, Andreas Förtner and the late Johann Haffner, later taken over by his son, became the Vereinigte Spielwarenfabriken, A. Förtner und J Haffner’s Nachfolger KG. In 1928 Stephan Bing took over the company after business and financial disagreements at the Bing-Werke AG that was founded by his father Ignatz and uncle, Adolf. The actual name Trix was adopted in 1931 with the first metal model erector set construction toys being produced, Trix Metallbaukasten and the name was changed to Trix Vereinigte Spielwarenfabriken, A. Förtner und J. Haffner Nachf. GmbH. (TVSF). The holes in the metal parts had a Tri “X” configuration, hence the name Trix. The metal construction system actually played an important role in Great Britain. It was instrumental in the formation of Trix, Ltd., which was licensed to manufacture these sets (2). The first directors were W.J. Bassett-Lowke and Leo Gross.
The first electric HO scale model train was introduced in March 1935 at the Leipzig Spring Fair under the Trix Express label. Trix made its debut in the U.K. at Christmas that same year where it was sold and distributed by Bassett-Lowke Ltd. as The Bassett Lowke Twin-Train Table Railway. Many of the Trix Express molds and plans were sent to England and collaboration with Bassett-Lowke eventually led to the British equivalent of Trix Express, Trix Twin (3).
The uniqueness of both systems was that two trains could be operated on a single track. The track scale was 16.5 mm and was 3-rail, each being electrically isolated from the other. The center rail was the common. The locomotives and tenders had collector shoes configured to pick up electricity from the center rail and either of the two outer rails. Hence “Twin” running. Later, with the addition of catenary one could now operate three trains independently on a single track with no other electrical “trix!!” From 1935 until 1956 both Trix Express and Trix Twin operated on 14 Volt AC then both switched to 12 Volt DC in 1956. The TRIX Express rail profile height is 3.3 mm which calls for larger wheel flanges and is not NEM compatible. One can operate any manufacturer's trains on TRIX Express track but not vice versa unless you swap wheel sets.
TRIX HO or International, 2-rail DC, was not introduced until 1964. The rail profile height of the 2-rail track is 2.7 mm and is NEM compatible. With 2-rail DC in analogue you can only run one train per track unless you use catenary and can then run two independently. With the advent of digital one does not need fancy wiring to be able to run multiple trains on 2-rail DC track anymore.
For those of us who still operate TRIX Express, it is a unique system and gives us many hours of pleasure. It truly offered the model railroader a way to operate many trains before digital was conceived. TRIX also brought out its Elektronischen Mehrzugsteuerung (EMS) system in the mid-1970's which was its first introduction to a digital way of operation. One could operate 6 trains independently on one track with this system.
All my TRIX Express operates as new!! Cannot beat it for quality!!
Regards and Happy Holidays (a Scot in Wisconsin).
thanks 1 user liked this useful post by TTRExpress
Offline TTRExpress
#12 Posted : 25 January 2008 19:04:28(UTC)
TTRExpress
Eric,
Here are some links that describe TRIX Express more completely.
http://www.tischeisenbahn.de/
http://www.ttrca.co.uk/
There are also many other interesting links within these sites.
If anyone has any further interest you can contact me via E-mail (mpheil@new.rr.com)
Offline TTRExpress
#13 Posted : 25 January 2008 19:06:06(UTC)
TTRExpress
Eric,
This page was generated in 0.716 seconds.
