Offline mascagni
#1 Posted : 23 August 2007 16:01:17(UTC)
mascagni
Hi: My middle son has a small inexpensive diesel, 3088, that he would like to be able to use on digital tracks as well. I have a Delta 66032 decoder, and would like to see about installing it. This decoder has access to all addresses, autodetects digital/analog, and has solder bridges that can be closed to give you function F1. But you knew all that. I was wondering if you have any advice, websites, or other literature that I could use to help me hook things up correctly? The decoder literature from Marklin is for dealers, and doesn't have the kind of examples that I prefer. Your help is appreciated.--MM
Michael Mascagni, Tallahassee
Offline Sander van Wijk
#2 Posted : 23 August 2007 16:24:14(UTC)
Sander van Wijk
Hi Michael,
Personally, I think you already pretty much know everything you need to know. All you need to do to install the decoder is:
1. Remove all wiring except for the black wire with the "Drossel" (usually grey coil-like part) in it, you can simply hook up the black decoder wire to this coil and leave the other end of the coil in place, i.e. at the motor cover.
2. Remove the direction switching relay
3. Hook up the red decoder wire to the pickup slider (by unscrewing it, you'll notice a small copper plate on which the original wire is/was soldered, you can solder the red wire on that position. (Take care it does not short anything, so don't remove too much of the wire insolation and "tin plate" the wire before installing it.)
4. Connect the brown wire to the ground, usually this is done easiest by attaching it to the little copper lip connected to one of the screws that hold the motorcover in place.
5. Connect the grey wire to the front light, and the yellow one to the back light.
6. If the light armatures are not connected directly to the ground, ground the bulbs by using the orange wire. This will probably not be the case, as the 3088 also is not equipped with Telex couplers, remove the orange wire by cutting close to the decoder and insulate the remains properly. The same can be done with the white wire, as not extra functions like Telex are present on your model.
7. Finally: solder the blue and green wires to the motor coil.
8. Test the model, if it runs opposite to it's light switching, swap the green and blue wire.
9. If you don't feel completely confident at first: don't shorten any wires, go through steps 1 until 8, if all works properly, loosen the wires again to shorten them to the correct length one by one.
Maybe this link is of use to you: http://www.bogobit.de/decoder/66032.html
Good luck!
Sander
Offline Hemmerich
#3 Posted : 23 August 2007 17:07:10(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by mascagni
Hi Michael,
in addition to Siegfried Grob's pages/pictures (you can see where they were coming from wink) mentioned above by Sander, Märklin has as well some more information about this decoder; please see here
http://www.maerklin.de/faq/show...;sb=5&o=&fpart=1
Wiring diagrams for this decoder can also be downloaded from the Märklin server; they were included (for whatever reason) in the MM2007/04 track layout plan (page 1).
http://www.maerklin-info.de/mm/...ads/MM_0407_Download.pdf
Offline mascagni
#4 Posted : 17 September 2007 15:57:29(UTC)
mascagni
BTW, the last two Märklin Magazines deal with this exact issue. The first goes through the solder bridges in order to get functions from the 66032, and the second article goes through the conversion of a simple Lok like the one I plan to do first. Thus, I thank all for the help, and feel confident that I will be OK.--MM
This page was generated in 0.260 seconds.
