Offline Westfield Depot
#1 Posted : 22 August 2007 04:47:41(UTC)
Westfield Depot
I just purchased starter set 81565 (example www.reynaulds.com/Marklin/temp.asp?item=81565) as a start in z scale and I can't say just how impressed I am with Marklin Z. The little BR 24 locomotive (8803) is very nice and so far runs very well. Yes, those little pieces are hard on the eyes and the track does take patience and a steady hand to assemble but well worth the effort. I chose the older 81565 over the current 81562 gift cube set, even though it was more expensive, because I liked the loco with tender better than the class 74 tank loco. I encourage everyone to pick up a z start set and just have fun and be amazed with this scale. You wont be sorry.
Does anyone have any experience with this loco and have any advice? Does the add on light work well? Is it worth installing? Has anyone used an LED instead?
Chris
Modeling Märklin Epoch I K.W.St.E. in Ohio USA
Offline ztrack
#2 Posted : 22 August 2007 07:13:58(UTC)
ztrack
Congratulations on your purchase. Marklin starter sets are a great way to get into Z. You are right, they are very high quality and run great! My only comment is to make sure and keep your track and wheels clean. Dirty track and wheels will cause the loco to stall. I use simple rubbing alcohol and a soft cloth to clean the track (in conjunction with a Gaugemaster) on the track. I also use a modified TRIX N scale wheel cleaner for my loco wheels.
The lights are okay on these locos. They are grain of wheat type bulbs and will shine brighter when more power is applied to the loco. If you like slower speed operations, the light will be dim to the point of barely visible. At the higher speeds, the lights will be bright. A company called High Tech Modelbahnen does offer drop in LED plugs for these locos. These are nice and do offer constant bright lighting. They are a great option if you want to go this route. We are the distributor for their products here in the US. We have more information on our HTM web page: http://www.ztrack.com/htm/htm_led_drop.html
Have fun with your new set!
Rob Kluz
Ztrack Magazine Ltd.
The Magazine For Z Scale Model Railroading.
www.ztrack.com
www.ztrackcenter.com
www.ztrackresale.com
#3 Posted : 22 August 2007 16:27:15(UTC)
Congratulations Chris.
Offline MärCo
#4 Posted : 22 August 2007 19:37:27(UTC)
MärCo
You can order a replacement front bogie for the B74. This can be used to change the front bogie from B24, so you have a coupling at both sides. I have done this, because I have no turntable.
Absolutly AFB-NOHAB fan ;-)
"New to Z scale" coupler question (Small scale)
by grahame 07/02/2014 16:50:02(UTC)
New to Z scale from O and 1... (Small scale)
by uhwerk 24/06/2012 04:58:27(UTC)
This page was generated in 0.395 seconds.
