Offline Hemmerich
#1 Posted : 12 August 2007 02:41:27(UTC)
Hemmerich
The next Swiss beauty with SDS has arrived - Ce 6/8-III #14308 in brown livery - and I must admit, it's a great model too!!! [:p]
When seeing it just from the outside nothing except the delivery box indicates anything about this great and powerful alligator which has been released now by Märklin.
But when it starts moving (almost w/o any noise) you will be surprised about its driving performance - and even more once it crawls slowly but steady along the tracks or up and down the hills (IMHO max. speed can be set slightly lower than the factory default value of 225).
In my personal rating of those four models that I have now, three of them with a different motor/drive, this new one is simply the best!
Here a comparison picture of the three basic models interior - HLA, large C-Sine and SDS (#14305 was originally a #3656 which I converted to HLA and added the Swiss light pcb, LED and cabin lights).
You'll immediately notice the VERTICAL mounted motor in the new model - an interesting solution! Instead of cabin lights, the new model has a Swiss signal horn (which is ok) and as you can easily see, it is really packed! wink
The frame and light pcb in the middle section (also containing the mode operation switch) are still the same as with the previous version with the larger C-Sine (#39560/39561/39569), but the outer traction sections are now different.
IMHO it should also be possible to replace the existing mfx decoder with a mfx sound decoder (you'll need to change the loudspeakers to 100Ohm).
The R1 revision date is 13.12.1929 (for #14316 it is a little bit earlier, 22.10.1929); instead of the more extensive weight label of #14316 the new model #14308 has only one line ("131t"). Manufacturer plate ("Oerlikon/SLM Winterthur") and depot location ("Erstfeld") are the same for both models.
Go for it too!!! winkwinkwink
Offline rschaffr
#2 Posted : 12 August 2007 02:51:47(UTC)
rschaffr
Thanks, Lutz. Mine is in route from Karlsruhe since last Tuesday. Should have it this week. You are just making me more impatient to get it! Smile
-Ron
#3 Posted : 12 August 2007 03:00:34(UTC)
Thanks, Lutz.
Very interesting!
Offline alonso231gery
#4 Posted : 12 August 2007 04:41:36(UTC)
alonso231gery
Thanks Lutz .
If you had to select between the 39561 and 39562, which model would you choose ?
An outsider.
#5 Posted : 12 August 2007 22:12:26(UTC)
Very nice,Thanks for sharing the pictures.
Offline Guus
#6 Posted : 13 August 2007 17:03:33(UTC)
Guus
Hi Lutz,
Congratulations from my side too!
Can't wait for mine.
Having two models with the new SDS I'm as enthusiastic as you appear to be.Driving characteristics are really amazing and its great fun having these locs run at very low speed on their tracks!
Thank you for your extensive report and the nice photos for comparison.
[size=1" face="Verdana" id="quote]quote:You'll immediately notice the VERTICAL mounted motor in the new model - an interesting solution!..
I would have expected a horizontally positioned motor and cardan drives,but this might be a more economical solution.Clever!!!
[size=1" face="Verdana" id="quote]quote:Go for it too!!! winkwinkwink
Already did that a couple of months ago [:o)]
Kind regards
Guus
Kind regards,
Guus
Offline Hemmerich
#7 Posted : 13 August 2007 21:41:29(UTC)
Hemmerich
<br />Thanks Lutz .
As you can see I was luckily not faced with that question; so I can't really tell - it's completely up to you. I do see about three + for the new model: the new SDS is more quiet (and likely stronger), it comes with mfx and it has an extra horn signal. wink
I can only say - try to get some time both. It took me several decades before I got my first croc; now I've already four of them and there are no signs (yet) that this "gatormania" will end soon! SmileSmileSmile
PS: I changed the Vmax value to 160 which results in a max. speed that is closer to that of the prototype; it now also matches what I've set at my other models.
Offline rschaffr
#8 Posted : 18 August 2007 02:19:22(UTC)
rschaffr
Got mine today. It is truly a beauty. Couldn't wait to get home to try it so I set up a small Tischbahn to try it out with my Grandson's MS. Really a smooth runner. I'll take some pictures on my layout tonight or tomorrow.
Added: My 18 mo old Granddaughter kept reaching for the MS, so I showed her how to adjust the speed and blow the whistle (both of which she picked up immediately) and is now our newest Modellbahnerin.
[image]http://www.sem-co.com/~rschaffr/trains/images/kath_krok.jpg[/image]
-Ron
Offline Larry
#9 Posted : 18 August 2007 05:52:09(UTC)
Larry
Cute pic, Ron. Have fun in Germany.
#10 Posted : 18 August 2007 15:09:36(UTC)
Big welcome to our latest member.
David
Offline kiwi
#11 Posted : 18 August 2007 15:52:11(UTC)
kiwi
thanxs for the info Lutz
mine is also on the way, i am hoping to get it in the coming week.
kiwi
Mike. Rebuilding at the moment(c-track,digital) DRG,DB,SBB era 1-4 steamers and the odd electric
https://www.marklin-user...ault.aspx?g=posts&t=4561
Offline Hemmerich
#12 Posted : 18 August 2007 22:57:22(UTC)
Hemmerich
My 18 mo old Granddaughter ... is now our newest Modellbahnerin.
Thats just "WUNDERBAR", Ron - I bet she will become a very active (Märklin) model train enthusiast!!! SmileSmileSmile
I guess the first thing she learned immediate was how to push the stop button, which she seems to do right at the moment when you took this great picture! biggrin
PS: I'm as well excited looking forward for my new grandchildren, which are expected to be born pretty soon. Two of my sons and their wives "decided" upon their family expansion almost at the same time earlier this year - which means that I still have to buy some more Mobile and Central Stations and lots of C-track. wink
But it will likely still take some time until they are allowed to put one of these Märklin masterpieces themselves onto their layouts - I almost can't wait for it to happen - wasn't it one of our own youth dreams too?!!! [:p]
Offline rschaffr
#13 Posted : 18 August 2007 23:37:05(UTC)
rschaffr
Lutz: Yes, she found the Stop button, but was getting pretty good at using the red knob too. What you can't experience is the shouts of joy and laughter while she was operating it.
Being a grandparent is the best experience in the world. Congratulations on your pending little ones. You will enjoy them.
Will we get to meet at the Treff, perchance?
-Ron
#14 Posted : 19 August 2007 11:34:38(UTC)
Very cute, Ron.Smile
Offline bmcrae
#15 Posted : 20 August 2007 22:18:51(UTC)
bmcrae
Hi Ron, that's a great pic! My youngest child just turned two and has been known to stand at the door to our basement and call out "Daddy, TRAINS!!". More so than my son (7), she can sit with me for hours watching trains go by on my layout. If I'm watching a train video, or happen to be watching Bahn TV, she will stop to sit and watch also!
Offline rschaffr
#16 Posted : 20 August 2007 23:20:17(UTC)
rschaffr
Brian: She spent the weekend with us. She was down the basement with me running the trains and she saw the new Krok on a siding where I had parked it. She kept pointing to it for me to run it. Her 4 year old brother loves them too. He was helping Mommy and Daddy do some painting and other projects this weekend at their house.
-Ron
Offline MarioFabro
#17 Posted : 22 August 2007 21:43:20(UTC)
MarioFabro
Lutz,
any problems "opening" up your croks? We documented here some problems to open the decoder hood on the 39560. Wonder if the 39562 has the same problems.
P.S.: mine should be here very soon!
Offline Hemmerich
#18 Posted : 22 August 2007 22:48:58(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by MarioFabro
<br />Lutz,
I could pull off the front hoods from my model very easy - otherwise you would probably not have seen my picture of the open model w/o a corresponding comment. wink
Offline rschaffr
#19 Posted : 29 August 2007 16:27:35(UTC)
rschaffr
Finally had the opportunity to run my 39562 somewhat extensively on my big layout. I had tried it (as seen above) on a Tischbahn with the MS and it was smooth and quiet, but the real test is on my complex K track layout with my IB and computer control. I am happy to report that it ran flawlessly. It is so quiet that I had to keep looking for it to make sure it was still running (I can usually hear engine noise in the hidden areas). It took the most difficult areas of my layout smoothly and easily. This included a number of compound curves (both "S" and radius changes) some with turnouts. Not even a hint of derailment. I loaded it down with a string of freight cars including a track cleaner that has a bit of resistance and it pulled them without any complaints. The only place I had any trouble was a known trouble spot where I have a vertical inflection coming into a double slip switch. Longer wheelbase loks (such as this one) can lose traction there, as this one did. That is on my list of things to fix, but it is in a difficult place (inside the tunnel where the trains come out from under my city into the main station..very hard place to work). Overall I am exceptionally pleased with this product.
-Ron
Offline Guus
#20 Posted : 29 August 2007 16:31:00(UTC)
Guus
Thank you Ron for the extensive report.
Kind regards
Guus
Kind regards,
Guus
Offline Hemmerich
#21 Posted : 29 August 2007 16:40:49(UTC)
Hemmerich
Ron,
very good to hear that you're very satisfied with your model as well! Especially the smooth and rather quiet driving still makes some difference to the already very good previous versions. Smile
PS: On my layout(s) I usually make sure to have levelling transition sections that go from +-1,5 to +-0,5 and finally 0mm. So far this worked out fine with ALL my models.
Offline rschaffr
#22 Posted : 29 August 2007 16:43:27(UTC)
rschaffr
Lutz: I have learned that lesson. This was part of the first area of the layout I constructed, and I tested it with short wheelbase loks before I closed it in. I am smarter now (at least for this type of thing) Smile. I test a hidden section much more extensively now before I close it up.
-Ron
#23 Posted : 29 August 2007 17:04:24(UTC)
alonso231gery
The 39180 and the 39562 have the same pulling power ?
An outsider.
Offline rschaffr
#24 Posted : 29 August 2007 18:28:45(UTC)
rschaffr
I can't answer that since I don't have a 39180, but the 39562 is a good puller.
-Ron
#25 Posted : 29 August 2007 18:35:16(UTC)
alonso231gery
Hello Ron,
perhaps Lutz can answer that.
An outsider.
#26 Posted : 29 August 2007 19:08:30(UTC)
Congrats on the new model Ron. Good to hear that the new motor is all we would wish.
David
#27 Posted : 29 August 2007 19:09:21(UTC)
<br />The 39180 and the 39562 have the same pulling power ?
I think about the same but wait for Lutz comment.
Offline kiwi
#28 Posted : 03 September 2007 17:00:44(UTC)
kiwi
Yay today i received my 39562, it was wroth the wait
great model
kiwi
#29 Posted : 03 September 2007 18:44:43(UTC)
Well done, kiwi.Smile
Offline MarioFabro
#30 Posted : 03 September 2007 18:47:03(UTC)
MarioFabro
I also received last week my 39562. I ran it on a carpet lay-out I have on the attic. It probably was dirty because I experienced erratic behaviour. I think this loko requires cleaner track than the 39560. I will try both at the same time, meanwhile I am cleaning my track wink
#31 Posted : 03 September 2007 20:30:32(UTC)
Congratulations with a great model, Mike and Mario.
#32 Posted : 03 September 2007 20:37:21(UTC)
Congratulations, Mario.
Offline metpo
#33 Posted : 03 September 2007 21:14:06(UTC)
metpo
YEaaaaah...
Long live the crocos... still old but if you see how original Back in teh old days those Swiss trains were really so modern in fact...... And still those crocos and other old swiss locs are running and working perfectly!
Offline Guus
#34 Posted : 03 September 2007 21:42:32(UTC)
Guus
Congratulations Mario and Mike.
I bet you've ordered them at a German dealer,is that correct?
No signs of a new croc here in Holland so far.
Kind regards
Guus
Kind regards,
Guus
Offline al_pignolo
#35 Posted : 04 September 2007 00:17:27(UTC)
al_pignolo
Congratulations. It seems to be a great model. I don't own any croc for now but I hope I'll buy one soon!
I'm not sure about the two circular stuffs above the first driving wheel from the left in Lutz's picture: are they the speakers?
Pietro
Offline Hemmerich
#36 Posted : 04 September 2007 01:34:02(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by al_pignolo
Hi Pietro,
yes, they are - #104723 (2x16mm, 32Ohm), actually the same as you'll find for example in the E10.3 #39120&39121. Smile
You'll barely regret the decision once you by one. wink
PS: I haven't (yet very detailed) tested the pulling power in comparison with the new BR218, but so far it looks like the croc is still slightly stronger; despite the fact that the BR218 has all wheelsets driven. But what does this matter anyways at a slope of 12%!!! biggrin
Offline Larry
#37 Posted : 04 September 2007 07:31:17(UTC)
Larry
Wait, perhaps I did not follow this thread correctly, but 2 speakers in the new brown croc? What functions use the speaker other than the horn, etc? I did not think it came with operating sounds.
Offline Hemmerich
#38 Posted : 04 September 2007 14:54:54(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by Larry
<br />Wait, perhaps I did not follow this thread correctly, but 2 speakers in the new brown croc?
Why not? It's two small ones, due to limited space and they are connected in series. biggrin
Offline MarioFabro
#39 Posted : 04 September 2007 19:18:24(UTC)
MarioFabro
<br />I also received last week my 39562. I ran it on a carpet lay-out I have on the attic. It probably was dirty because I experienced erratic behaviour. I think this loko requires cleaner track than the 39560. I will try both at the same time, meanwhile I am cleaning my track wink
UPDATE: Clean track.. model works flawlessly. Now I would like to compare it to the 39560 with the C-Sine. I was very happy with that one as well. I will post pictures and details of the two shortly.
Offline Guus
#40 Posted : 09 September 2007 15:12:30(UTC)
Guus
[size=1" face="Verdana" id="quote]quote:originally posted by Mario:
.......Now I would like to compare it to the 39560 with the C-Sine. I was very happy with that one as well. I will post pictures and details of the two shortly.
Looking forward to your report.
I picked up my 39562 at my dealer yesterday.My first impression is that it's a very powerful locomotive.
It doesn't only look identical to the 39561,but also its driving characteristics are almost identical.
The driving characteristics of the new SDS have been very impressive up till now I think.
Hopefully Märklin will introduce this motor in more of her models in the near future.
Kind regards
Guus
Kind regards,
Guus
Offline jonquinn
#41 Posted : 09 September 2007 18:18:35(UTC)
jonquinn
is there any improvement over the detailing between this one and the older say #3352 brown croc? I recently bought one of these from the Reynauld's marklin estate sale, at what I thought was a pretty good price. I'm sure the road number must be different.
It will eventually be upgraded to digital/sound and a new motor.
I wonder if the SDS motor will become available as an upgrade, like they did with the 5-star? otherwise it may get an SB motor.
being there are so many other nice new things being released, I was hoping not to have to "have" to add another croc to the collection (up to three SBB ones so far - the other two have the 5-star motors).
also, I have found the hood to be not impossible to remove, just that a third hand would be helpful. mine have some little clips that need to be pressed in (small flat screwdriver helped) and then it pops off no problem. it was not immediately obvious how the hood was released - had to do it to clean and lube (oil dried up) on one of the others I have.
Offline Guus
#42 Posted : 09 September 2007 19:11:41(UTC)
Guus
Hi Jon,
Congratulations with your new croc.
[size=1" face="Verdana" id="quote]quote:I wonder if the SDS motor will become available as an upgrade, like they did with the 5-star? otherwise it may get an SB motor.
The design of the newest 39562 is rather different from the older big C-sine and 5-star engined crocs.So I think it'll take considerable effort to modify an old model.
[size=1" face="Verdana" id="quote]quote:also, I have found the hood to be not impossible to remove,.......
It is a lot easier to remove the hoods from the 39562 than the hoods on my other,older,crocs.
Kind regards
Guus
Kind regards,
Guus
Offline kiwi
#43 Posted : 02 July 2008 09:49:34(UTC)
kiwi
here are 2 crocs pulling a 2.6m freight train
Kiwi
Guest (4)
This page was generated in 0.739 seconds.
