#1 Posted : 06 August 2007 05:08:27(UTC)
I have tried out the Märklin 73400 interior lighting kits and as I show at
http://layout.mixmox.com/1/marklin-73400
there is room for a capacitor.
Has anyone added a capacitor ?
If so, what size and what were the results?
If not, can anyone suggest a suitable size and any caveats?
The circuit can be pretty much be deduced from the pictures.
Offline sudibarba
#2 Posted : 06 August 2007 05:54:41(UTC)
sudibarba
Once again you are very ahead of me. I guess you are saying that Marklin could have installed a capacitor to minimize flickering but they did not do that because of cost. How much does such a capacitor cost ? I have no idea. The labor at the factory would be quite small I guess but as they are selling to the masses I guess they count pennies.
Eric
Offline trainbuff
#3 Posted : 06 August 2007 07:31:55(UTC)
trainbuff
Hi Dale,
Thanks for pointing out the C1 pads. At least they are there if needed. I intend to power my 73400 from the loc slider so hopefully there will be steady power and I won't need a capacitor. But still an interesting observation and I'm also curious to know what size would be used if needed.
I also recently got a 73400 to check out since its not listed to fit in a thunder box (but it will if you squeeze it in at an angle, ha ha). I did not notice any flickering while testing, unlike some older stuff I have that will flicker just sitting on the track, namely a 4103 thunder box with tail lights and a 3793 BR 52. So I'm pleased with the 73400 so far...
Offline trainbuff
#4 Posted : 15 December 2007 22:08:26(UTC)
trainbuff
Ok, after having these for a while I see there is a little flicker. I hard wired my coaches together to eliminate flicker caused by current conducting coupler to baseplate contact. That helped a lot. The whole consist now has 8 axles grounded together. But there is still one spot on my track that causes a flicker. Must be dirty track but the loc does not flicker. The consist is getting power from the loc slider. So the loc must have capacitors.
**Added later: I went to clean the track and found a piece of wood the size of a tooth pick on the track! Removed that and no more flickering.**
So does anybody know what type of capacitor to add to the led strip?
#5 Posted : 16 December 2007 01:52:44(UTC)
Thanks for the report, Dale.
I think I will stick to 28 Volt bulbs or lower voltage bulbs (610080 or 610040) connected in series in my older era coaches, as I am very found of the yellow warm glow.
In daylight it should not be visible from the outside of the coach, without looking directly at the light source (or dark sucking device).
#6 Posted : 16 December 2007 02:42:27(UTC)
Maerklin will be releasing the 73401 Bright White LED lighting.
I was not too impressed with the 73400. I found that the connected bars had a tendency to sag in the middle. Additionally, there was no lighting at the ends of the coaches (washrooms and gangway on the SBB LS coaches).
I was further frustrated by the wiring. I bought one slider, which came with the ground pickups (2). I equipped the remaining coaches with Maerklin's new current conducting couplers, and very quickly found, that I did not have the ground pickups for the other coaches, nor did I have the wiring needed to connect the couplers to the lighting bars. As the lighting uses sockets and pins, it would be helpful if these were included with the lighting or with the couplers. Maerklin is releasing a set of ground pickups this year, but the wiring of the couplers is still up in the air.
I will upgrade my 26534 Set to the new 73401 White LEDs and will test Roco's powered couplings to see if I can use them to provide both ground and live leads to the coaches. If Maerklin does come out with the pilot coach as well, it should make this train even more interesting.
All in all, an interesting system that will help avoid future meltdown of plastic coach roofs and bodies that were commonplace on older coaches.
#7 Posted : 16 December 2007 02:58:06(UTC)
Thanks for the report Dale. I've just received 3 of these kits, and intend to use them in my ICE 2 train, after I set up some connectors on the coach couplings to give continuous current down the length of the train.
I was wondering how the supports for the lights were fitted, and your picture helped clear that one up - quite simple really!! [:I][:I]
As for capacitors, well I'm no expert, but I would guess a fairly small value would suffice. Don't know if it should be an electrolytic or an ordinary greencap.
I intended running the lights off the loco's slider, as the decoder in the loco doesn't have a spare function output. If I every get around to replacing the decoder, I'll run the lights of a secondary function output.
The train is one of the versions out of a starter set, hence the reason why it doesn't already have lights.
Offline trainbuff
#8 Posted : 17 December 2007 03:46:12(UTC)
trainbuff
I don't know what is considered a small value for capacitors. What ranges and types should I ask for at the electronics shop? -thanks
Offline hmsfix
#9 Posted : 17 December 2007 15:33:50(UTC)
hmsfix
Hi Dale,
very interesting pics of the 73400 lighting set. I agree, there is some space intended for a (not too big) capacitor. IMHO 50 micro farads should be o.k. (e.g. 47 uF/40 V) and prevent flickering. Precise value shouldn't matter (22 or 68 uF will certainly work, too).
But even more impressing to me are the other electronic parts: two transistors, two resistors, and a protection diode. It seems that this could be a current circuit stabilizing circuit which keeps brightness constant at changing supply voltage.
Hans Martin
#10 Posted : 27 December 2007 19:00:35(UTC)
I had installed the 73400 on two of the SBB Lightsteel coaches from the 26534 Set (2006). The lighting effect was generally ok, although it did not match the lightbulb in the Hag BDe 4/4 that I was using to pull the train.
I decided that I would re-equip those coaches with the 73401 White LED lights as soon as they were available.
I did equip those coaches with current conducting close couplers. I have commented in this theme about problems connecting the lighting strips to the contact plate for the 72020 couplers.
Today, I received a message from Maerklin (DE) in reply to a query I had submitted earlier this Fall:
[size=1" face="Verdana" id="quote]quote:Sehr geehrter Herr
vielen Dank für Ihre E-mail.
Das Verbindindungskabel ist in der Packung 72021 enthalten. Es kann auch als ERSATZTEIL gekauft werden.
Kabel 126944 mit Buchse
Kabel 126946 mit Stecker
Die Massefedern bekommen Sie als Katalogartikel 72050. In einer Packung sind 5 Stück.
Im deutschen Jahrbuch 2007/2008 finden Sie diese Artikel auf Seite 339/340....
English Translation: "The connection cable is included in the 72021 package. It can also be ordered separately as a spare part.
126944 with Socket
126946 with Sticker
The ground contacts are listed in the catalog under 72050. Each package contains 5 pieces.
In the German catalog 2007/2008 these items can be found on pages 339/340."
The 72020s that I purchased did not come with any cables, only with the couplers and replacement insert for the contact mount. Hopefully the 72021 does indeed have the needed part.
#11 Posted : 27 December 2007 21:09:05(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by trainbuff
<br />I don't know what is considered a small value for capacitors. What ranges and types should I ask for at the electronics shop? -thanks
Chris, capacitance is measured in 'farads'. 1 Farad (1f) is very very very large. 1 pico farad (1pf) is very very small - a pico, if memory serves correctly is 1/1000,000,000.
Mostly capacitors are measured in micro farads (uf). For example, the capacitors in a 12v DC power supply will be around 470uf. There are many types of capacitors as well - there are polarised (they have to be inserted the correct way around), there are greencaps, there are ceramic (the ones you see on the Marklin motor covers are ceramic), just to name a few.
I would guess, for this application, maybe around 47uf would be OK. Not sure if a polarised one is needed or whether a greencap would do. I suppose you can try and see - they only cost a few cents each.
Offline trainbuff
#12 Posted : 27 December 2007 21:46:55(UTC)
trainbuff
Thanks all for the help on capacitors. I'll follow up with results when I try the caps. It maybe awhile...
Offline DTaylor91
#13 Posted : 31 December 2007 05:27:29(UTC)
DTaylor91
Keep in mind the size of the cap when you go to install. Most likely you will want an electrolytic. Polarized ones tend to be smaller than non-polar. You will need to find one that is rated above the voltage that is running across your rails! This is most important! If the capacitor cannot handle the voltage, it will either fail prematurely, or immediately, and in a most spectacular fashion! Make sure if using polarized that you observe correct polarity (read back to the "spectacular failure" section previously). An electrolytic cap installed backwards is effectively a short circuit.
I haven't tried it yet, but my first choice would be a 10uF, 35V cap, as most of these tend to be small, can hold a decent, short-term charge, they are generally CHEAP, and easy to find. I would be hesitant to use a cap much larger than that without knowing what kind of inrush current the circuit/rectifier/power supply can handle.
If you are more patient than I (and I work on electronics for a living), you can get "surface mount" caps and try installing those, since that is the type the board is made for. If your eyesight is failing, or if you have shaky hands, or the patience of a typical 2-year-old 3 days before Christmas, go with the "normal" kind with wire leads. I would suggest, given the space available, to use a radial, as opposed to an axial cap. Polarity isn't marked, but from the photos posted above, it is easy to figure out. Match the negative ( - ) terminal of the cap to the negative ( - ) terminal of the rectifier. On most electrolytics, the positive terminal is not marked, other than having a longer lead than the negative lead.
Hope this helps,
Don
#14 Posted : 31 December 2007 06:24:41(UTC)
Thanks for the advice, Don. Yes a 10uF 35v electro cap will be small enough to fit into a coach without too much trouble.
Chris, a radial cap means the capacitor leads are both coming out of the capacitor at the same end, which will make things easier for the application in mind. An axial cap means that one lead comes out of the cap at one end, and the other lead comes out of the other end. Which means that one of the leads has to be bent down.
Offline adrian
#15 Posted : 01 January 2008 18:35:51(UTC)
adrian
I have the following problem: the wheels of the cars which I equiped with pick up shoes for lighing, are derailing on the turouts, even I was adding some extra weight on the cars. How do you handle this?
Did anyone lighted the ICE 2 cars. What pick up shoes are suitable for ICE 2?
Thank you,
#16 Posted : 30 May 2008 06:32:01(UTC)
73400 Question:
Each time I take my Lightsteel (43370) coaches out of the box, I find that I need to open at least one up to reconnect the pin/socket for the LED lighting strip.
Has anybody else had problems, either during layout use or in storage, where the wires had detached just like that?
#17 Posted : 30 May 2008 15:05:09(UTC)
Hi Mike. I put a piece of tape over the pin/socket or some tape to hold the wire in place before it reaches the pin/socket.
David
Offline gachar001
#18 Posted : 30 May 2008 18:21:41(UTC)
gachar001
India
[size=1" face="Verdana" id="quote]quote:Originally posted by adrian
<br />I have the following problem: the wheels of the cars which I equiped with pick up shoes for lighing, are derailing on the turouts, even I was adding some extra weight on the cars. How do you handle this?
Thank you,
Adrian,
I installed lighting to my ICE 2 cars a couple of weeks ago. Here is what I had to do.
I purchased a 73404 Pickup shoe (slight offset) ground spring set after reading somewhere in this forum that it was the correct one. However, the pickup shoe was too large for the car and hit the body at turnouts etc. If you look at the bottom of the steering car that already has a pickup shoe, you will notice that the underside of the car has recesses for the pickup shoe so that it does not hit the chasis while compressing. The other cars do not have this recess.
What I finally ended up doing was adding just the ground spring to this car and taking the live feed from the steering car's pickup shoe using a black wire. I used the tiny 0.4mm plug/socket which I took off the pickup shoe kit to hook the black wires up between the cars. These plugs were not too secure and kept coming off so I have just soldered the 2 black wires for now (yes. The cars cannot be separated now). I am looking for a suitable plug/socket for this application. The black wires are not visible at all and the lights work great.
Gautham
Gautham
Atlanta, GA USA
Offline martinfung
#19 Posted : 30 May 2008 20:57:45(UTC)
martinfung
Gautham, have you considered locking connectors like those from here:
http://www.action-electronics.com/molex.htm#Mini
Try the two-pin locking one: WMF-3901PRT. You can use the spare pin to pass the gound wire too.
[size=1" face="Verdana" id="quote]quote:Originally posted by gachar001
<br />Adrian,
Gautham
Still beginner, no layout, random buying
O-gauge, 3R Scale US Steamers (avatar is not of my collection, but the models are nice)
Märklin HO anything :-)
This page was generated in 1.111 seconds.
