Offline charles Sharpe
#1 Posted : 01 June 2007 21:47:09(UTC)
charles Sharpe
I wish to add more power to my layout and it has been surgested to me that a 6017 booster/60129 connection box /and 60052 transformer will be ok please could you give me your views. Charles PS I am on C track/central station.
CHARLES SHARPE
Offline rschaffr
#2 Posted : 01 June 2007 22:07:11(UTC)
rschaffr
In the first place, you should wait until you get your CS updated. It will then contain the connection for the 6017 boosters and you will not need any interface box. I don't have a CS, but as I understand it (you CS guys correct me if I'm wrong), it will work. You must isolate the section connected to the booster from your main section. The section with the booster will not send back mfx data, so any lok placed on that track will not "report in", but a lok already under control will continue to operate.
-Ron
Offline Lars Westerlind
#3 Posted : 02 June 2007 10:23:59(UTC)
Lars Westerlind
AFAIK,
the isolation between CS section and booster section should be done with a ski lifter, which I dislike. The trains must have some speed to overcome those. But there are people here that like the CS, who could give better advice to you I think.
/Lars
#4 Posted : 03 June 2007 07:41:32(UTC)
Charles,
Without putting you off, in my usual bloated way, I would highlight a few considerations. These may or may not be applicable to your particular situation however considering the future of ones layout direction may sae some duplication/doublehandling (wasted effort)
FIRSTLY:
Please refer the "Schematische Darstellung" @ http://maerklin-info.de/...s/Systemarchitektur2.pdf
Here Marklin have "put a stake in the ground" and shown that any legacy 6015/6017 track must be seperate from any "systems" track.
The ski-lifter solution only isolates the centre rail and then only in a single pickup train. This is the 1st hurdle as it provides a potential solution for when different track sections are driven from different controllers and leverages the tradition common ground for the rails.
1) a previous MM/MNews(2006?) article effectiely implied that, in a 6021 environment, there was no need for the ski-jump as long as.
a)) the booster(s) were in-phase digitally - i.e. all off the same 6021
b)) the ski did not "dwell" across the join.
most operators have known/assumed/gotawaywith this for years.
2) however with the CS , the output to the track must ALSO isolate the ground/return rail from the common ground concept.
Thus a CS/6017x solution can (may not be supported) only work if
1) the ski-jump isolates the the power (reds)
2) the transformer that drives the CS is totally sepearte from any transformer that drives a 6015/17 and does NOT have a ground(brown) in common.
The schematic indicates that the 60172 (unreleased / dropped?) will/was meant to be able to operate on a par with the CS "power to the track" .This is in addition to its ability to support bidirectional mfx.
Note: If the 60172 is wired as shown it would not need to relay mfx data back to the CS from a decoder as the track circuit is tied as one.
SECONDLY:
I reemphasise that any legacy use of a power circuit and the "common ground" concept as it relates to Accessory return (16V AC from the same transformer) or s88 contact (using the common rail as return) must be reviewed and preferably elliminated.
THIRDLY:
Not widely discussed is the subject of problem determination, and trying to identify in which circuit a short occured and its impact on the WHOLE layout.
Unitl the CS-upgrade for booster hits the streets I have no idea if the CS will indicate/isolate that section - the technology is available but the desire may not be .
For the 60129 (of similar DiltaControl as booster) implementation I see an IMMEDIATE benefit in that ONLY the relevent section cuts out. I am forever hopeful that someday the CS will be able to detect and report this information, in the meantime we still have the indicator LED on the booster. (and a momentary switch in the feed to allow a selectie reset)
FOURTHLY:
While the rumoured native attach of boosters to the CS is still pending, the information to hand is that it will use the same 5pin flat cable . This has 2 drawbacks. distance and connector type.
While the CS System-Bus does not take a leaf out of the loconet book and use industry standard RJ12/RJ45 connectors it does offer a more structured way of extending the control circuits up to 100m (As above, I am hopeful that the future will allow for feedback/status information)
My personal summary.
- eliminate any design that connects accessorys to track
- plan for independant sensor(s88) return bus (I use contact tracks extensively so this is a problem)
- plan for a 60129 mentality (one booster per 60129), even if the direct attach ends up able to deliver the same functionality.
Offline perz
#5 Posted : 04 June 2007 01:30:43(UTC)
perz
Offline perz
#6 Posted : 04 June 2007 01:36:35(UTC)
perz
Don't believe every post in this forum. Do you think Clapcott is right or do you think I am? Go on, guess!
Or take a course in electronics...
#7 Posted : 05 June 2007 21:48:56(UTC)
charles Sharpe
[size=1" face="Verdana" id="quote]quote:Originally posted by perz
<br />Don't believe every post in this forum. Do you think Clapcott is right or do you think I am? Go on, guess!
CHARLES SHARPE
#8 Posted : 05 June 2007 21:57:09(UTC)
charles Sharpe
Hi perz Please dont play mind games with me your timing is very bad at the moment I have just been told that do to a wreaked spine I will never work again and on top of that my mum was taken into hospitial last night and I had a telephone call at three am to say she has only 48 hours to live. PS wiring is not my thing[V][V][V]
CHARLES SHARPE
Offline hemau
#9 Posted : 05 June 2007 23:28:14(UTC)
hemau
Hi Charles,
Very sad to read your situation. I'm sure we all wish you strenght.
Come back to the forum when your want to. Henk
C and M track; CS1R and 2 MS
Offline perz
#10 Posted : 06 June 2007 00:18:35(UTC)
perz
[size=1" face="Verdana" id="quote]quote:Hi perz Please dont play mind games with me
Hi Charles,
Sorry, it is not at all my intention to play games with you or confuse you. The drawing I posted is to the best of my knowledge. Most of it coincides with what Clapcott is writing, but there are some more or less important divergencies.
My somewhat sarcastic comment in the second post obviously didn't get the right effect. I could have tried to make a lengthy explanation about why I think my version is the correct one, but you would need to know something about electronics to check the sanity of my arguments anyhow.
So I was hoping to get "majority support". It may seem a stupid idea to "vote" about facts, but in a serious forum like this it often works.
But nobody "voted" and the result was only more confusion. Sorry for that.
Offline Caplin
#11 Posted : 06 June 2007 00:38:10(UTC)
Caplin
Hi Charles,
Very sorry for your sad situation. Hope that you find the strenght to overcome.
Best wishes.
Benny - Outsider and MFDWPL
Offline rschaffr
#12 Posted : 06 June 2007 00:52:14(UTC)
rschaffr
Charles..sorry about your situation, but I believe Perz is correct on the ground issue. You realize that as soon as Marklin puts the modification in your CS, a common ground is going out on both the booster bus and the s88 bus directly form the CS.
-Ron
Offline dntower85
#13 Posted : 06 June 2007 01:26:59(UTC)
dntower85
Sorry to hear about your problems Charles, I hope the doctors have made the wrong predictions but will make the right decisions and all will go well.
Ok as far as voting, I would have to base my decision on how long is left on the warranty on the CS (if I had one), and how much my pocket book would hurt if I had to by a new one. As far as me I would wait for more documentation and reports which are just starting to be made,like what Luts has written. It shouldn't take long for the answers to come in.
DT
#14 Posted : 06 June 2007 02:13:25(UTC)
Charles Sorry about your new here also. May all things turn out Ok.
Nev
#15 Posted : 06 June 2007 10:31:21(UTC)
Lars Westerlind
Hi Charles,
Well,
I did not interfer partly because I don't have enough facts IMHO, and also lack of interest in the CS.
If I understand correctly, the question is if the rails need isolation as well, meaning that 6017 can't be used at all at normal layouts?
The CS has a very bad design in these aspects, but still, it seems completely absurd if they've overlooked this need. So I prefer to think that the system bus is optoisolated from the booster output stage, but I don't know. The I2C bus of the old system used the idea of common ground all over the system, but if I understand correctly, the output stages in /systems have another construct which makes this impossible. So I prefer to imagine that Clapcots references are misunderstandings or simplifications and as your sketch seems to be the only useful, but I don't really know. Comments appreciated.
/Lars
PS. Rons comment about s88 is also important; the s88 is rather useless without a common ground concept, as well as some other items, but still, doesn't prove anything. Märklin have bought a system design from ESU which certainly has not been properly checked to work with a Märklin railroad. LW.
Offline Guus
#16 Posted : 06 June 2007 11:30:24(UTC)
Guus
Hi Charles,
Very sad to hear about your situation.I wish you strenght.
Kind regards
Guus
Kind regards,
Guus
#17 Posted : 06 June 2007 12:18:48(UTC)
not sure what the vote is on.
If its the bits in blue..
Why does Marklins schematic not have the skijump
and why does it show a totally different track being powered by the legacy boosters.
#18 Posted : 06 June 2007 12:51:14(UTC)
Charles, I'm very sorry to hear about your situation.
I lost my Dad last year, and my Mum was diagnosed with cancer earlier this year. She was very ill for a while after a major operation, but is now showing signs of recovery.
My prayers are with you.
#19 Posted : 06 June 2007 13:02:21(UTC)
Lars Westerlind
<br />not sure what the vote is on.
Becuase it's a schematic, a phantasy, a marketing product, or whatever you call it. It also does not show the isolatiions needed between booster and CS etc. And it shows a "Digital Anschlussgerät" which will never be produced, as the function will more or less be integrated as a PCB in the CS.
/Lars
Offline rschaffr
#20 Posted : 06 June 2007 15:54:13(UTC)
rschaffr
Out of curiosity, and since I am actually considering a CS or ECoS whenever the computer protocol is released, I sent an e-mail to Marklin last night describing my system (seven booster zones) and asked if I could just attach the CS in place of my current controller. They said it would work. No mention of having to rip up my layout to isolate rails. (I actually got a response in under 6 hours)
-Ron
Offline laalves
#21 Posted : 06 June 2007 17:39:55(UTC)
laalves
This whole ground separation thing is being led to hysteria.
For example, I have a Delta controller connected as a digital accessory booster (several k83s) to my CS and all is fine. Guess what, the CS has common ground with the Delta controller.
Luis
PS: Charles, I deeply regret your predictaments.
#22 Posted : 06 June 2007 18:02:11(UTC)
Lars Westerlind
Luis,
that's because the Delta shares common ground with the OUTPUT of the CS. All other boosters have a connection with the central in different way; booster bus or system bus.
As a matter of fact, on my current layout (in building phase), I feed all my tracks by Delta controls! The IB output is for the Deltas, and for accessories, including one power consumer (Busch realistic sound).
/Lars
Online David Dewar
#23 Posted : 06 June 2007 22:51:05(UTC)
Hi Charles. Sorry to hear your news. I do hope things will improve for you.
If it is any support I have no idea most of the time what these guys are talking about and found over the years that by experimenting the solution usually comes good in the end. Learning by mistakes can also be useful.
Take care and best wishes
David
Offline laalves
#24 Posted : 06 June 2007 23:03:14(UTC)
laalves
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br />Luis,
/Lars
Agree with everything you say, Lars, but there's one detail: the connector cable that comes out of the booster bus from, say a 6021 or a IB, also has ground and signal cables, added by the short detection and booster on/off control cables. The format is different, but it actually also has common ground with the 6021/IB.
Luis
Offline hemau
#25 Posted : 07 June 2007 00:21:59(UTC)
hemau
My programming track, with two MS, and my layout, powered by two 66045 boosters, all share common ground. All are fed by separate trafo's, who have no connection with the common ground.
As far as I know you can even have a common ground with an analog feed, for instance the catenary.
What I would like to know if anybody has experience with a CS feeding one section of the layout and a Delta 6604(5) feeding another section. I would not like to use ski-jumpers.
Offline laalves
#26 Posted : 07 June 2007 00:46:23(UTC)
laalves
[size=1" face="Verdana" id="quote]quote:Originally posted by hemau
<br />What I would like to know if anybody has experience with a CS feeding one section of the layout and a Delta 6604(5) feeding another section. I would not like to use ski-jumpers.
Not with a CS, but with a 6021, yes. And it's not good. There are timing differences between the 6021 signal and the Delta controller, which results that, when a slider crosses over the sections, some loks just start running on their own, like if they were possessed by evil [}:)].
I would expect that the same would happen with the CS+Delta.
Luis
#27 Posted : 07 June 2007 11:31:19(UTC)
So why doesn't someone at Maerklin get off their arse and correct it.
<ul><li> If it has no purpose then delete it.</li>
<li>If it is wrong then fix it </li>
<li>If it is out of date then update it (Even the similar image from the 2006 yearbooks, now over a year old, have been updated with the 60129 &lt;and 60128&gt; catalogue references)</li>
<li>If it requires explaination then do so</li>
</ul>
ps. Just because the "Digital Anschlussgerät" fuction is rumoured to be provided as part of the CS update sometime in the future, doesn't mean that a 60128, "Connect 6021", would not be useful in some situations. How will a 2nd CS (aka 6036) attach.
#28 Posted : 07 June 2007 14:53:02(UTC)
Good luck, Charles - all the best for you and your Mom ... SmileSmileSmile
#29 Posted : 07 June 2007 16:34:07(UTC)
Very sorry to hear your mother,Charles.
#30 Posted : 07 June 2007 21:04:11(UTC)
Lars Westerlind
</ul>
Fully agree, Clapcot. All the time from the first rumours about /systems, the information about the system has been - well, poor. Mainly absent, but also wrong. Sometimes replaced, but never corrected. I tend to prefer the german way of doing it before the american - the germans speek less but do more IMHO, but in this case it has been to much also for me.
The adapter is more than a rumour IMHO. Pictures have been published. But who knows, things could change again, you might be rigth. But the I find it hard to understand how a "Connect 6021" should be useful. In the description it was said to only include turnout control, abviously because the 6036 etc only have 14 speed steps and 80 adresses and 1+4 funcntions. And the sole purpose with it was to get M Digital users to go for the CS, it was not really intended to be useful. The "sniffer" now provided is smarter, and yes, contrary to the "Connect 6021" could take a second CS as input too. But that's a waste of course.
/Lars
Power/boosters (Digital)
by charles Sharpe 23/02/2008 21:59:27(UTC)
This page was generated in 2.208 seconds.
