Offline Larry
#1 Posted : 11 March 2007 06:07:06(UTC)
Larry
My plans are to construct an incline on my layout using Bemo HOm cog track, however, this got me to wondering how steep a grade or incline you might have used in your Marklin HO layouts and exists for real in non-narrow gauge express routes in Europe.
Right now I have a few grades and they are long and very gradual but I'm tempted to construct one in my Marklin HO layout that while unrealisitic would be much more challenging. It seems to me that Marklin locos could go up fairly steep grades without problems.
While an unusually steep grade for say a Swiss 460 might be totally unrealistic, I just wondered what might be possible based on your experience?
Aside from the narrow gauge like RhB, Glacier Express, etc., what is the steepest grade in Europe for express trains?
Offline svgeorgiad
#2 Posted : 11 March 2007 10:01:34(UTC)
svgeorgiad
Hi Larry!
I have made tests with inclines as steep as 11%. Maerklin 460 (from starter set) had no problem in climbing up alone or even with 3 passenger waggons.
In my layout I have tested inclines as big as 7% and still have absolutely nor problem with any Maerklin loc. I even had tried a combination of loc with 13-15 waggons and even the cheaper models like the OBB2016 or the BLS had no problem besides a small reduction of speed. ROCO and PICO locs of my collection had considerable trouble in climbing up such steep inclines.
You can test my layout page in the LAYOUT FORUM for pictures.
Symeon
Symeon Georgiadis
Offline MärCo
#3 Posted : 11 March 2007 11:41:00(UTC)
MärCo
A steep grade in a real railwayline in Europe I know is the Lickey Incline, a few miles before Birmingham New Street station. It is situated on the line from Bristol Temple Meads to Birmingham New Street. The gradient is of 1:37 3/4 (2.65%), and is 2 miles long. Even today some goods trains needs banking assistence.
The Lickey Incline is the steepest grade in England.
More about the incline —> http://en.wikipedia.org/wiki/Lickey_Incline
Absolutly AFB-NOHAB fan ;-)
Offline perz
#4 Posted : 11 March 2007 12:11:23(UTC)
perz
Many Märklin models will, on a straight line and with no or few cars, make it on a 10% grade or steeper.
If you want grades in curves, safe operation with small switchers, trains with more than 2-3 cars etc. , I would say that 4 % is quite safe and 5 % is the absolute maximum.
Offline Markus Schild
#5 Posted : 11 March 2007 12:52:42(UTC)
Markus Schild
Hi Larry,
the steepest grade I know in Europe is the Flåmsbana in Norway: 1:18 (5.5 %):
http://en.wikipedia.org/wiki/Fl%C3%A5msbana
Markus
Offline stephenbb
#6 Posted : 11 March 2007 15:12:34(UTC)
stephenbb
For many Marklin engines its not the grade as much as the transition to the grade. I have 3% grades on some of my layout. Howver you can't have sharp transitions some of the larger engines like 45's will loose traction, not on the grade but the transition area.
Stephen(USA)
ETE,NMRA,MEA
Offline Davy
#7 Posted : 12 March 2007 16:26:31(UTC)
Davy
In germany the steapest grade in the real world is almost 5%.
M-track with a CS2.
#8 Posted : 29 March 2007 22:09:44(UTC)
Rätische Bahn in Switzerland climbs with normal traction up to 7% on the Bernina Bahn. I took it with some friends last summer.
As far as I know, 7% is close to the possible limit for normal traction.
Offline hmsfix
#9 Posted : 29 March 2007 23:25:02(UTC)
hmsfix
One of the most famous railroad grades in Germany is the "Geislinger Steige". As far as I know it is 2.5 %, and the total height difference is around 200 meters.
This is not the steepest grade, but it is on the main line between Stuttgart and Munich, and all express trains have to pass the "Steige". Usually the IC and ICE trains make not more than 80 kmh here.
Concerning M* models the "champion" of my collection is the PA-1 (37610+49610). It once managed a 23 % grade.
However, I don't think that it can pull many cars over this grade.
Hans Martin
#10 Posted : 29 March 2007 23:42:23(UTC)
Larry and Markus:
I obviously shot a photo at the same spot as the Wikipedia-one at the Flåmsbana:
A very nice train ride, especially the top part.
#11 Posted : 29 March 2007 23:43:11(UTC)
Very good PA-1.
Offline Troy Yang
#12 Posted : 30 March 2007 00:08:26(UTC)
Troy Yang
I think on there are some very steep grade on the Swiss Gotthard and German Black Forest routes. They used spiral tunnels to overcome these.
Offline MärCo
#13 Posted : 30 March 2007 00:30:18(UTC)
MärCo
Using spiral tunnels most of the times indicate avoiding as much as possible steep grades. Best on to try, if you are ever in the neighbourhood —>
http://www.wutachtalbahn...lebahn/wutachtalbahn.php
#14 Posted : 01 April 2007 15:03:19(UTC)
Cool link,Thanks MarCo.
Offline Mein Schells
#15 Posted : 06 April 2008 23:33:29(UTC)
Mein Schells
A big thank you to everyone who posted to this question. I have been contemplating the ideal grade on a helix. The best from a space constraint perspective is 3% but I could modify to get down to 2.6%. Based on what I see here it should work at 3% and still pull multiple (20+) cars. I am running newer Marklin locs (Big Boy from starter set, PA-1's (double headed), and a few older F7s. I will post back (probably a year from now!) to let people know how it works in the real world (only in planning stage right now (CADRail v. 8).
Smägol whines about Samwise, "Fat hobbit always so polite..."
Offline Frostie
#16 Posted : 06 April 2008 23:57:44(UTC)
Frostie
I am finding that 4% is the max that I can get away with. I have some long steam locomotoives and steep inclines are difficult for them. If you have mallets it works okay, but a long steamer with fixed wheelsets makes steep inclines hard to work with.
CS/MS Digital Era 1/2
#17 Posted : 07 April 2008 00:43:59(UTC)
Mein Schells
Thank you Frostie - at least I am going into it eyes wide open...
Offline pmgsr
#18 Posted : 07 April 2008 14:12:56(UTC)
pmgsr
In the process of starting to build my layout i tested my helix (R1) with lots of locos. No problem. But when the Gottardo 39540 arrived, i had to adjust the helix... [:I] and it still needs some attention.
So i guess that, on models, the steep grade can be larger but problems could still happen on some special trains like this one (no matter what's been said i'm a happy Gottardo owner biggrin)
Pedro Rosa.
Linda-a-Velha / Lisbon, Portugal.
My Layout (Marklin, C-Track, Digital)
Offline nfotis
#19 Posted : 08 April 2008 23:40:09(UTC)
nfotis
In the prototypes, a 2.7% grade like the old Lotschberg ramp are a practical limit for mainline railroading in Europe. Note that the rolling resistance is higher when the wagons are in curves instead of a straight line.
In the USA, mountain grades higher than 2.3% are very rare (classic case Tehachapi), but these are very long and twisting, making necessary lots of locomotives
(typical consist in Tehachapi: 10+ 4000hp+ each diesels in 2-3 groups for 140+ wagons).
For model railroaders, for reliable operation in a helix I would advise against grades higher than 2.5% (note that there is resistance from the curves, and in a helix the resistance is becoming higher and higher as more wagons enter it).
Even better, limit yourself to 2% grades if you plan on pulling long trains without helpers.
N.Fotis
Guest (5)
This page was generated in 0.687 seconds.
