marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Login
Register
OK
General topics
H0-scale
F7 Upgrade
2 Pages
1
2
Go to Page...
F7 Upgrade
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
Posted :
27 January 2007 01:30:02(UTC)
Retweet
<br />Fair right [^] ... And thanks, Neville - for fighting that decisive first battle for us
Missed this one John,
I was not the first, Hans Martin did one earlier, not with MFX though, all I did was follow his instructions.
Nev
User Profile
View All Posts by User
View Thanks
Posted :
27 January 2007 17:22:06(UTC)
Retweet
Ah, well ... so the very same thanks to Hans Martin, too
- both of you are true pioneers !!!
Sorry - but with that huge amount of information here in this great forum I tend to forget some of it [:I]
User Profile
View Thanks
alonso231gery
#53
Posted :
27 January 2007 17:31:34(UTC)
Retweet
Is there an Amtrak loco that has a 4 digit code and has 3 parts?
An outsider.
User Profile
View Thanks
Posted :
27 January 2007 17:39:11(UTC)
Retweet
Originally posted by alonso231gery
<br />Is there an Amtrak loco that has 3 parts?
Yep - #37621, A-B-A, 2 motors, 6090 Digital FX, 1997-1998
User Profile
View Thanks
alonso231gery
#55
Posted :
06 August 2007 04:21:01(UTC)
Retweet
Hello Nev , you used the ESU 62436 MFX Loksound decoder so as to control the two motors ?
An outsider.
User Profile
View Thanks
Posted :
06 August 2007 05:53:12(UTC)
Retweet
<br />Hello Nev , you used the ESU 62436 MFX Loksound decoder so as to control the two motors ?
Yep that is the decoder I used. HOWEVER I think that the Part Numbers really refer to the Sound File Loaded. I have had no problems with driving the 2 Motors.
User Profile
View Thanks
alonso231gery
#57
Posted :
06 August 2007 13:51:14(UTC)
Retweet
Two fx decoders with the same adress is an option ?
An outsider.
User Profile
View Thanks
laalves
#58
Posted :
06 August 2007 15:37:27(UTC)
Retweet
<br />Two fx decoders with the same adress is an option ?
It is, but IMHO it's more likely that you may run into different running speeds of the two motors, since you will in fact have two different loks, knowing nothing of each other. If you use the same decoder, you'll be reducing the probability of trouble
WWW
User Profile
View Thanks
alonso231gery
#59
Posted :
06 August 2007 16:16:57(UTC)
Retweet
Hello Luis .
M does not produce a decoder for 2 motors , so i am trying to figure out what should i ask from ESU .
Can you solder two cables instead of one ?
An outsider.
User Profile
View Thanks
hmsfix
#60
Posted :
06 August 2007 17:06:19(UTC)
Retweet
Connecting two dc motors in parallel to one decoder sounds primitive, but I think it is a very safe and intelligent circuit, as the motors tend to sync their revolution speeds. Impossible when each motor has its own decoder.
That's easy to see. Consider the case that one of the two motors has a higher revolution speed than the other, for some reason. As a consequence it generates a higher voltage across its brushes, and thus supplies additional electic power for slower motor. This slows down the faster motor, and speeds up the slower one, i.e. the faster motor works as a generator.
Well, that's a strongly simplified explanation, but mutual stabilization of two parallel dc engines is well-proved when e.g. combining several electric generators in power plants.
Hans Martin
User Profile
View Thanks
Guus
#61
Posted :
06 August 2007 17:24:11(UTC)
Retweet
Hi Nikos,
originally posted by Nikos:
...., so i am trying to figure out what should i ask from ESU .
For example HAG uses a single Lokpilot 2.0 for powering two motors in their Re 6/6 Cargo Muri model.
Kind regards
Guus
Kind regards,
Guus
User Profile
View Thanks
laalves
#62
Posted :
06 August 2007 18:15:12(UTC)
Retweet
<br />Hello Luis .
As a matter of fact it does, albeit only as a spare part. One such example are the twin swiss loks, 37591 and 37593 and their decoders P/N 600597. They're big but I'm pretty sure you'll have the room needed in your basically empty F7. However, I see no need for such a costly solution, when you can perfectly use even a bog standard Lokpilot, not to mention a Märklin 60902. Rest assured it will work very well.
If you are really, really afraid of excess current draw, there's even another ESU solution for you a LokpilotXL or even a LoksoundXL. The LokpilotXL will actually fit in H0 loks, such as the F7 and many other big diesels and electrics. Not sure if the LoksoundXL will fit though. If I remeber correctly, the LokpilotXL is capable of handling 3 amps motors! Still, by all means use a standard H0 decoder such as the Lokpilot.
It's perfectly adequate, and you just have to connect the motors in parallel. As Hans explained, one will stabilise the other, and the result is a very strong and stable puller.
Ah, just rememebered another twin motor example: my turbine train, the BR602. It has a single, normal Loksoundmfx in it and it pulls like a horse.
Luis
WWW
User Profile
View Thanks
alonso231gery
#63
Posted :
06 August 2007 20:06:04(UTC)
Retweet
Hello Guus , Hans and Luis .
I have seen how the motor is connected with the decoder , i guess what u have to do is to remove the two delta decoders and connect the LoksoundXL to both locos , by soldering the first motor to the decoder and connecting to the soldering point the other motor as well , is that the in paraller connection Luis ?
An outsider.
User Profile
View Thanks
laalves
#64
Posted :
06 August 2007 20:10:45(UTC)
Retweet
<br />Hello Guus , Hans and Luis .
It is. But do ponder the extra spending in an XL decoder. As I said the standard Lokpilots and Loksound will be more than enough. Still, if you're REALLY afraid of having a limit in the output current to your motors, the XL decoders are the sure way to go.
Good luck, and be sure to report on your efforts.
Luis
WWW
User Profile
View Thanks
alonso231gery
#65
Posted :
06 August 2007 20:14:50(UTC)
Retweet
Thanks Luis , i am just making plans , but the canditates for that conversion is a twin motor f7 or a delta V188 that i want also to paint snow camouflage on her .
When i will do it i will make a thorough report with images .
An outsider.
User Profile
View Thanks
Posted :
07 August 2007 02:00:28(UTC)
Retweet
Hans Martin and I have done the F7 with only one Delta Decoder. Hans used the Loksound and I Used the MFX. as far as I can remember there was only one Decoder in the F7 from New.
Use the MFX Loksound Decoder
User Profile
View Thanks
hmsfix
#67
Posted :
07 August 2007 13:26:16(UTC)
Retweet
Yep, that's right.
The Lokpilot and Loksound decoders can handle 1,1 A of motor current. On my double motor F7 I never have more than 0,35 A per motor. No risk.
Hmm, in principle one could even control a super cool triple motor F7 consist with one decoder (= 1,05 A max.)
Hans Martin
User Profile
View Thanks
Posted :
10 August 2007 00:26:03(UTC)
Retweet
Originally posted by hmsfix
<br />Consider the case that one of the two motors has a higher revolution speed than the other, for some reason. As a consequence it generates a higher voltage across its brushes, and thus supplies additional electic power for slower motor. This slows down the faster motor, and speeds up the slower one, i.e. the faster motor works as a generator
Thanks, Hans Martin - this is most interesting information
Reminds me a bit of "Das physikalische Gesetz der kommunizierenden Gefäße" ...
User Profile
View Thanks
jonquinn
#69
Posted :
10 August 2007 04:34:31(UTC)
Retweet
here's another option for re-motoring
http://www.sb-modellbau....ucts_id=476&cPath=27
I think I will do it on my alaskan F7. I have a few others, and if that works well, they will get the same treatment.
it will get a loksound decoder too.
User Profile
View Thanks
hmsfix
#70
Posted :
10 August 2007 11:56:36(UTC)
Retweet
Hi Jon,
Installing a Faulhaber motor is indeed an interesting option. Old F7 will run like a Big Boy, I guess
Hans Martin
User Profile
View Thanks
F7 Upgrade problem
Digital
by
26/08/2012 14:50:01(UTC)
3481 F7 upgrade
Digital
by
sudibarba
27/01/2008 05:37:02(UTC)
2 Pages
1
2
Go to Page...
General topics
H0-scale
F7 Upgrade
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
This page was generated in 0.651 seconds.
