Online hxmiesa
#1 Posted : 18 January 2007 11:35:49(UTC)
Hi guys,
I am wondering what exactly is a "FX" decoder?
Is it the same as the 6090x series decoders?
Is it a lokpilot?
What features does it have? (and what DOESNT it have?)
And -most importantly- is it oneSPECIFIC decoder, or does "FX" just refer to anything that is NOT MFX?
Thanks in advance.
#2 Posted : 18 January 2007 12:14:42(UTC)
AFAIK Fx is a Motorola Protocol. MFX is Motorola but with Feed Back.
Could be horribly wrong. But will stick my head out to get more knowledge
Lokpilot Decoders will "Read" both DCC and Motorola (FX).
Nev
Offline Davy
#3 Posted : 18 January 2007 12:31:32(UTC)
Davy
From the Marklin website.
FX,
Digital decoder with additional, digitally controlled functions (f1, f2, f3 or f4) when operated with the with the 6021 Control Unit. The functions present depend on how the locomotive is equipped. Standard function (function) active during conventional operation.
M-track with a CS2.
Offline kgsjoqvist
#4 Posted : 18 January 2007 13:45:06(UTC)
kgsjoqvist
<br />AFAIK Fx is a Motorola Protocol. MFX is Motorola but with Feed Back.
Nev
The mfx decoders are "multiprotocol" for Motorola and /systems (but not NMRA-DCC). The Mobile Station and Central Station are too. But if both central and decoder are mfx-enabled, they negociate when the loco is first put on the track and choose from 16000+ addresses. This means you can have two identical locos with the same Motorola address, but MS and CS can handle both separately. The fx decoders have only a Motorola address, so they use the old protocol.
Besides that, there are also improvements like 128 speedsteps and maximum of 16 functions in the mfx decoders. So mfx is a bit more than just an extension of the Motorola protocol, even if all Märklin decoders and all controllers still support "Motorola".
Online hxmiesa
#5 Posted : 18 January 2007 16:37:09(UTC)
Additional doubt/question;
Is the FX inferior to the 6090x style decos? (in regard to speedsteps, prgramability to handle more than 80 addresses, etc.)
Offline frankie
#6 Posted : 18 January 2007 16:54:44(UTC)
frankie
6090X decoders are FX, AFAIK, the MFX upgrade kits have different part #.
Alessandro
I have a CS1 Reloaded!
Offline frankie
#7 Posted : 18 January 2007 16:59:01(UTC)
frankie
Just checked, they become 6092X.
You can buy 6090X motor parts and then use an ESU 61600.
Alessandro
Offline perz
#8 Posted : 18 January 2007 23:46:40(UTC)
perz
<br />Additional doubt/question;
[size=1" face="Verdana" id="quote]quote:Originally posted by frankie
<br />6090X decoders are FX, AFAIK, the MFX upgrade kits have different part #.
6090X decoders are fx, but also the new on-track decoders, e.g. those in the 60760 conversion kit, are fx if they aren't mfx. See Davys previous post.
#9 Posted : 19 January 2007 11:58:04(UTC)
Several M* locos have been sold with 6090x and PIC decoders, some even with mfx decoders. So fx in the catalog doesn't tell which decoder the loco has.
It only shows the loco doesn't have a 6090 or earlier decoder.
Online hxmiesa
#10 Posted : 19 January 2007 12:48:05(UTC)
So, FX so far only means that it is NOT mfx.
What I am still looking for to understand, is if there are any MINIMUM features *guaranteed* with an FX loco? Davy meantions F1-&gt;F4.
What about address-range, lastreglung and speed-steps?
Could it be that FX just means "Compatible with Motorola I", and Märklin simply will call ANYthing which is not mfx for "FX" ???
Offline kgsjoqvist
#11 Posted : 19 January 2007 15:03:04(UTC)
kgsjoqvist
<br />So, FX so far only means that it is NOT mfx.
I would say it's the later criteria - the decoder is not mfx capable. It has even been used in the catalogue for locos with 6090x decoders (probably they are all sold out now), but never for Delta locos. So I would say that a minimum requirement is that it can handle addresses 1-80 and has adjustment possibilities of speed and acceleration/braking. Functions depend on the loco as well, some of the starter locos don't have lights, and the decoder in them lacks output for functions - but is still "fx".
For a while I thought the 36xxx item numbers would be used for "fx" equipped locos and 37xxx for "mfx". But some 36xxx locos have mfx decoder...
#12 Posted : 19 January 2007 15:48:38(UTC)
<br />Could it be that FX just means "Compatible with Motorola I"???
FX decoders all support Motorola II.
FX decoders support at least one out of F1 through F4 (which requires Motorola II).
They are compatible with Motorola I - but mfx decoders are that, too.
Motorola I only supports "function" for loco decoders, not F1 through F4. There are function decoders for Motorola I that support F1 through F4 by means of a different protocol.
FX decoders with mouse pianos (DIP switches) have 80 addresses and 27 speed steps).
Programmable FX decoders have 255 addresses (rumours say some are limited to 80 addresses, but so far all I have tried support addresses above 80), but only 14 speed steps with CU6021/IB.
They are FX decoders even if the only function is F4 to disable acceleration / braking delay.
However there are some FX locos where acceleration / braking delay cannot be disabled (39103, 39104, some C-Sine V200).
#13 Posted : 19 January 2007 18:04:05(UTC)
I refer you all to Davy's contribution to this topic. By Marklin's definition (you can look this up on the back inside cover of most Marklin catalogues), FX means that the decoder will recognise functions F1 to F4. This was brought into use when Marklin introduced the Motorola II format. It has nothing to do with MFX.
#14 Posted : 19 January 2007 18:51:23(UTC)
<br />I refer you all to Davy's contribution to this topic. By Marklin's definition (you can look this up on the back inside cover of most Marklin catalogues), FX means that the decoder will recognise functions F1 to F4. This was brought into use when Marklin introduced the Motorola II format. It has nothing to do with MFX.
Everything you say is correct.
But the catalogues don't tell the whole story. Several locos marked as fx in the catalogue where produced as both 6090x and mfx versions. They keep fx in the catalogue (maybe to protect dealers that have old versions on stock).
I prefer 6090x locos over mfx locos. And if the catalogue reads fx, you can still end up with an mfx loco with its abominable speed characteristics and only 14 speed steps (speaking as an IB user).
fx has nothing to do with mfx because fx existed before mfx, but fx locos sometimes have mfx inside.
Online hxmiesa
#15 Posted : 19 January 2007 20:39:54(UTC)
Thanks to all of you who have answered! It is slowly coming together for me now...
I will risk to opiniate a bit already, because my "fears" seems to be reality; The "FX" description is practically useless for the end-client. In certain situations we will end up with a worse product than older 6090x types, where at least you KNEW what you were getting. Now it can be anything!
I am not an expert with Märklin Digital. (Actually the totally opossite! ;-) -But the worst of this IMHO seems to be only 14 speedsteps if you use 6021/IB. If I were using digital I would take that as an insult!!!
If anyboy else is in the know about FX oficial (or unoficial) specifications, please speak. I would LOVE to have my opinion proved wrong! :-/
Offline Hemmerich
#16 Posted : 19 January 2007 22:47:20(UTC)
Hemmerich
You can simply take for granted what Davy (as an "expert") stated already before. wink
For any further explanations on "fx" please see: http://www.maerklin.de/produkte/pdb/index.php and click on the "Info" box; most to all pictograms are explained there. Technically "fx" simply means that the corresponding mfx, ASIC or PIC decoder is able to recognize the f1-f4 bits which are sent together with the digital loco or function address byte.
Märklin produced a few digital models in the past (end of 2004) as well with mfx decoders w/o changing their original product #; those models that were manufactured with mfx decoders (should) have the corresponding labels on the box and accompanying instruction booklets, so both dealers and customers knew what they got. It was a limited offer and not "generally available" and thus also not explicit mentioned in the product database or even the catalog (you might find a related remark in a recent Koll collectors catalog). Amongst those models were for example BR18 (#37184), BR140 (#37401), BR111 (#37316), ET87 (#37265), BR212 (#37725), Mikado (#37973) and Cargosprinter (#37090).
IMHO every manufacturer has the right to change/improve a product any time without further notice. Cool
BTW: When people learned about those special models, they almost went crazy to catch one of them. biggrin
Offline grnwtrs
#17 Posted : 20 January 2007 04:03:58(UTC)
grnwtrs
Nice that you waited for everyone to respond before you replied. The benefit of insight and years is wonderful. You serve your master well!! Any more gems of wisdombiggrin
#18 Posted : 21 January 2007 21:36:30(UTC)
<br />IMHO every manufacturer has the right to change/improve a product any time without further notice. Cool
From my point of view this is a regression, not an improvement - they changed the product to save money.
And the same is happening now with the compact c-sine motor. If the catalogue says c-sine, you can't be sure if you'll get the "real thing" or the compact imitation. From my point of view this is another regression.
I read that a company is developing replacement motors for M* VT 08.5 (it seems I'm not the only one calling this a regression).
Offline Hemmerich
#19 Posted : 22 January 2007 00:54:19(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by h-zero
...they changed the product to save money.
This could be one of many reasons. I think it is legal and understandable (actually an objective for product changes in almost every company!).
With respect to the topic (fx function) and in comparison of new vs. old products (i.e. 60901-60904 vs. 60921-60924) I think that customers received improved functionality with:
- automatic decoder addressing and function symbol allocation (mfx)
- extensive mapping feature
- way more function output features than before, like dimming (saves for example replacement of bulbs) and other special effects.
PS: Already the old C-Sine was produced by another company.
#20 Posted : 22 January 2007 02:35:34(UTC)
<br />With respect to the topic (fx function) and in comparison of new vs. old products (i.e. 60901-60904 vs. 60921-60924) I think that customers received improved functionality
Not really - or at least not all.
Catalogue says that fx locos can be used with Delta. No problem if the loco has a mouse piano - otherwise you'll need someone to change the address for you.
I use an Intellibox. Old C-Sine has 27 speedsteps, new compact C-Sine has only 14 speedsteps with an abominable speed curve (which I cannot adjust without help from a CS user).
In between there were non-mfx non-mouse-piano decoders with only 14 speed steps - and AFAIK also only 14 speedsteps for CS users. No improvement, only money saving.
I use an Intellibox and have 28 or 128 speedsteps with DCC locos. Switching to CS would mean a regression for using these locos.
And only because M* decided to do the same things DCC does, but with the proprietary mfx protocol.
So I'll keep my IB until I find a central that handles MM, mfx, and DCC.
Online hxmiesa
#21 Posted : 22 January 2007 10:03:40(UTC)
Also, as an analogic user, I have now no way of setting the max speed and acceleration, as I had with 6090x types! :-(
I have SOME understanding for not being fully supported -running only analog-, but if even fully digital users are seeing a degrading of the products...?
#22 Posted : 22 January 2007 14:30:32(UTC)
The new C-sine is more compact, allowing it to fit in the boiler of a steamer, not like the old motors, including old C-sine, which fill the cab in an unrealistic way. I would consider this an improvement.
Even in diesels and electrics, very often the old motor types extend into one of the cabs, spoiling the view through the windows.
Let's not see every change that is made as negative. As the saying goes, "You can't please all of the people all of the time..."
Offline Hemmerich
#23 Posted : 22 January 2007 17:41:45(UTC)
Hemmerich
My statement was explicitly related to the fx functionality, regardless of the decoder type(s), since this was/is the thread topic/question.
IMHO Märklin has never stated support for Uhlenbrock digital products. Cool
Online hxmiesa
#24 Posted : 23 January 2007 12:00:33(UTC)
<br />My statement was explicitly related to the fx functionality, regardless of the decoder type(s), since this was/is the thread topic/question.
Well, just as a personal side-note; I think there is nothing wrong in going "over and beyond the call of duty" when answering technical questions here in the forum.
I certainly value any additional information the members always give.
Although my trains are 95% Märklin, the CS is certainly the LAST digital control I would consider buying, so compatibility to Uhlenbrock, ESU, Lenz, etc. are very important to me.
As Märklin cannot be held responsable for compatibility with 3rd parties products, this extra (indeed "value added") information is very important.
Otherwise how would we know? From you, Lutz? ;-)
Offline Hemmerich
#25 Posted : 23 January 2007 12:59:22(UTC)
Hemmerich
That was not the point - some people may want or like to discuss in one single thread about "god and the world", with the potential of complete defocus - I really don't mind.
My answer was stating a clear improvement of features for the "fx" functionality of decoders (actually regardless whether they support mfx, Motorola or DCC). Anyways, when choosing Systems (i.e. mfx), Märklin customers get as well more features than they got with previous generation decoders. Just normal.
[size=1" face="Verdana" id="quote]quote:the CS is certainly the LAST digital control I would consider buying, so compatibility to Uhlenbrock, ESU, Lenz, etc. are very important to me.
That's your own personal decision (and maybe problem). If you change the wording of your sentence slightly, it comes probably closer to reality: "so compatibility of Uhlenbrock, ESU, Lenz, etc. are very important to me". biggrin
[size=1" face="Verdana" id="quote]quote:As Märklin cannot be held responsable for compatibility with 3rd parties products,
Again, the reality is: "Märklin cannot be held responsible for compatibility of 3rd parties products..."
Actually they even always made and still make clear to everyone where and how they see their "field of responsibility".
[size=1" face="Verdana" id="quote]quote:Otherwise how would we know? From you, Lutz?
Yes, too - if deemed suitable or helpful from my viewpoint - about a specific topic or part thereof; which might well be different from yours and your "desired answers". Different views can help. I spend probably more time analyzing and comparing other supplier's products (including own purchase) with those of Märklin than you might assume.
From my own experience I can say that those new "fx" functionalities, for example also provided with mfx decoders today help me alot to implement and operate certain train "features" easier. After the ESU announcement of their LokPilot fx decoder (#52600/52601) it might well be possible that Märklin and/or ESU will come up in the near future even with a specific mfx function decoder (preferrable with more than 6 outputs).
Online hxmiesa
#26 Posted : 23 January 2007 13:35:26(UTC)
Oh come on. I find that insulting and below standards!
Although my english obviously sucks to you, I would think the general meaning comes through alright. Not all of us speaks english like natives.
[size=1" face="Verdana" id="quote]quote:My answer was stating a clear improvement of features for the "fx" functionality of decoders (actually regardless whether they support mfx, Motorola or DCC). Anyways, when choosing Systems (i.e. mfx), Märklin customers get as well more features than they got with previous generation decoders. Just normal.
Well, that is certainly a respectable view of things, although I find the reality to be the totally opposite, especially when reading h_zeros/Tom's message. (Parts of it actually concerns Märklin only! ;-)
As another side-note (now that I´m at it); I´ll say that your clear and specific answers are also always appreciated for their huge amount of information and knowledge. Less so, your desire to impose YOUR own specific interpretation of a given subject, or telling me that I have "desired answers"; I have an open mind, -I am trying to get a picture of reality, trying to see THROUGH Märklin propaganda.
#27 Posted : 23 January 2007 14:35:02(UTC)
Why do so many of these topics degenerate into arguments over who is in favour of Marklin or against?
The topic is "What is an FX decoder?" While I welcome the extra insight offered by forum members who explain the background to this issue, I am fed up of reading the same old arguments about what Marklin should or should not be doing![xx(]
Could we have a seperate section for these arguments, maybe titled something like "Personal non-Marklin preferences", or "Third party compatible equipment", so that we can contain the arguing? Please??
I would then know never to read those posts!!!
Offline Hemmerich
#28 Posted : 23 January 2007 19:06:00(UTC)
Hemmerich
Oh come on.
To make that story short: I think Henrik missed the point of my "message" - we talk about product functionality/features.
(if someone really desires a "face-to-face" personal discussion, I propose to use the private message feature of this forum).
When reading any Märklin Digital/Systems product description, there is no single word about other companies' products, "3rd Party" products or even any compatibility with those mentioned by you. Fact (i.e. reality) is that Märklin simply just cares about and supports only their own digital products, as stated in those documents.
So, compatibility with digital products of other companies is apparently no Märklin objective or priority - whether you or others like this or not.
This might be quite different/the opposite for those other companies. (just business reasons).
As said, using Systems is key (IMHO Thomas is not a Systems user).
Just a simple comparison of "fx" capabilities without and with Systems/mfx may make the improvements more clear.
- #of possible functions
- output options (dimming, smoke, telex, light features)
- free mapping of functions with keys and symbols
- direction dependency of functions
- combining of functions, etc.
This overall increased functionality and flexibllity allows for example quite easy to define different and more (realistic) light operations, where with the older "technology" additional HW was needed.
Similar true is it for not "fx" specific, driving related functions like:
- different speed curves
- ABV (both ACC and DEC)
- Shunting
- break sound and various other sound related options
- 128 mfx decoder speed steps when using Systems
#29 Posted : 23 January 2007 19:50:10(UTC)
<br />As said, using Systems is key (IMHO Thomas is not a Systems user).
Dear Lutz,
so what is "Systems" then? I have CU6021, IB, and Mobile Station.
I cannot change the speed curves, I cannot remap functions, I cannot use 128 speed steps (except with DCC locos).
If you have a CS and convert locos with mfx decoders then you can make use of the improvements you mention (switching rear lights separately without extra hardware). But you don't get this with most M* digital locos (eg V90: f1 through f3 are unused and rear lights are always on when front lights are on).
For the price of one CS I can buy 20 MM/DCC decoders with 21-pin plug. And that's what I intend to do in the near future.
A few years ago M* offered locos as Delta and fx versions. In the '90s they even offered up to 4 versions of the same loco: analog 3-pole, analog 5-pole, Delta, Digital.
If they would simply offer two versions, one with mfx decoder and one with MM/DCC/SX decoder (Trix), then I'd be much more happy; I could change the speed curves with my IB, use 28 or 128 speed steps, and I'd have more addresses available than I'll ever need.
#30 Posted : 24 January 2007 00:48:41(UTC)
Lutz,
On a CS and MFX Decoder where do you get the light dimming function. I have searched but have had no luck.
Nev
Offline Hemmerich
#31 Posted : 25 January 2007 01:28:25(UTC)
Hemmerich
Dear Lutz,
Sorry - I should have been more precise - I meant Systems with CS since this gives you all possible capabilities, including for example the change of speed curves, function icons and numerous other options (IMHO I had also just understood that you were using an IB).
It should as well be obvious that neither the MS was designed to be a full blown Systems/mfx programming tool nor have "older generation" products like a 6021 or IB ever been designed for that purpose or will support all functional features of the new Systems controller, namely the CS.
Offline frankie
#32 Posted : 25 January 2007 12:22:49(UTC)
frankie
Lutz,
Nev
Yeah, where is it?
Alessandro
#33 Posted : 25 January 2007 12:26:29(UTC)
Lutz,
Nev
Yeah, where is it?
Lutz,
Help, Help confused
Offline MarioFabro
#34 Posted : 30 January 2007 14:59:10(UTC)
MarioFabro
Ok.. I got back into THE passion after a year or two hiatus (workload) and have started buying again.. and again.. and again. I have now close to 60+ locos and more coming. I am planning to buy the CS to go with my 6021 (a propos .. any word on that connection gizmo that may make the two working together?) but.. i digress.. my question here is about mfx adresses. With the CS do I have to worry about two locos (a 39606 Re 465 with old decoder and the new 37490 GG1 with mfx) having the same address? I believe the CS will handle the two separately that means I can forget about setting new addresses on the new mfx decoders and "keep" the 1-80 range for my old ones (or ESU, or Lenz, or etc.). Right?
#35 Posted : 30 January 2007 18:17:37(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by MarioFabro
<br />I believe the CS will handle the two separately that means I can forget about setting new addresses on the new mfx decoders and "keep" the 1-80 range for my old ones. Right?
Right, Sir! And - welcome back, Mario Smile
#36 Posted : 30 January 2007 18:57:22(UTC)
Welcome back Mario.
#37 Posted : 31 January 2007 00:05:39(UTC)
Mario,
MFX Decoders have a Unique Identification, Something like Computer Network Cards, So they are clearly identified by the CS and MS even if they have the same address.
There will be no clashing of MFX addresses. You do not have to set them
Nev
Offline Hemmerich
#38 Posted : 31 January 2007 00:40:43(UTC)
Hemmerich
Lutz,
Nev
You should take a look at the LokProgrammer function mapping screen; for every mfx decoder output you can configure this. With previous fx decoders (i.e. 6090x) this was not possible.
This page was generated in 1.463 seconds.
