Offline jkoellmer
#1 Posted : 26 December 2006 20:35:03(UTC)
jkoellmer
Hi and Merry Christmas to you all,
Santa brought me a 36330 digital Swiss switch engine (wonder how he knew?) for use on my swiss layout. It works great, but I noticed in the instruction manual that the F4 key is supposed to enable "Low Speed Switching Range (only ABV)". I don't notice any difference in operation with or without F4 depressed. Does anyone know what "ABV" stands for?
Jeff
Offline Sander van Wijk
#2 Posted : 26 December 2006 21:11:42(UTC)
Sander van Wijk
Hi Jeff,
ABV stands for: Anfahr-Brems-Verzögerung (Accelaration-Decelaration-Delay). By using this function you have the decelaration and accelaration under direct control. If you don't see any difference it probably has to do with the settings of your decoder, if (in normal mode, f4 off) the loco does not brake and accelarate slowly you will probably not notice a difference if you shut the ABV off.
Sander
Offline mmervine
#3 Posted : 26 December 2006 21:40:12(UTC)
mmervine
Jeff:
Congrats! Is the shell metal or plastic?
r/mark
Offline Hemmerich
#4 Posted : 26 December 2006 22:21:04(UTC)
Hemmerich
Hi Jeff,
you might want to reset the decoder of this loco or simply change the acceleration(ACC)/deceleration(DEC) to a desired value by you; factory default settings are 3,48s and 2,61s.
When pressing f4 the loco should react quite direct upon changes of the speed knob. Mine for example takes nearly two track lenghts (about 30cm) from medium speed (150/step 8) to 0 without the ABV button pressed and about 5cm when the button is active. biggrin
Offline jkoellmer
#5 Posted : 26 December 2006 22:48:35(UTC)
jkoellmer
Thanks all! Mark, I believe its plastic (at least the roof overhang is), but its good and sturdy and difficult to tell without taking the cover off??
Jeff
Offline jkoellmer
#6 Posted : 27 December 2006 02:41:25(UTC)
jkoellmer
Lutz,
You are correct indeed. I just tried it again and there is a noticable difference in deceleration with F4 depressed (works just like the rest of my Marklin digitals..). My first reaction was to look for some other condition based on the description. If they had said something like "Acceleration/Deceleration Brake delay off" I would have picked it up immediately. Oh well, such are the ways of M*..
Thanks again,
Jeff
Offline Troy Yang
#7 Posted : 27 December 2006 06:30:59(UTC)
Troy Yang
[size=1" face="Verdana" id="quote]quote:Originally posted by mmervine
<br />Jeff:
r/mark
Body is metal. Loco worth having.
Troy
This page was generated in 0.263 seconds.
