Offline Biased turkey
#1 Posted : 11 October 2006 13:23:12(UTC)
Biased turkey
So far I'm in the N scale business ( I expect to graduate in the HO league this week when the cute mailwoman will deliver my Marklin starter set )
I own a Fleischmann class 53 DCC tender loco and a Life-Like DC GP18 diesel loco. One has a flywheel ( the GP18 ) while the Fleischmann doesn't. It really makes a big difference when a loco has a flywheel.
So, my question is:
Do the Marklin HO locos have a flywheel ?
Tia for any info.
Jacques in Montreal
#2 Posted : 11 October 2006 13:28:44(UTC)
Some have a flywheel.
The "ordinary" M* motor has a heavy anchor and runs OK w/o flywheel.
With digital operation you have acceleration and braking delay - flywheels don't make a big difference then.
Offline Davy
#3 Posted : 11 October 2006 14:22:20(UTC)
Davy
Most new Marklin locs have a flywheel. Even the new hobbylocs have a engine with a little flywheel. Even the new sinusengine has a flywheel.
M-track with a CS2.
#4 Posted : 11 October 2006 18:23:19(UTC)
The new model will have every flywheel.
#5 Posted : 11 October 2006 18:40:39(UTC)
Older analog Märklin locos dont need a flywheel, as they dont have a permanent magnet (DC-type) motor.
Most newer locos with the HL-motor (The most common 5 pole motor with a 60901 type decoder) doesnt have a flywheel, and relies on its decoder to achieve smooth running. (not too good in analog operation, stopping in powerless sections)
Old-type C-sine IS in fact a flywheel, but newer type C-sine (compact) doesnt have much mass, and relies again on its electronics to achieve smooth operation.
As others have stated, some newer locos are appearing with extra flywheels anyway (thanks M!) -but in any case you should CHECK each individual loco first!
Offline Hemmerich
#6 Posted : 11 October 2006 23:51:39(UTC)
Hemmerich
Most models equipped with the new C-sine have a flywheel; it is usually mounted between the C-Sine and gear. Latest example is the new V200 021 (#39800) - with real excellent driving performance.
#7 Posted : 13 October 2006 20:40:47(UTC)
Biased turkey
Thank you all for the information, but now I'm even more confused because I didn't know Marklin has so many type of motors ( C-sine, HL motor etc.. )and decoders available.
For example, the loco that comes with my srarterer set is the class 86 tank loco ( part # 29533 ). There is an exploded view of all the loco parts, but I can't find anything that looks like a flywheel.
By the way, how can one says "flywheel " in German ?
The pictures posted by Hemmerich doesn't help because there is not such a think like that one on my exploded view.
to hxmiesa:
"Most newer locos with the HL-motor (The most common 5 pole motor with a 60901 type decoder) doesnt have a flywheel, and relies on its decoder to achieve smooth running."
Imho no electronic type decoder can replace the "real" inertia from the loco mass or from a flywheel.
Maybe it is less important with HO scale because an average HO loco has enough inertia for a smooth run, while in N scale the sltghtest flys..t can stop a flywheelless loco dead on the track.
Offline Hemmerich
#8 Posted : 13 October 2006 22:31:28(UTC)
Hemmerich
Hi Jacques,
you stated a general question (based upon your assumption of more or less only one motor type for any model), but didn't tell upfront which specific Märklin loco you meant. That's why you got those answers; mine was more in response to the wrong assumption that the new compact C-Sine would not have a flywheel.
The BR86 (of the set you refer to) has a 5-pole HLA motor with a special (and quite strong) magnet; i.e. by that it is a simple DC motor. The mechanics equivalent to Märklin product #60904/60924 - you can view this for example on the Märklin product page.
Following is a pic of this model & motor (yours matches the one in front).
That motor type doesn't have a flywheel, neither do the other "traditional" ones like SFCM and LFCM (see inet for explanation). The corresponding decoder takes care of the neccessary acceleration/deceleration delays (when driving in digital mode); i.e. flywheel mass substitution.
Indeed HO - and especially Märklin "heavy metal" biggrin - models have a quite different mass than N or even Z models.
The German word "Flywheel" is "Schwungrad" or "Schwungscheibe". wink
PS: Newer GFN locos/motors have some metal pieces inside the anchor which provide some kind of a flywheel mass.
Offline WelshMatt
#9 Posted : 13 October 2006 23:13:26(UTC)
WelshMatt
Marklin locos don't tend to need flywheels in my experience - after I cleaned the commutator and oiled the bearings the three I have will all amble along slowly enough to count the wheel spokes!
Matt from Wales.
Offline MärCo
#10 Posted : 13 October 2006 23:21:19(UTC)
MärCo
36871 has a small flywheel (latest version of the KLVM locomotive).
Absolutly AFB-NOHAB fan ;-)
Offline WelshMatt
#11 Posted : 13 October 2006 23:23:12(UTC)
WelshMatt
That looks like the motor Hornby use in their smallest locos. How does it behave in this loco? The Hornby ones tend to be ok if used on a decent controller and well run in, though they will go ballistic if you're not gentle with the throttle.
Matt from Wales.
Offline Hemmerich
#12 Posted : 13 October 2006 23:28:49(UTC)
Hemmerich
Has nothing to do with Hornby.
For driving characteristics, just take a look at the earlier threads about this loco (36381/KLVM) or the new 36322 (BR81).
Offline MärCo
#13 Posted : 13 October 2006 23:46:55(UTC)
MärCo
<br />That looks like the motor Hornby use in their smallest locos. How does it behave in this loco? The Hornby ones tend to be ok if used on a decent controller and well run in, though they will go ballistic if you're not gentle with the throttle.
In combination with a 66045 it is a very fine shunting engine.
This page was generated in 0.452 seconds.
