Offline Karl
#1 Posted : 15 May 2006 13:22:52(UTC)
Karl
Does anyone know where I can find the dip switch settings for a Marklin 66032 Decoder?
Offline Guus
#2 Posted : 15 May 2006 14:13:15(UTC)
Guus
Hi Karl,
I'm not quite sure,but do you mean this one:http://www.maerklin-info.de/faq...-DeltaBetriebTabelle.pdf
Kind regards
Guus
Kind regards,
Guus
Offline Karl
#3 Posted : 15 May 2006 14:43:19(UTC)
Karl
Thanks Guus. That does look close since it has eight dip switches. I will see if it works.
Offline Hemmerich
#4 Posted : 15 May 2006 17:39:17(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by Karl
<br />Does anyone know where I can find the dip switch settings for a Marklin 66032 Decoder?
There are numerous places, like here:
http://www.maerklin.de/faq/download.php?Number=119
But you can for example also download the 60652 Mobile Station handbook. A full table for all 80 addresses of the 66032 is located in appendix G on pg. 49. They are the same as for 6090/60902 decoders.
http://maerklin-info.de/systems/bda-60652.pdf
Lutz
Offline DasBert33
#5 Posted : 15 May 2006 18:19:21(UTC)
DasBert33
I think this is even more convenient:
http://www.stummi.de/Digirechner.html
Bert
Offline Hemmerich
#6 Posted : 15 May 2006 22:45:10(UTC)
Hemmerich
It's a nice toy - but do you really want to run back to your PC, start it and run that program if you sit in front of you model train layout with you locomotive open?
Wouldn't you too prefer too just have a single paper sheet that lists ALL address combinations at once?
By the way - this table is still also included in all fx loco instruction booklets and - needless to say? - in that of the 66032 (pg. 11 - and even in several common languages). Cool
Lutz
Offline mattillini
#7 Posted : 16 May 2006 03:26:18(UTC)
mattillini
What about decoder 60901? I have a BR 50 that i just converted and i haven't hit the right switches. I belieive it's 4 & 8 on but I'm not 100% sure. Is there a table that would show that? Forgive my ignorance, pretty new to this world...
lfcfcdtex
YNWA!
Offline Guus
#8 Posted : 16 May 2006 10:31:30(UTC)
Guus
Hi Matt,
[size=1" face="Verdana" id="quote]quote: What about decoder 60901? I have a BR 50 that i just converted and i haven't hit the right switches. I belieive it's 4 & 8 on but I'm not 100% sure. Is there a table that would show that? Forgive my ignorance, pretty new to this world...
Yes there is a table.
The one suggested by Lutz is the complete table.
If you want to give your BR50 the adress "50" for instance then the dipswitch settings should be 4 and 8 on indeed and all others off
Hope this helps.
Kind regards
Guus
Kind regards,
Guus
Offline mattillini
#9 Posted : 16 May 2006 18:23:58(UTC)
mattillini
Guus,
Thanks for the help! That was my next guess and you confirmed it for me.
Matt
lfcfcdtex
YNWA!
Offline jaypavlick
#10 Posted : 16 May 2006 19:04:45(UTC)
jaypavlick
Guys,
You can also check out some information on my site, Modell-Zug Elektronix, which has the Digital and Delta coding tables along with an explanation of how the switches actually work. Once you understand the basic code, you won't need to use the tables anymore. The 66032 Delta board uses the same coding scheme as a 6080/6090/60901 Digital board with 8 switches.
http://www.modell-zug.co...s/DigitalAddSwitches.htm
Hope this helps you out-
-Jason
Jason Pavlick
Marklin HO & Digital
Offline mattillini
#11 Posted : 16 May 2006 20:41:37(UTC)
mattillini
"Hope this helps you out"
No doubt about it. Thanks for the info Jason.
lfcfcdtex
YNWA!
Offline mattillini
#12 Posted : 17 May 2006 02:38:10(UTC)
mattillini
Alright, now it's my turn to ask for some assistance.
I have set the dip switches to 4 & 8, picked 3684 on my MS (which is the correct running number 050 082-7) but still nothing. Am I missing something? Does any one else have suggestions?
lfcfcdtex
YNWA!
Offline mmervine
#13 Posted : 17 May 2006 02:49:42(UTC)
mmervine
Matt:
On my MS, 3684 is address 5. You have your 3684 set to 50. Either change the Loc to 5 (4, 5, & 7) or edit the Loc address in the MS to 50.
r/mark
Offline mattillini
#14 Posted : 17 May 2006 03:58:54(UTC)
mattillini
Thanks Mark, I'll try it that way....wish me luck!
lfcfcdtex
YNWA!
Offline mattillini
#15 Posted : 17 May 2006 06:14:48(UTC)
mattillini
No luck so far....I think I'll take it to the shop and see what they can tell me.
Thanks for the help though!
lfcfcdtex
YNWA!
Offline rugauger
#16 Posted : 17 May 2006 12:38:27(UTC)
rugauger
I don't have a MS, so can't try it, but couldn't you just whizz through addresses 1-80 quickly and see if it responds to one of them, before taking it back to the shop? On my 6021, this would take all but 2 minutes winkbiggrin.
Richard
Offline Hemmerich
#17 Posted : 17 May 2006 17:52:15(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by mattillini
<br />No luck so far....I think I'll take it to the shop and see what they can tell me.
As already stated, the factory and MS database default setting for the decoder in this loco is 05.
If your DIP switches are set to address 50, it will not work unless you change either the decoder address to 05 or the default address in the MS to the current setting of your BR50.
For a quick home check you might also want to change the decoder address to another set of DIP's, like 20 (3+7), 78 (1) or 79 (2), etc.
Lutz
Offline McLae
#18 Posted : 18 May 2006 02:11:17(UTC)
McLae
Sounds like you are trying to use a non-mfx decoder with the MS.
This is not plug and play.
There is a procedure to use when using 'older'(6090x) Loks with the MS. Look in the MS manual for instructions on how to use 6090x decoders. You have to set some values by hand.wink
The McLae
Offline mattillini
#19 Posted : 18 May 2006 06:03:11(UTC)
mattillini
Well here's an update....I awoke around 4am and realized when the decoder was put in it was installed upside down. So all the dip switches were on and I was turning "off" the correct ones. So of course first thing I did when I walked in the door from work was to turn them all of and set it up with the 4,5,&7 on.
Guess what?.....
It worked. So now I am running it around the layout as we speak....
Thanks for all the input guys. Nice to know there is some support out there....
lfcfcdtex
YNWA!
Offline mmervine
#20 Posted : 18 May 2006 15:34:02(UTC)
mmervine
Matt:
That's great news! I was really wondering when you changed the switch settings to '5' and it didn't work. Now we need a picture of your Lok in action!!!
r/mark
Offline McLae
#21 Posted : 18 May 2006 22:58:40(UTC)
McLae
[size=1" face="Verdana" id="quote]quote:I awoke around 4am and realized ....
Happens to us all.biggrinbiggrinbiggrin
(Most of us are oldsters after allwink)
The McLae
Offline Hemmerich
#22 Posted : 18 May 2006 23:12:09(UTC)
Hemmerich
<br />Well here's an update....I awoke around 4am
Ok - NOW I know why I slept so badly last night! biggrin
I was "turning from one side to the other" in bed and was always thinking what else could be wrong - and there are quite some options! [}:)]
Nevertheless, please be assured that I am also happy with your success - Congratulations!!! SmileSmileSmile
Lutz
PS: A pic of the loco in action is the least "prize"; one of the loco open with a view at the Decoder and its DIP's would just be great!!! biggrin
This page was generated in 0.920 seconds.
