Offline Ranjit
#1 Posted : 25 October 2009 11:30:28(UTC)
Ranjit
Hi All,
Is there a way to convert old Marklin analogue signals to be used in a digital layout?
Ranjit
#Get Vaccinated
Offline Philip
#2 Posted : 25 October 2009 11:47:15(UTC)
Philip
Hello Ranjit.
Your question must be answered with a question, the old signal can be used just as the points, since the are solenoid opperated in funktion - so i realy don´t understand your question. What do you mean?
Philip
Philip.
Let's keep it simple.
MFDWPL
Offline Ranjit
#3 Posted : 25 October 2009 11:53:56(UTC)
Ranjit
Hi Philip,
My question is: Can these analogue signals be used in a digital layout without any kind of conversion? I am sorry that my question was confusing.
Ranjit
#Get Vaccinated
#4 Posted : 25 October 2009 12:14:16(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Ranjit
<br />Is there a way to convert old Marklin analogue signals to be used in a digital layout?
You can use them with a k83 decoder (no need to convert them).
You can use them manually as they are in digital layout.
In both cases you need signal braking modules (Märklin 72442 or similar) if you want locos to stop with lights and sound on.
I wouldn't call that a conversion, but you need some extra devices to use them.
Offline Ranjit
#5 Posted : 25 October 2009 12:40:53(UTC)
Ranjit
Thank you for the info, Thomas.
As I have absolutely no idea how an analogue signal would work in a digital layout, could you help me understand how the "extra devices" are put together?
Ranjit
#Get Vaccinated
#6 Posted : 25 October 2009 12:45:45(UTC)
Ranjit, just think of the K83 as a substitute for the 7072 switchbox. You wire your signals to the K83. The K83 has a digital address, which is how the Central Station talks to it. You can wire the cables for the dead section from the analog signal just like you would if you were using it with an analog layout.
As Tom says, if you want locos to stop with lights and sound on, you need signal braking modules - Märklin 72442 or similar.
Offline Ranjit
#7 Posted : 25 October 2009 12:49:34(UTC)
Ranjit
Hi David,
I see. Would you recommednd the Marklin 3402 Signal Book? Does this book explain how analogue signals are connected to the K83 decoder or similar and the use of the signal braking modules?
Ranjit
#Get Vaccinated
Offline Philip
#8 Posted : 28 October 2009 15:34:24(UTC)
Philip
Hi Ranjit
If you go to this site: http://www.majhost.com/c...in/gallery.cgi?i=2428016
it is possibel to se on a picture how the K83 decoder is connected to that signal.
Philip
Edited by user 29 October 2009 23:53:17(UTC)  | Reason: Not specified
Philip.
MFDWPL
This page was generated in 0.339 seconds.
