Offline Hobbit
#1 Posted : 20 March 2006 04:06:49(UTC)
Hobbit
Over the weekend i installed a new 60901 into a 3309 (DB 85 Class) that has smoke and telex. I wired up the smoke unit to F1 and the front and rear telexes to F2. The lights were connected to Function.
I knew that I would not be able to check the operation of F1 and F2 with a 6020, but I was amazed to see smoke coming out of the funnel as soon as the loco was put on the track. It appeared the F1 was active immediately - even without addressing the loco. Interestingly, the telex via F2 was off.
I took the loco to a friend (just outside of the Shire) and we confimed that all functions and lights works perfectly when using a 6021. We made sure everything was set to "off" when we finished. However back home the smoke unit started producing smoke again as soon as the loco was put back on the rails.
Is this normal? That is - is F1 always "on" when used with a 6020, but F2 is "off"?
There is no place like The Shire...
#2 Posted : 20 March 2006 04:20:47(UTC)
Hello Hobbit. I think it is Gandalf making fun with you, have you teased him lately? [}:)]
Welcome to the forum, Hobbit.
P.S. I don't have a clue about your question.
Offline Lars Westerlind
#3 Posted : 20 March 2006 08:53:48(UTC)
Lars Westerlind
A little surprised but only little. These decoder have some kind of default setting which means that in analog f1+function is on, rest is off. I guess this is what happened. As the decoder detects Motorola old, it realizes it will never receive understandable f1-f4, so it uses the default setting. I can't tell if it's 'normal', nevertheless, I find it 'understandable'.
/Lars
Offline Bill Marklin
#4 Posted : 20 March 2006 11:34:24(UTC)
Bill Marklin
Hi All!
Yes, this is "normal"
in the default setting.
E.g. with 6020 or 6604.
F1 and function are always "on".
However I noticed with my switchable
6604 that the lights had to be turned on.
You can always change F1 and F2.
Then you can switch the smoke yourselfCool
Greetings
Bill
K-Rail layout wth DC,
Delta Control and C-rail layout with Mobile Station
#5 Posted : 20 March 2006 12:37:36(UTC)
Lars Westerlind
No,
not switch, as Telex is the other function. Never attach Telex to f1 for obvious reasons!
#6 Posted : 20 March 2006 13:28:19(UTC)
Bill Marklin
Yes,
don't panic[}:)]
That was an example.
You can always set F1
to F3 and let the telex be.
Greetings
Bill
#7 Posted : 20 March 2006 18:58:07(UTC)
Views messages in topic : 15,471
It seems that F1 is also on if you set your Intellibox to old motorola protocol - that's what happened to me recently.
Years ago I must have set address 78 to old motorola protocol in order to program one of those jumperless decoders.
As soon as I selected that address on my 6021 (connected as a slave to my IB), F1 was on and could not be turned off.
I realized this as I selected that address on my IB (protocol shown on display).
Offline McLae
#8 Posted : 20 March 2006 19:31:41(UTC)
McLae
In the ESU decoders (Likpilot and Loksound) there is a table where you set what functions are 'on' when running in analog.
Obviously, your decoder considers 'old marklin' as analog,wink[:o)] and has F! default to ON in analog.
This makes sense, as you will never get a F1=ON signal with either Analog, DELTA, or 6020. Cool
The McLae
#9 Posted : 20 March 2006 19:44:53(UTC)
(Edited) AFAIK Function and F1 will always be on if you use a Delta Station; with a Delta Control 66045 Function can be switched and F1 is always on; with a Delta Control 6604, Function cannot be switched (and is probably always off), but F1 is always on.
#10 Posted : 20 March 2006 20:23:58(UTC)
Lars Westerlind
I think you might be correct, but don't know exactly why. Could be because the Delta Control sends those commands. I don't even know if Delta control sends Motorola new or Motorola old. But my guess is that both Delta control and Delta station send Motorola new, with f1-f4 on for Delta station, and off for Delta control. Decoder sets function and f1 on if Motorola old or analog is received, othervise as the signal tells.
/lw
Offline Hemmerich
#11 Posted : 21 March 2006 00:32:17(UTC)
Hemmerich
Please see: http://www.maerklin.de/faq/download.php?Number=50
and: http://www.maerklin.de/p...e/digital/h0-decoder.php
"Im konventionellen Betrieb oder im Betrieb mit der früheren Central Unit Art.-Nr. 6020 oder mit Märklin DELTA sind bei diesen Decodern die Funktionen <<functions>> und <<f1>> immer eingeschaltet. "
Lutz
#12 Posted : 21 March 2006 09:46:08(UTC)
Hello and welcome to the forum Hobbit.Smile
Offline Hobbit
#13 Posted : 21 March 2006 17:12:58(UTC)
Hobbit
Great feed-back. Thanks.
One wonders why M did not default F1 to "off" as a precaution (like with F2). Certainly someting to be aware of when running newer locos on 6020 based layouts. Prolonged and inadvertent use of F1 is probably not healthy for either decoder or the smoke unit - especially if run dry.
Looks like I need to disconnect the smoke until I upgrade the 6020.
Perhaps Gandalf did indeed work at M at some stage. Certainly an endless number of digital mysteries point to it!
#14 Posted : 21 March 2006 19:29:58(UTC)
Lars Westerlind
Because,
if you run analog or Delta, you might want the smoke to be on when power is on. 6020 just happens to give the same signal as Delta, I think.
/Lars
Offline Hobbit
#15 Posted : 24 March 2006 04:11:39(UTC)
Hobbit
Since the only switchable function with the 6020 is the "function" could I connect the two Telexes to the light outputs (grey and yellow) without blowing the 60901 decoder?
How much current does each Telex device draw? And do all Telexes draw the same current, or are there differences?
Obviously I would have to forget about lights and smoke on this loco in order to be able to use Telex, which I accept.
#16 Posted : 24 March 2006 09:06:47(UTC)
Lars Westerlind
I've not read any warnings from Märklin; on the contrary, they have encouraged us to control Telex by the function output. I myself have done it with an old c80 without problem, and have not seen any problem reports either. Märklin don't even say protection diode is needed (built in?); still, if there is space enought, it doesn't hurt.
I have one old Telex and one new (1960, 1990) and the latter indeed is much weaker, which I guess is because less power consumtion.
If there is space inside, you could mount a function decoder; at least in the past Uhlenbrock had one that could be programmed for old Motorola protocol. You might think the 6020 cannot send f1-f4, but that is wrong. It sends f1-f4, but with the old protocol, understabable only by a few remaing decoders.
/Lars
Offline Hemmerich
#17 Posted : 24 March 2006 19:09:22(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br />I've not read any warnings from Märklin; on the contrary,
Maybe the following helps - taken from: http://www.maerklin.de/p...e/digital/h0-decoder.php
"Vor dem Einbau sollten Sie sich genau überlegen welche zusätzlichen Funktionen angeschlossen werden sollen. Bitte bedenken Sie immer, daß im konventionellen Betrieb die im Digitalbetrieb unter &lt;&lt;function&gt;&gt; und &lt;&lt;f1&gt;&gt; geschalteten Funktionen immer eingeschaltet sind. Daher ist es nicht empfehlenswert, eine Telexkupplung oder einen Lokpfeifengenerator an eine dieser beiden Funktionen anzuschließen."
Translated it tells the following:
"Before installation you should carefully decide which additional functions should be connected to the decoder. Please keep in mind that the functions &lt;&lt;function&gt;&gt; and &lt;&lt;f1&gt;&gt; are always turned on in conventional operation. Therefor it is not recommended to connect a telex coupling or signal horn generator to any of these two functions"
There are differences in the current consumption of the various telex magnets. Also a telex magnet is a coil and generates an inductive current, oppose to a simple resistor or bulb. This could or even will blow the 100mA direct function output of the decoder, whereas the additional functions are switched by separate transistors with a maximum current of 250mA.
Just go the safe way. If needed install an addidional power transistor or relay in order to protect the decoder against undesired damages.
Lutz
Offline Hobbit
#18 Posted : 27 March 2006 07:14:22(UTC)
Hobbit
Thank you Lutz, I suspected as much. I have previously used a relay for the 2 smoke units when converting 3102 so I know how to wire up a relay. However I have not heard of using an additional transistor. I assume this is not a new idea, but can anyone post a picture or provide a link to a circuit diagram?
Guest (7)
This page was generated in 0.543 seconds.
