Offline Chris M
#1 Posted : 13 March 2006 07:14:55(UTC)
Chris M
I wanted to share a couple more photos of some of my Engines in action. As well as ask a question.
As I am starting to operate my layout I have noticed that the couples do not match up on some cars, I was wondering if their are some guidelines or standard practices for adjusting them to a similar height as is the case with American models using Kadee Couplers.
Now for a couple pictures.
[imgUserPostedImage
img]
Chris M
Offline Gustavo Villa
#2 Posted : 13 March 2006 13:07:41(UTC)
Gustavo Villa
Chile
This standard exist in the european MR community (NEM), but tiny differences between couplers height between European manufacturers makes this standardization a dream.
Just try to soft couple a new marklin or roco coach to a new Fleischmann coach (using same couplers of course) and you will see that standardization sometimes is a bad word in MR European industry.
For marklin old trains you just adjust the height with a pair of clamps because they are easy to adjust, the new ones with the nem socket are different story, no easy solutions for them because the socket is plastic.
American MR is way more advance in standarization, couplers is the best example for it.
From my side, I'm using Kadee with nem socket in all my european trains.
#3 Posted : 13 March 2006 19:08:16(UTC)
You need a large that small pictures.Hard to see the small pictures.[xx(]
Offline McLae
#4 Posted : 13 March 2006 19:59:34(UTC)
McLae
Roco has a NEM 'universal' coupler with adjustable height. They also have a close coupler that is adjustable. The coupler comes in two parts, a 'shank' with a groove, and a 'head' that slides into the groove.
I was lucky enough to get about 50 for a good price on eBay.biggrin Lasted for several years now. If I have problems with couplers, I swap out with these and the problem goes away!winkbiggrin
If you need the part number, I can look it up when I get home tonight.Cool
The McLae
Offline Zora la rousse
#5 Posted : 13 March 2006 20:13:21(UTC)
Zora la rousse
@Chris M:
It is [ img ] add link here [ /img ]
#6 Posted : 13 March 2006 23:08:38(UTC)
Guys and girls... The link is exposed to show the larger image... The little image or thumbnail is just to give a taster about what is on the other end of the link... Give it a try - just click on the link.. Smile
Offline McLae
#7 Posted : 14 March 2006 01:51:03(UTC)
McLae
Here are some links to show the Roco couplers. Note this is just for the pictures, other folks may have better prices.wink
http://www.reynaulds.com/Roco/temp.asp?item=40351
http://www.reynaulds.com/Roco/temp.asp?item=40287
Note that the 40351 is acutally adjustable like the 40287. (Picture is wrong![:0]) I recommend the 40351.biggrin
I had some trouble with a Wiessel double decker set on s-curves. Problem went away when I replaced the couplers with 40351's.biggrin
The McLae
#8 Posted : 14 March 2006 02:04:20(UTC)
Gustavo Villa
Chile
As far as I know, those roco couplers are going to be discontinued, Mr Magdefrau (former owner of roco) has the right of the design of those couplers and those rights were not included in the recent agreement between Magdefrau and the new Roco society.
Offline McLae
#9 Posted : 14 March 2006 06:12:16(UTC)
McLae
I thought it was only the CC (4028x) that were in trouble.
I also heard that there are negotiations in progress....Smile
The McLae
This page was generated in 0.356 seconds.
