Offline rugauger
#1 Posted : 06 March 2006 01:12:19(UTC)
rugauger
All
I'm looking for a simple, cheap function decoder. Requirements: 1 direction-dependent function, 1 extra function (F1). Should support 2000 mA total. That's all!
So far I've come up with the (obvious) Marklin 60960, the Uhlenbrock 76900 and the Tams MM FD-3. However, these all have far more functions than I need, and consequently cost more than I want to pay wink
Any other suggestions?
Richard
Offline Charlie
#2 Posted : 06 March 2006 03:03:00(UTC)
Charlie
Richard,
At the Toy Fair I saw that Uhlenbrock will release out with a new mini function decoder, the 73990. It will do direction dependent switching, and has 4 outputs. It can do many things, like dim lights, time releases (couplers), flashing (Swiss tail lights).
Total output can not exceed .6 Amps
Charlie
Offline Lars Westerlind
#3 Posted : 06 March 2006 08:48:12(UTC)
Lars Westerlind
I'm rather satisfied with Lenz LE100XF which is DCC. However, 2 A is more than I've noted for any decoder. Othervise I would look at cheap loco-decoders, as LokPilot. Do you still regard these as too expensive, or is it the power limit which is your problem?
/Lars
Offline perz
#4 Posted : 06 March 2006 09:22:10(UTC)
perz
I think it is possible to use an old 6080 and boost the function outputs with power transistors. It is probably possible to get a 6080 almost for free second hand.
#5 Posted : 06 March 2006 10:55:03(UTC)
Lars Westerlind
6080 doesn't have f1 though. Possible there are decoders available with burnt Motor output? Like c901 or LokPilot?
Offline pa-pauls
#6 Posted : 06 March 2006 14:28:21(UTC)
pa-pauls
That's a function decoder I would also like to get Richard
But I haven't heard about 2 A do,,, but anyway you can
use a relay on the function output, they are small enough.
Pål Paulsen
#7 Posted : 06 March 2006 18:58:50(UTC)
Why not use a TAMS LD-W 3 as a function decoder? OK, it's far below 2000 mA, but I think I'll use one in my BR 815 coach as soon as I find the time to convert it to digital.
It's a loco decoder, but it should also work w/o motor ...
Offline rugauger
#8 Posted : 06 March 2006 23:40:05(UTC)
rugauger
[size=1" face="Verdana" id="quote]quote:Originally posted by h-zero
<br />Why not use a TAMS LD-W 3 as a function decoder? OK, it's far below 2000 mA, but I think I'll use one in my BR 815 coach as soon as I find the time to convert it to digital.
Interesting - the 815 is EXACTLY what I want to use it for. Directional output for the headlights, F1 for the interior light, right?
My problem is that it's difficult to replace the red/white light bulbs which "eat" 1A already, leaving 1A for the interior (although I'm currently thinking about miniature light bulbs 60mA, or LEDs, for that purpose).
Richard
#9 Posted : 07 March 2006 00:52:07(UTC)
How about letting the f output trigger a relay and take the juice from the tracks? With appropriate resistors to limit the current? I think Lars has done something like that if I recall correctly...
#10 Posted : 07 March 2006 09:05:35(UTC)
Lars Westerlind
Yes,
because I wanted "distant light" connected with the directional light, so that F2 controlled wether it should be 3 bright lamps or 2 dim lights, and 'function' on and off. As said in another thread, I think it's a good idea to use protection diodes with the inductive load of a relay coil.
/Lars
Offline rugauger
#11 Posted : 07 March 2006 09:23:16(UTC)
rugauger
Juhan, Lars
Thank you for your kind advice. Hadn't thought of the relay thing (because I never think of the obvious...). Lars, can you explain more about what you mean by "protection diodes" for the "inductive load" - sorry, I only understand electronics on a "need-to-know" basis wink
Richard
#12 Posted : 08 March 2006 00:59:01(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by rugauger
The light bulb eats 1W (1VA), not 1A (which would mean more than 16W; 1W = 1 VA).
As far as I recall I used 70 mA white light bulbs and 30 mA red light bulbs in my BR 515 (lights on both sides). The BR 815 has lights on one side only, so there is either one red light bulb or one white light bulb burning.
70 mA at 19 V gives 19 V * 0,07 A = 1.33 VA = 1.33 W.
#13 Posted : 08 March 2006 09:32:26(UTC)
Lars Westerlind
<br />Juhan, Lars
Connect the relay and the diode in parrallell to the function output; the diode directed from the F1 output (as the current flow towards this connection when 'on'. Makes no harm when on. When the decoder swithces off, the coil in the relay tends to force the current to continue, thus building up a high voltage which could destroy the decoder. Instead this voltage is drained through the diode. Same principle which was used in the pre-electronic car ignition systems. In short, you don't want this spark to occur inside the decoder.Smile
/Lars
This page was generated in 0.433 seconds.
