Offline Brakepad
#1 Posted : 30 August 2009 08:51:36(UTC)
Brakepad
France, Metropolitan
You may remember this topic:
https://www.marklin-users.net/fo...ult.aspx?g=posts&t=12585
where an old BR01 3048 was "overhauled", and it was stated that everything on it was built to last...except its chimney insert, which in early models is made from a material (fiber? plastic?) which gets worse as time goes by. In this particular model, the chimney insert had lost some material and its appearance was not good anymore:
This is the chimney insert once it has been disassembled from the loco:
You can see that its condition its poor...
Yesterday I visited a friend who has a small workshop in his garage. As we had some spare time I asked him to try to manufacture new chimney inserts made from stainless steel.
And this is the result. This was some kind of "approximative" test, actual parts are slightly oversized but they appear to be OK, in particular if the original part is not there to compare. Moreover, the smoke unit can be fitted to the new parts:
This one compares old vs new part:
This one shows how it gets when assembled on the loco:
This one compares a loco with the old insert vs another with the new insert:
#2 Posted : 30 August 2009 11:46:29(UTC)
Very clever approach to repairing the faulty item.
#3 Posted : 30 August 2009 13:17:23(UTC)
Very good.
#4 Posted : 30 August 2009 14:02:29(UTC)
Very good repair, Brakepad.
The old lady can smoke again!
#5 Posted : 30 August 2009 15:03:04(UTC)
S/S is not the best electricity conducter.
Did you have problems with it.
regards.,
Offline Brakepad
#6 Posted : 30 August 2009 23:39:05(UTC)
Brakepad
[size=1" face="Verdana" id="quote]quote:Originally posted by river6109
<br />S/S is not the best electricity conducter.
regards.,
Hi John,
Even if S/S resistivity is much higher compared to, i.e., copper, the absolute value of the resistivity of the chimney insert, between the housing and the smoke unit would be low enough to allow perfect operation of the smoke unit. Thickness of insert between the housing and the smoke unit is very, very low (less than 1 mm), and IMHO the housing itself would have a higher electrical resistivity than the S/S chimney insert.
However, this locomotive (3048) does not rely on the chimney to conduct electricity to the smoke unit (in fact the original part is made from an isolating material!), but on two copper plates located beside the light bulb. See:
So far, I have had no problems at all with it, and appearance has improved a lot, IMHO. Perhaps this would be more noticeable if the loco was resprayed.
Thanks and regards.
Offline kbvrod
#7 Posted : 19 January 2013 23:43:15(UTC)
kbvrod
Weinert.
Dr D
Offline Iamnotthecrazyone
#8 Posted : 19 January 2013 23:50:45(UTC)
Iamnotthecrazyone
regards.,
Hi John,
Thanks and regards.
The earlier model may rely on the two plates. If memory serves me right on later models you have only the bottom plate but no side plate. This post makes want to go through opening the different versions to check on differences. Must be that my oldest ones are in perfect condition but I've never noticed the chimeney wasn't metal, everything seem to be the same material. Thank you for posting the photos.
This page was generated in 0.558 seconds.
