Maybe it's just me, yet this is the second Seuthe 24 smoke generator I install (this time into a BR 18.4 aka S3/6) and I don't find it to be smoking a lot, compared to other smoking generators...
I checked the contact, I did not overfill the smoke generator. I can spot a very very faint hint of smoke only so far... So contacts are OK.
Does anyone have similar experiences with the Seuthe 24? |
Joined: 03/01/2003(UTC) Posts: 5,193 Location: Southern New Jersey, USA
Are you powering the smoke generator from the decoder?
If so, you should use a # 20, since the decoder only puts out about 14 volts, I believe. You need the 24 if you are driving it directly from digital track voltage. |
Aha, that explains it. I am powering it from the decoder indeed, whereas the original model configuration was being powered from the track.
The manual of the loc said to use a Seuthe 24... That one needs 16 to 22V. On the other hand, it consumes ca. 70 mA, which is exactly what Kühn recommends. I built in a Kühn T145 decoder... |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by rschaffr <br />I had the same problem.
 I'll guess it is a common mistake to make. I'll have to order a Seuthe 20... Thanks for the info. |
Joined: 28/04/2003(UTC) Posts: 757 Location: Wawa, Ontario
I too had the same problem until a few minutes ago. I am still using a seuthe 24 but what I did in my test was to take the body off, remove the smoke generator from the body and attach aligator clips from the smoke unit to the frame of the locomotive (just put screw in the frame and attach the aligator clip to it) and the other to the metal tab. Put the recommended amount of oil in power up the locomotive and activate the F1. Low and behold the unit starts smoking the way it should.
I then reassembled the whole unit and scraped a little paint away from where the screw covers on the body of the locomotive and reinstall screw. The next test produced the same results (lots of smoke as it should).
I would try this first before going to a seuthe 20 unit which will draw more power. The seuthe 24 does actually work with a decoder.
Maxi
Hi Maxi,
I will try this first as well. I did some further reading and came to the conclusion that the 24 draws 70 mA which is better. Also, the Kühn T145 manual says I should be looking for a smoke generator which is 16V-21V and according the specs, the 24 should suit that perfectly.
Maybe the ground is not so good on the metal body of a S3/6... |
I tested the smoke generator by wiring it directly to a 16V trafo and than it smokes big time. So, the analysis is right: connected directly to digital current, the Seuthe 24 would do. Now I have the decoder, I'd need a Seuthe 20. I have ordered one... a few days waiting and all will be fixed :-D |
Hi Steven86, You've already found out how it all works,nevertheless here's a link to a German Märklin Insiders website with a summary of possibilities you'll most likely encounter in Märklin locs. http://www.hamst.de/html/seuthe_dampf.htmlHope you don't mind it's in German only. Kind regards Guus |
Kind regards, Guus |
Hi Guus, Very nice link. Thanks. I don't mind that it is in German. I'll have to find a use for the Seuthe 24. I can build it in to the chimney of a factory I am going to scratch build  Steven |
The Seuthe 20 is now in the loc and it smokes as it should. Many thanks for the advice.
This experience led me to examine another loc with a not-so-good smoke generator, a BR-55. Guess what. It has a Seuthe 24 too. Now, I checked the manual from Märklin and to my surprise it says:
Delta/digital: Seuthe 24 Analog: Seuthe 20
imho, Märklin's manual must be wrong. They probably switched the numbers. Shouldn't it be Delta/Digital: 20 and Analog: 24?
Anyone who has a BR-55? What type of Seuthe do you have in there? |
I find that a Seuthe 24 works rather well. I guess it depends on how much smoke one claims is enough or abundent.
In the BR-55, it will not smoke except after 30 minutes or so... I'd like to claim some more smoke  |
Joined: 29/04/2005(UTC) Posts: 777 Location: Netherlands
Isn't this discussion all about the fact there used to be a analog (20) units only. Due to electronic switching in the decoder, this gave a voltage drop (about 0,7 V) that made the analog (20) units not perform well. So then came the digital (24) smoke units that smoked well on this lower voltage. But decoders have improved, so this voltage drop is not here any more...the traditional analog (20) unit will do for digital operation nowadays. And for sure, the digital (24) units designed for the somewhat lower voltage, will perform 'boosted' on the new decoders and pure analog. Some even say the will burn out when used 'dry'.... Or is this story a fairy tale? It does not fit with the experience Steven86 has    |
Mosty era III DB. |
Joined: 10/09/2004(UTC) Posts: 959 Location: Copenhagen, Denmark
The story as I have been told, is this:
In the beginning was the analog train with its analog smoker, and all was well. Then came the first digital (delta?) trains. The decoder introduced a voltage drop before it reached the motor, so the digital system runs on a HIGHER voltage in order to compensate for this. However, the smoke units were still connected directly to the rails, so they smoked like heck due to the higher voltage. And so the "digital" smoke units saw the light of day, and all was once again well. And now we want to control everything, so of course our smokers are connected to the decoders. Of course this means that the smokers now get the slightly lower voltage from the decoder output, and so we, once again, are best served with the old analog smoke generators.
When that is said, I should perhaps mention that some decoders doesn't introduce much of a voltage drop, and here the "digital" smokers are the preferred choice. Proper wiring of the track power is also essential. I have two loks with digital smokers, and they run and smoke very well on my own layout. But visiting my cousins bigger layout resulted in virtually no smoke at all. A closer look revealed that his track power were fed by very thin wires (like the size of the wires on a turnout), and the layout only had feeding points for every 4 meters of track.
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by Mikael <br />The story as I have been told, is this:
I too have no problem with smoke units on my layout and use 24 gauge wire to feed power to the track. How ever I also add a feeder set every 6 pieces of track which means about every meter and have no power problems what so ever. Copper wire is cheap so may as well use plenty of it.
Quote:[size=1" face="Verdana" id="quote]quote: Originally posted by Gert-Jan<br />Isn't this discussion all about the fact there used to be a analog (20) units only. Due to electronic switching in the decoder, this gave a voltage drop (about 0,7 V) that made the analog (20) units not perform well. So then came the digital (24) smoke units that smoked well on this lower voltage. But decoders have improved, so this voltage drop is not here any more...the traditional analog (20) unit will do for digital operation nowadays. And for sure, the digital (24) units designed for the somewhat lower voltage, will perform 'boosted' on the new decoders and pure analog. Some even say the will burn out when used 'dry'.... Or is this story a fairy tale? It does not fit with the experience Steven86 has    I'd say it would be the other way around. The Seuthe 20 is recommended in the above HAMST link as the type to connect to a Function of the decoder. So that suggests it needs a lower voltage to smoke. I am also running my Intellibox at voltage for N gauge, to save the electronics. Would that make a difference too? Voltage will never go above 16V than... |
