Offline ulf999
#1 Posted : 03 October 2005 13:47:21(UTC)
ulf999
What are Circuit Tracks, ex 24294, used for?
I've been browsing the Märklin yearbook. But I still don't get it...
Is it for signals?
TIA,
Ulf
Offline Lars Westerlind
#2 Posted : 03 October 2005 15:07:52(UTC)
Lars Westerlind
They just close a contact. This can be used to
- throw a turnout
- change a signals state
- chante the state of a relay
- show "occupied" on a s88; thus either telling a computer that a train is present, or a "memory unit", or others. You should look in the signal book to learn more; at least the old one describes the traditional uses of contact and circuit tracks. You could also look at
https://www.marklin-user...eration/OPautotrain.html
/Lars
Offline ulf999
#3 Posted : 03 October 2005 15:51:12(UTC)
ulf999
Ah, thanks.
Probably time for me to get hold of that signal book :)
/Ulf
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br />They just close a contact. This can be used to
- throw a turnout
/Lars
Offline McLae
#4 Posted : 03 October 2005 19:15:25(UTC)
McLae
If you look at my article "Simple block control" on the home page, the empty blue, yellow and red squares are 24X94 sections.
There are also 24194 and 24294 curved circuit tracks that work the same. All are activated by a slider.
The McLae
Offline ulf999
#5 Posted : 03 October 2005 23:14:20(UTC)
ulf999
cool. Thanks.
Now my question is: contact track or reed?
Any advice here?
/Ulf
[size=1" face="Verdana" id="quote]quote:Originally posted by McLae
<br />If you look at my article "Simple block control" on the home page, the empty blue, yellow and red squares are 24X94 sections.
#6 Posted : 04 October 2005 00:37:23(UTC)
Lars Westerlind
If we speak about C-track, I've got the impression that contact or circuit tracks are more reliable. And circuit tracks detects direction too. But I have no experience of REED.
/Lars
Offline McLae
#7 Posted : 04 October 2005 01:30:59(UTC)
McLae
I have tested the Viessmann reed contact switches.
1. If you stop a magnet over the switch, the switch can burn out.[:(]
2. The magnets need to be at the correct height: too low and they snag on pukos, too high and the switch ignores the magnet.
My .02$: If you are just starting, get a few circuit tracks and experiment. After you get an idea of how the train control works, you can switch to reed switches.
I have a pair of LDT ocupancy detector modules waiting for testing.[:I] I will probably wind up using these with RR&Co Software to automate my main layout.
The McLae
Offline jonquinn
#8 Posted : 04 October 2005 05:22:38(UTC)
jonquinn
You have been a member since:: 15/02/2004(UTC)
would infra-red detection be the better/best solution? would this be the principle behind Uhlenbrock LISSY?
Offline McLae
#9 Posted : 04 October 2005 06:17:38(UTC)
McLae
I think LISSY is a cousin to MFX (Very Distantwink). You have a transmitter in the Lok (more soldering[xx(]) and recievers that detect the signal, Lok X just passed dectector Y.
I remember (Many moons ago) seeing pictures of how someone had set up IR detectors for train control on his DC layout. Lots of hard work to wind up with the same information that a circuit track can give you.wink
If you have lots of money, and not many Loks (something wrong with that idea[}:)]) Lissy could be a viable option.
The McLae
Offline rschaffr
#10 Posted : 04 October 2005 06:42:09(UTC)
rschaffr
I use IR detectors selectivly where I don't want to commit a full track length to detection(such as in a station). It provides a point source of train location. It is, however, a lot of work. I did a description of it some time ago. It can be found at: http://www.sem-co.com/~r.../trains/irifc/irifc.html
I had originally planned to do all my detection with this system, but I've gotten lazy and I now use contact tracks where space is not a problem.
-Ron
#11 Posted : 04 October 2005 10:15:59(UTC)
Lars Westerlind
[size=1" face="Verdana" id="quote]quote:Originally posted by jonquinn
<br />would infra-red detection be the better/best solution? would this be the principle behind Uhlenbrock LISSY?
Yes,
Lissy is doing the work, and very much more. Therefore, it's expensive too.
Lissy is operating in a digital environment only, and also needs a central with LocoNet, like IB, Daisy, Digitrax, (Piko, Fleischmann). It indicates presence and direction, just as the circuit tracks, but in addition also
- allows for identification - what train is there?
- speed measurement
- triggering actions in the digital system, with or without computer.
Actions may be throwing turnouts and the like, or commands to the loco like slowing down, pull the whistle or whatever.
In my view there is no relationsship between Lissy and mfx, except they are both present in the digital field.
/Lars
Offline ulf999
#12 Posted : 04 October 2005 16:07:29(UTC)
ulf999
Thanks guys!
I'll get me some circuit tracks and do some 'trial and horror' :)
Offline McLae
#13 Posted : 05 October 2005 04:59:45(UTC)
McLae
You might also consider getting a couple of old marklin 7039 or 7188 signals to 'play' with.
Or a couple of Viessmann Hobby signals.wink
The McLae
Offline ulf999
#14 Posted : 18 October 2005 12:30:59(UTC)
ulf999
ok, now I've bought 3 of these circuit tracks. How do I connect them to my motorized swithces???
I assume the yellow goes to the feeder I have for lights etc.
Do I connect the 2 blue cables to the switche's blue cables?
TIA,Ulf
Offline MärCo
#15 Posted : 18 October 2005 12:41:22(UTC)
MärCo
No, only the blue wire which you like to activate by the train. So you need 2 circuit tracks to operate a switch.
Other members: isn't there a manual online ?
Absolutly AFB-NOHAB fan ;-)
Offline McLae
#16 Posted : 18 October 2005 16:31:16(UTC)
McLae
Each circuit track has two connections (Blue wires). One is activated in one direction, the other is activated in the other. (On the side the train is comming from. I always get it wrong[:p])
Pretend your finger is a Lok slider. As you run your finger over the track, the first blue wire you encounter will be grounded as your finger passes. Same as pushing a button on the control pannel. Connect that blue wire to whatever you want to activate with that train, switch, signal, etc.
The McLae
Offline ulf999
#17 Posted : 18 October 2005 19:42:55(UTC)
ulf999
<br />Each circuit track has two connections (Blue wires). One is activated in one direction, the other is activated in the other. (On the side the train is comming from. I always get it wrong[:p])
Thanks. Will try this. (The yellow cable was from the switch motor :) )
/Ulf
Offline ulf999
#18 Posted : 18 October 2005 21:25:58(UTC)
ulf999
I've tried circuit tracks and switches now, to no avail.
the track works. I tested it with a 12v lamp. and the switch motors also work
The circuit track seem to just send a short pulse. Not enough to throw a switch... What else might I need?
TIA, Ulf
Offline McLae
#19 Posted : 18 October 2005 21:35:50(UTC)
McLae
Make sure that the track is Brown, and the pukos are red. (Same as Yellow).
If you are using an MS, power the switches (yellow) from the Red (puko) wire.
If I have the MS power understood, the MS red and brown are not the same as yellow and brown from the trafo.[B)]
In the old system (6021, IB), brown was track, and was common. With MS, brown to track is NOT the same as brown from trafo. If you feed Yellow from trafo, brown from track (circuit track) will not work.
Hope this helps.
The McLae
Offline ulf999
#20 Posted : 18 October 2005 21:50:38(UTC)
ulf999
I have MS to power my system. The switch motors (and lamps) are powered by a second trafo (as the booklet describes).
Could it be that I need the circuit tracks to send a pulse to a signal, which in turn can throw the switch?
Or can the track itself throw a switch?
/confused...
Offline ulf999
#21 Posted : 18 October 2005 22:20:59(UTC)
ulf999
&gt;&gt;If you are using an MS, power the switches (yellow) from the Red (puko) wire.
That was the trick. power the switch from the track feed.
Thanks guys!!!
/Ulf
#22 Posted : 19 October 2005 00:16:22(UTC)
Lars Westerlind
[size=1" face="Verdana" id="quote]quote:Originally posted by ulf999
<br />&gt;&gt;If you are using an MS, power the switches (yellow) from the Red (puko) wire.
Thanks guys!!!
/Ulf
Better yet,
you may feed the switches from a separate transformer, by
1. Connecting the extra transformers brown to the rails as well (common ground). Or,
2. Turn the circuit track. From factory the switch is connect by a cable shoe to the track; this may be removed. Instead connect that short cable to the brown of the extra transformer.
This save expensive digital power.
/Lars
Offline McLae
#23 Posted : 19 October 2005 00:35:24(UTC)
McLae
[size=1" face="Verdana" id="quote]quote:This save expensive digital power.
True. However, If he is using an MS, he cannot be running many loks anyway. The small occasional switch power usage will probably not cause problems.wink
Good trick for later.biggrin
Meantime, happy to help!Cool[:I]
The McLae
This page was generated in 0.557 seconds.
