Offline Mikael
#1 Posted : 29 August 2005 23:15:25(UTC)
Mikael
Hi.
I got my fingers in a second hand Roco turntable, and it seems to have a bit of a problem. Sometimes it overshoots the connection track before it stops, so I need to run it a bit backwards. Are there any tricks or adjustments I can try?
Offline Mikael
#2 Posted : 30 August 2005 10:58:15(UTC)
Mikael
In case nobody has any good ideas, I might consider getting a Märklin turntable instead. But are they better? Do they stop where they are supposed to? And reliably every time?
Offline Maxi
#3 Posted : 30 August 2005 16:14:06(UTC)
Maxi
Yes the Marklin turntable does work very relliable assuming that the motor is turning at it's normal speed. Should the motor turn slower then the module for the turntable which Marklin makes could get out of synch since it works on time and power draw to calculate where the turntable is in it's scheme of indexing.
Maxi
#4 Posted : 31 August 2005 01:26:40(UTC)
I'll be the first to say that when the Marklin turntable works, its great. However I have had nothing but trouble with them out of the box from improper wiring diagrams for set up to dead spots between the deck and the connecting tracks that refuse to be repaired. They are nice, but test yours at the store before buying.
#5 Posted : 31 August 2005 11:26:30(UTC)
My turbtable working perfect since i bought it,five years ago.biggrin
Offline Mikael
#6 Posted : 31 August 2005 23:23:54(UTC)
Mikael
Thanks guys. I may get a M* turntable later on. But there is plenty of other stuff to do first, so I'll live with my Roco one to begin with. Maybe it gets better when I start to use it regularly.
Offline Mikael
#7 Posted : 04 September 2005 14:29:39(UTC)
Mikael
Unfortunately, it doesn't seem to get better after I started to use it. Now it enjoys to short out the tracks when certain loks are entering it. I'll retire it as soon as possible and get a Märklin turntable instead.
#8 Posted : 04 September 2005 16:39:10(UTC)
You need marklin turntable as Roco turntable didnt work with marklin layout because three rails marklin.
Offline Munich 1860
#9 Posted : 04 September 2005 17:16:02(UTC)
Munich 1860
<br />You need marklin turntable as Roco turntable didnt work with marklin layout because three rails marklin.
Not true, Stephen, it can be used by Märklinists. Actually, if Roco hadn't brought out its turntable years ago, we would still be using the old 7186, I am convinced.
This page was generated in 0.479 seconds.
