Offline littledragon
#1 Posted : 28 July 2005 20:11:32(UTC)
littledragon
haven't figured on taking it apart or even be able to test-run it yet but anyone know if a deltic decoder probably could fit in this small shell?
thanks
Offline MärCo
#2 Posted : 28 July 2005 20:45:26(UTC)
MärCo
Small description of the locomotive, please wink.
I’ve build in a Delta decoder 66032 into 3080 (DHG500 diesel switch locomotive).
Little note, it has no lights. Made things more easy.
Absolutly AFB-NOHAB fan ;-)
#3 Posted : 28 July 2005 23:32:46(UTC)
littledragon
well...its a little 3-axle (4th if you count the motor flywheel between middle and rear axle) diesel shunter engine
this thing has four lights (two per direction) located atop the end platforms at end edges
it actually seem to look like the actual light bulbs themself are underneath the end platforms as I only see what looks like a 90 degree bent clear plastic (or fibre?) light tube....know what, I'll link to the auction [where I won thig thing] for you to see for yourself.
#4 Posted : 29 July 2005 04:06:56(UTC)
littledragon
well here it is anyhow: http://cgi.ebay.ca/ws/eB...;ssPageName=STRK:MEWN:IT
if you look closely at the second picture you can see what I mean in third paragraph in my previous post above
#5 Posted : 29 July 2005 21:33:16(UTC)
Good bargain! Did you bid it?
#6 Posted : 29 July 2005 23:54:12(UTC)
littledragon
stevetrain...if it wasn't mine now I wouldn't had been asking about fitting a decoder to it would I? :D heh
just being humorful :p
Offline rschaffr
#7 Posted : 30 July 2005 00:49:04(UTC)
rschaffr
littledragon: I converted a 3065 switcher, which I believe is basically the same body, with the 60903 high efficiency motor and decoder. As I recall (I did it several years ago) it was a tight fit but it all went in. There should be three lights on each end. There should be a lower "lichtkoerper" or light body to carry the light to the lower outlets and an upper one to carry it to the light on the top of the cab. It can be done, but as I said, it was a tight fit. There are other options, such as the Uhlenbrock decoders which work with the existing motor and fit in the same space as the reversing unit, but I have not been fully satisfied with the performance of that arrangement (I have done two).
-Ron
Offline MärCo
#8 Posted : 30 July 2005 14:16:52(UTC)
MärCo
To give an idea how tight space can be.
I have converted this DHG 500 (3080) with a Delta decoder. At the end, I was happy that there were no lights installed, and no Telex coupling.
Offline pat
#9 Posted : 30 July 2005 16:52:53(UTC)
pat
HelIo Little dragon
I done a delta install on a 3144(similar/same to the3080 above) a long time ago with lights either end with no space problems. I just have to be careful putting the shell on and off.
worse things happen at sea
This page was generated in 0.469 seconds.
