Offline Sander van Wijk
#1 Posted : 27 June 2005 11:52:03(UTC)
Sander van Wijk
A friend of mine has acquired a remote control transfer table (7294). In the Märklin database the possibility to control this transfer table with a K84 is mentioned. The manual of the K84 should contain the necessary schematics. Unfortunately, we can't find these. Does anyone know how to hook up a transfer table with a K84 or another way to digitalize this transfer table?
Thanks in advance!
Sander
#2 Posted : 27 June 2005 16:13:18(UTC)
The instuction booked included with 7294 to show how to use the k84.The k84 instuction not included for 7294,or digital book cat no 0308.
Offline McLae
#3 Posted : 27 June 2005 17:11:29(UTC)
McLae
The instructions are in Digital manual 0303, page 131.
Explains how to use a rectifier to provide DC +/- for direction control. Uses two outputs of the K84.
The McLae
#4 Posted : 27 June 2005 18:45:22(UTC)
Sander van Wijk
OK, thanks for the input! Does anyone perhaps have a schematic since we don't have the instruction booklet for the 7294 nor the digital manual here.
Sander
Offline Lars Westerlind
#5 Posted : 27 June 2005 22:53:32(UTC)
Lars Westerlind
The transfer table has 3 control inputs, which conventionally has red (A), green (B) and grey (C) connection, from left to right. (A) should be grounded, (B)should have positive or negative DC to decide the direction, and (C) should have the same as (B) when the table is active, and disconnected when passive.
The suggested used of k84 is to connect (A) to grond, (B) to mid of output (1) and (2) of k84, and (C) to red of (2). Red and green of (1) is fed by positive and negative DC, using diodes from AC source.
p171 of the digital manual.
/Lars
Offline Maxi
#6 Posted : 27 June 2005 23:29:07(UTC)
Maxi
the English version of Digital manual 0303 can be viewed at the following link.
http://www.ebis.ca/marklin/index.html
Maxi
#7 Posted : 28 June 2005 01:36:26(UTC)
Sander van Wijk
Great! Thanks a lot all! I guess my friend will be able to do the trick with this info Smile
Sander
Offline Guus
#8 Posted : 28 June 2005 12:42:50(UTC)
Guus
Hi Matthew,
I'm not into transfer tables,not yet to be precise,but I want to thank you for the great link.
Guus
Kind regards,
Guus
#9 Posted : 28 June 2005 18:27:15(UTC)
Sander van Wijk
Today I've heard from my friend that this totally fits his needs! By the way, it is a great link indeed!
Sander
#10 Posted : 28 June 2005 20:48:24(UTC)
Very pleasure to hear that.
Offline Guus
#11 Posted : 29 June 2005 15:49:38(UTC)
Guus
Hi Sander,
A little (too) late perhaps and most probably you know this already,but the requested schematic can also be found in Märklins book 0715 "Ratgeber Elektrik" Chapter 6 page 57.
Guus
Kind regards,
Guus
#12 Posted : 30 June 2005 00:27:32(UTC)
Sander van Wijk
Hi Guus,
Thanks for your input! But you're right... the problem is kind of solved already. Thanks anyway!
Sander
Offline gmorrison01
#13 Posted : 25 October 2005 05:48:19(UTC)
gmorrison01
[size=1" face="Verdana" id="quote]quote:Originally posted by Maxi
<br />the English version of Digital manual 0303 can be viewed at the following link.
Maxi
Maxi -
The site with the digital manual is now closed. If you still have the document from the site, would you share it with me via private e-mail?
GEM
Offline antrains48
#14 Posted : 21 September 2006 00:54:26(UTC)
antrains48
I am also interested in this manualin English. Could someone guide me on where could this be found?
Thanks for all the help.
antrains48
[size=1" face="Verdana" id="quote]quote:Originally posted by gmorrison01
Maxi
Maxi -
This page was generated in 0.879 seconds.
