Offline laalves
#1 Posted : 09 May 2005 01:51:10(UTC)
laalves
Does anyone know the parts reference for the pickup shoes that come in the coach lighting kits? I'm especially looking for the 2-axle lighting kits in particular.
Best,
Luis
Offline HueyCE
#2 Posted : 09 May 2005 04:08:46(UTC)
HueyCE
Märklin does say that the lighting kits have replacement parts, I can't find the numbers on either the Märklin.de or Marklin.com. They are also not listed on the CD-rom. Does anyone know where to get the numbers?
Ira
Offline rschaffr
#3 Posted : 09 May 2005 04:21:20(UTC)
rschaffr
I believe it is 7175.
-Ron
Offline Alberto Pedrini
#4 Posted : 09 May 2005 11:15:54(UTC)
Alberto Pedrini
Hi Luis,
check this page, it's in Italian, but you maybe recognize the pickup by the photo.
http://www.ciciessemodel.it/catalog/page7.html
bye Smile
Alberto
Marklinfan Club Italia
www.marklinfan.net
Offline laalves
#5 Posted : 09 May 2005 13:11:30(UTC)
laalves
<br />Hi Luis,
bye Smile
Thanks almagik but it's none of them. It's the one with the suport tube off-centre.
Thanks rschaff. Can I trust that for an order......?
Luis
Offline rschaffr
#6 Posted : 09 May 2005 16:08:58(UTC)
rschaffr
laaves:
I'll check one out when I get home tonight...I have a few in stock.
-Ron
Offline rschaffr
#7 Posted : 10 May 2005 07:05:21(UTC)
rschaffr
The 7175 is the replacement slider for the 7198 pickup set. The 7198 has a slider with a tube attached to the top for a plug. The slider is symmetrical with the metal slider part being about 43mm long. The base of the slider where it attaches is about 24mm long. It has a hole in the center for a screw. This attaches to a block in the 7198 set that has the tube for a plug. Hope this helps.
-Ron
Offline laalves
#8 Posted : 10 May 2005 21:03:24(UTC)
laalves
Thanks again, but still no luck: that ain't it. What I'm talking about is the pickup from the 7318 lighting kit. After a bit of research I finally found the lighting reference. It's out of production, apparently, since it's no longer in the catalog.
Anybody knows the part number for the pickup?
Luis
Offline laalves
#9 Posted : 10 May 2005 22:11:25(UTC)
laalves
Found it! http://www.pallund.dk/spareparts/marklinparts.txt
It's 44637, which I believe now translates into 446370.
Luis
Offline HueyCE
#10 Posted : 11 May 2005 03:39:05(UTC)
HueyCE
Cool that you found it.
Ira
This page was generated in 0.295 seconds.
