Offline Peter Neumann
#1 Posted : 23 January 2009 05:56:05(UTC)
Peter Neumann
The "Abfahrsignal" signal is a series of green lights arranged in a circular pattern that when turned on and showing green indicate to the locomotive engineer to depart the station. This is separate from the "Ausfahrtsignal" which is the block signal, for the track, and which always appears to the right of the track. That signal might indicate green, but the engineer wouldn't start moving the train until the "Abfahrsignal" is green too.
Could someone describe the correct placement of the "Abfahrsignal"?
It is usually located on the platform, but I am wondering if there is a 'rule' that applies for its placement? I've seen them to left and right sides of the engine, when its facing forward, depending on the direction of the train.
Any guidance is appreciated.
Offline TTRExpress
#2 Posted : 23 January 2009 06:23:58(UTC)
TTRExpress
Hi Peter,
Please refer to the following:
http://mysite.du.edu/~jc...ailway/germaust.htm#Sigs
http://www.sh1.org/eisenbahn/index.htm
Should give you the answer you are looking for.
Let me know if it helped.
#3 Posted : 23 January 2009 13:21:32(UTC)
Hi Peter,
The Abfahrsignal will be placed at the end of the platform where the train is stopped either left or right depending on the side where the doors are open (It is usually hanging from the roof if it a covered platform) or just after the platform in order for the engineer to see it.
The "H" Signaltafel for Halt should then (logically) be placed before the Abfahrsignal.
Hope this helps
#4 Posted : 23 January 2009 15:06:12(UTC)
Peter Neumann
Thank you, Jacques. You have confirmed what I had suspected... my platform roof does not extend to the end of the platform so it will be a 'stand alone' signal. I wish my roof extended far enough out to allow the hanging signal, which makes for a lovely effect.
All the best to you,
Peter in Fort Wayne
ETE-GL
#5 Posted : 23 January 2009 18:46:53(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Peter Neumann
<br />Could someone describe the correct placement of the "Abfahrsignal"?
I know they have some at Cologne Central Station - and they are mounted at the pole of the Ausfahrsignal.
Look here for a sample picture:
http://de.wikipedia.org/wiki/Abfahrsignal
They say:
"2. als „Lichtsignal“, ortsfest am Ausfahrsignal oder Zwischensignal angebracht: Ein aus mehreren Lichtpunkten gebildeter grüner Ring oder senkrechter grüner Lichtstreifen"
This means: it's on the pole of the Ausfahrsignal or a signal before that.
BTW: they have those signals only at huge stations.
On most stations the Zugführer will only lift a white plastic disc with a green ring or show a green flashlight.
Cologne central station has 11 tracks, 11 platforms and Ausfahrsignale. But Cologne Tradefair Deutz (500 metres away, 12 tracks, 10 platforms) doesn't.
I won't have them on my layout.
Signal placement (General MRR)
by mgbeck_98 14/12/2018 08:11:45(UTC)
This page was generated in 0.386 seconds.
